kadins Posted April 26, 2015 Posted April 26, 2015 When opening sega games, using the retroarch module and rocketlauncher (hyperlaunchhq) the emulator opens in the corner of the top left corner of the screen. When opening the emulator straight from the retroarch launcher everything opens centered as you would expect. No sure if this is a problem with retroarch (don't think so, since it opens fine by itself), hyperlaunch, or hyperlaunchhq. Kind of new to it all, so any help would be great! (The games run fine, just not centered)
demonseed Posted April 28, 2015 Posted April 28, 2015 I had the same issue.. if you go into the sega genesis config file in retroarch , I had sent Video-scale-interger to ON
Erika Posted May 30, 2015 Posted May 30, 2015 In the RetroArch GUI under Settings, Video Options, Aspect Ratio Index, try setting the value to "Core Provided." You can turn Integer scaling on/off if desired, also.
