NullDC help - Games wont load
hobohunter2316
I got nulldc running on its own.
When I go to launch a game(from rocketlauncher or FE) it freezes on the fade screens and i must use CTL ALT DEL to get rid of them. And of course game fails to load.
Hi,
You should always start with:
Does the game play in the emulator?  Check!  Good.
Does the game launch from RocketLauncher?  No.  Bad.
Need to start with that.
All official support for RocketLauncher is done on their forum.  I will be glad to help you out over there.
rlauncher.com
Thanks,
Ron
PS:  Please post your RocketLauncher log when you get there.  (Use CODE tags)
I just got it running from nullDC
I think it is because i wasnt pointing it trowd the .cdi file
Do i have to have it unzipper(winrar) and point HyperlaunchHQ to the cdi or should it worked from the zipped file?
You do not have to have it un-zipped.  I just recommend that you get it working un-zipped first, then once it's working the way you want, use the zipped files.
Thanks,
Ron
