baddeolv Posted April 21, 2015 Posted April 21, 2015 Thanks to member xesusleo we are updated on Hyperbase, as well as the downloads section to MAME ver. .160 Instagram : baddeolv Facebook : Brian Addeo
Metalzoic Posted December 14, 2015 Posted December 14, 2015 This topic is from April. Mame is now at version 168 and will be at 169 in just a few days. If your set is up-to-date or newer than 160 you'll want to make sure to use a newer, correct XML.
craig816 Posted December 15, 2015 Posted December 15, 2015 Hello, I want to limit my HyperSpin MAME system to 100 games - all supported in MAME version .153 Is there a tool that will automatically create the MAME.xml (database file) or will I have to create manually ? Thanks for any suggestions !
Metalzoic Posted December 15, 2015 Posted December 15, 2015 Hello, I want to limit my HyperSpin MAME system to 100 games - all supported in MAME version .153 Is there a tool that will automatically create the MAME.xml (database file) or will I have to create manually ? Thanks for any suggestions ! You could use Dons Hyper Tools (in the download section) to create a limited database from your .153 XML with just the games you want. Then you use Don's tools to split that new XML to create your genre XML'x and you're done. Although I'd suggest first updating to .168 first so that you can use all the newer HLSL/GLSL effects that are missing in .153
