Roverius Posted April 30, 2015 Posted April 30, 2015 Hello, I would like to setup eXoDOS (eXoDOS V2) with HL2 but have no clue how to set it up in HyperlaunchHQ I made allready a new entry, but have not the finest clue what to set for "emulator" "rompath" and "rom extension". I use meagre for the moment, but don't want to use that (unless i don't have a option to use in hyperspin) btw, when i use meagre, the game installs first to the harddisk, but doesn't remove after playing. I think my harddrive will get out of space when playing some of this collection after a while. I have allready the XML file and a module made by djvj ;---------------------------------------------------------------------------- ; DOS ; dfend v1.1.0 ; by djvj ; 1.1 ; ; Notes: ; Blank txt files need to be created for every game ; romPath needs to point to the dir with all the blank txt files ; Setup all your games in the dfend frontend, this script will launch each game using dfend instead of straight dosbox ; This allows for easy editing of dosbox settings in case they are needed ; There is no exit key setup, it is needed for in-game menu usage. ; Controls are done via in-game options for each game. ;---------------------------------------------------------------------------- ;These GUI settings allow for a much cleaner launch Gui +AlwaysOnTop -Caption +ToolWindow Gui, color, 0 Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%, HSHIDE RunWait, %executable% "%romName%", %emuPath% Process, WaitClose, DOSBox.exe Gui Destroy ExitApp CloseProcess: return All help is appreciated If anyone know where to find some wheelart, please let me know Regards, Roverius
damageinc86 Posted April 30, 2015 Posted April 30, 2015 Exodos is too huge for me. I just hand pick my dos stuff and add it manually to Dfend Reloaded. There's a Dfend module in HL, iirc it was set up like most other systems in HL
Roverius Posted April 30, 2015 Author Posted April 30, 2015 Exodos is too huge for me. I just hand pick my dos stuff and add it manually to Dfend Reloaded. There's a Dfend module in HL, iirc it was set up like most other systems in HL Yes, OK, but what to set in hyperHQ? and what to use as emulator? I am completly stuck at this point. The dosgames run mostly with dosbox, so i dont have any idea how to set things up in hyperlaunchHQ Can you post maybe youre dfend.ini or dos.ini file please or whatever the *.ini file is named under settings. I might narrow it down also, would be a bit pointless to add all 5000 games into hyperspin. Thanks Roverius
Roverius Posted May 10, 2015 Author Posted May 10, 2015 I have made a small workaround to get this working 1: I use "Meagre" to install the wanted game (e.g.: Commander Keen 1 = CKeen1) 2: I make a shortcut (hyperlink) from the "..\Games\!dos\CKeen1\Commander Keen 1 - Marooned on Mars (1990).bat" file and name it "CKeen1.lnk" 3. I made a "ROM" folder in my "Emulators/DOS" folder 4. Moved the "CKeen1.lnk into the "ROM" folder This is the DOS.INI setting (just top part) [exe info] path= rompath=H:\Hyperspin\Emulators\DOS\roms\ userompath= exe= romextension=lnk parameters= searchsubfolders= pcgame=true winstate=HIDDEN hyperlaunch=false Per_Game_Modules=false All works well. Now, the big challenge is to create themes. I have made a default theme so far, but i going to try to make some game specific themes (if i can find some art) Regards, Roverius
