craiganderson Posted April 28, 2015 Posted April 28, 2015 I HAVE NO IDEA HOW THIS WILL ALTER TOUHOU SO MAKE A BACKUPwhile setting up NEC PC-9801 i noticed the module does not load .fdi games so i tweaked it and it also will load .fdi games with two disks into drive 0 and drive 1 as long as naming is as follows Goofy Game (Disk 1).fdi ---- will go into drive 00 Goofy Game (Disk 2).fdi ---- will go into drive 01 also tweaked it so it exits fullscreen and closes (at least for me) just sharing.. thanks iCRC = 1E716C97 MEmu = T98-Next MEmuV = v13.1th Beta MURL = http://www.geocities.jp/t98next/ MAuthor = djvj MVersion = 2.0.5 MCRC = 2096D52F MID = 635038268927083194 MSystem = "NEC PC-9801","Touhou","Touhou Project" ;---------------------------------------------------------------------------- ; Notes: ; This is only needed for games 1th through 5th, so make sure in your Games.ini, you have this Emulator set to load this module ; In order to autolaunch the game, we have to write the game's name in the MAIN.ini before launching the emu ; 3th - Phantasmagoria of Dim Dream uses different keys then the other 4 games. We need to remap keys to get 2-players working, so make sure you setup a keymapper profile to change them ; ; Default PC-98 keys are: ; player 1 ; RTY ; FGH ; VBN ; shot - z ; bomb - X ; player 2 ; 789 ; 456 ; 123 ; shot - left arrow ; bomb - right arrow ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) BezelStart("fixResMode") hideEmuObj := Object("Emulation Window ahk_class T98-Next",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) ; Setting Fullscreen setting in ini if it doesn't match what user wants above t98INI := emuPath . "\MAIN.INI" IniRead, currentFullScreen, %t98INI%, CRT, FULLSCREEN If (fullscreen != "true" && currentFullScreen = 1) IniWrite, 0, %t98INI%, CRT, FULLSCREEN Else If (fullscreen = "true" && currentFullScreen = 0) IniWrite, 1, %t98INI%, CRT, FULLSCREEN IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK00 IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK01 IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK02 IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK03 If romExtension = .fdi { If InStr(romName, "(Disk") { ; simulwar (disk 1) StringTrimRight, trimmedromName, romName, 9 IniWrite, %romPath%\%trimmedromName% (Disk 1)%romExtension%, %emuPath%\MAIN.INI, DISK, DISK00 IniWrite, %romPath%\%trimmedromName% (Disk 2)%romExtension%, %emuPath%\MAIN.INI, DISK, DISK01 } else { Sleep, 100 IniWrite, %romPath%\%romName%%romExtension%, %emuPath%\MAIN.INI, DISK, DISK00 } } else If romExtension = .hdi IniWrite, %romPath%\%romName%%romExtension%, %emuPath%\MAIN.INI, DISK, DISK02 IniWrite, 1, %emuPath%\MAIN.INI, Control, AutoRun ; required for games to start on emu launch HideEmuStart() Run(executable, emuPath, "Hide") WinWait("Emulation Window ahk_class T98-Next") WinWaitActive("Emulation Window ahk_class T98-Next") Sleep, 1000 ; need this otherwise mouse doesn't move off screen MouseMove 0,2000,0 ;Move mouse off screen HideEmuEnd() BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() ; IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK00 ; IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK01 ; IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK02 ; IniWrite, %A_Space%, %emuPath%\MAIN.INI, DISK, DISK03 WinClose("ahk_class T98-Next") Sleep, 100 Process, Close, Next.exe Return http://craigandersonthemes.weebly.com/
