matabhaine Posted April 29, 2015 Posted April 29, 2015 When I run AAE from its folder it just says closing and won't run. When I run from Hyperspin I get the error Your module does not contain a startmodule() line. Please download a module that has one. I downloaded a module but AAE does not appear in the emulators section, just MAME and RA. AAE seems to have vanished.
warpig Posted April 29, 2015 Posted April 29, 2015 I have AAE set up as a system on my main menu wheel but just set the default emulator to be MAME and everything works fine
rfancella Posted April 29, 2015 Posted April 29, 2015 HI, I have AAE running just fine on both my setups. But we would need a little more info. What version of HyperLaunch(RocketLauncher) are you using? What version of the emulator and with which updates? Thanks, Ron When I run AAE from its folder it just says closing and won't run. When I run from Hyperspin I get the error Your module does not contain a startmodule() line. Please download a module that has one. I downloaded a module but AAE does not appear in the emulators section, just MAME and RA. AAE seems to have vanished. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
matabhaine Posted April 29, 2015 Author Posted April 29, 2015 The have the latest AAE from here http://pages.suddenlink.net/aae/ I cannot run AAE.exe, it just crashes and stops so I cannot find out what which version it is from within the program. I tried running it through MAME but it just goes to the populated MAME wheel instead of starting AAE running. I have the all the latest HL and HS pulled through Git four days ago. I have win 7 64bit.
rfancella Posted April 29, 2015 Posted April 29, 2015 Ok, So AAE will not run by its self? On the AAE site there are three downloads: AAE Update #2, extract to your AAE directory. (12/13/08) AAE Update #1, extract to your AAE directory. (10/27/08) AAE Alpha Binary, including required Artwork and Sound files (Not MAME Standard) Alpha Build 87, updated Sept 28th 2008 (58MB). The bottom one is the actual emulator. Update #1 is good to add. Update #2 doesn't work in a lot of setups. If the emulator does not work outside HyperSpin or HyperLaunchHQ, try to run stand alone. Then post your aae.log file here. Be sure to use code tags. Thanks, Ron The have the latest AAE from here http://pages.suddenlink.net/aae/ I cannot run AAE.exe, it just crashes and stops so I cannot find out what which version it is from within the program. I tried running it through MAME but it just goes to the populated MAME wheel instead of starting AAE running. I have the all the latest HL and HS pulled through Git four days ago. I have win 7 64bit. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
matabhaine Posted April 29, 2015 Author Posted April 29, 2015 First off, think I was being a bit of a snob when I saw the word ALPHA :-) I downloaded the alpha version and the first update, it runs outside of HS but inside HS it throws out this AutoHotKey.dll error. Error at line 472. Line Text: ReturnRunwait, %executable% %romName%, %emuPath%, Hide UseErrorLevel Error: This line does not contain a recognised action. The program will exit. Got this log too, hope it is of some help 07:10:15 PM | HyperSpin Started07:10:15 PM | Going FullScreen07:10:15 PM | Checking for updates07:10:15 PM | Update Check Complete07:10:15 PM | Startup program unavailable07:10:15 PM | Playing intro video07:10:16 PM | Error intializing joysticks07:10:16 PM | Menu Mode is multi07:10:16 PM | Loading Main Menu.xml07:10:16 PM | Main Menu.xml successfully loaded07:10:16 PM | Main Menu wheel loaded successfully07:10:17 PM | Loading AAE.xml07:10:17 PM | Main Menu.xml successfully loaded07:10:17 PM | AAE wheel loaded successfully07:10:24 PM | Launching Game07:10:24 PM | Using HyperLaunch07:10:24 PM | Getting HyperLaunch path07:10:24 PM | HyperLaunch located at C:\Hyperspin\HyperLaunch\HyperLaunch.exe07:10:24 PM | Running HyperLaunch.exe07:10:24 PM | HyperLaunch Command Line is: C:\Hyperspin\HyperLaunch\HyperLaunch.exe "AAE" "zektor"07:10:46 PM | Loading Main Menu.xml07:10:46 PM | Main Menu.xml successfully loaded07:10:46 PM | Main Menu wheel loaded successfully07:10:48 PM | Exit program unavailable07:10:48 PM | Quiting Hyperspin07:10:48 PM | Bye! HyperHQ seems to be doing a number of strange things, changing emulators execution from HL to Normal and Changing emulator from disabled to PC Game, removing extensions in the extensions window that I have added but it helps your learning curve when you have to find errors. Thanx for the help.
rfancella Posted April 29, 2015 Posted April 29, 2015 Hi, Great. Part of the way there. AAE runs outside of HS and HLHQ! It also appears, from the log, that HyperSpin is correct also. Good! The issue appears to be in your HyperLaunch (RocketLauncher) configuration. This issue would best be addressed at the RLauncher.com site. Please set your logging level to Troubleshooting and post your HyperLaunch log there (with code tags). Thanks, ron First off, think I was being a bit of a snob when I saw the word ALPHA :-) I downloaded the alpha version and the first update, it runs outside of HS but inside HS it throws out this AutoHotKey.dll error. Error at line 472. Line Text: ReturnRunwait, %executable% %romName%, %emuPath%, Hide UseErrorLevel Error: This line does not contain a recognised action. The program will exit. Got this log too, hope it is of some help 07:10:15 PM | HyperSpin Started 07:10:15 PM | Going FullScreen 07:10:15 PM | Checking for updates 07:10:15 PM | Update Check Complete 07:10:15 PM | Startup program unavailable 07:10:15 PM | Playing intro video 07:10:16 PM | Error intializing joysticks 07:10:16 PM | Menu Mode is multi 07:10:16 PM | Loading Main Menu.xml 07:10:16 PM | Main Menu.xml successfully loaded 07:10:16 PM | Main Menu wheel loaded successfully 07:10:17 PM | Loading AAE.xml 07:10:17 PM | Main Menu.xml successfully loaded 07:10:17 PM | AAE wheel loaded successfully 07:10:24 PM | Launching Game 07:10:24 PM | Using HyperLaunch 07:10:24 PM | Getting HyperLaunch path 07:10:24 PM | HyperLaunch located at C:\Hyperspin\HyperLaunch\HyperLaunch.exe 07:10:24 PM | Running HyperLaunch.exe 07:10:24 PM | HyperLaunch Command Line is: C:\Hyperspin\HyperLaunch\HyperLaunch.exe "AAE" "zektor" 07:10:46 PM | Loading Main Menu.xml 07:10:46 PM | Main Menu.xml successfully loaded 07:10:46 PM | Main Menu wheel loaded successfully 07:10:48 PM | Exit program unavailable 07:10:48 PM | Quiting Hyperspin 07:10:48 PM | Bye! HyperHQ seems to be doing a number of strange things, changing emulators execution from HL to Normal and Changing emulator from disabled to PC Game, removing extensions in the extensions window that I have added but it helps your learning curve when you have to find errors. Thanx for the help. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
