Brand new build, slow wheel performance
taekwonjohn36
Hello, HyperGurus. I finally have all of my emulators configured and mapped + plus all the wheels I want set-up in Hyperspin. However, there seems to be some choppy lag when navigating from wheel to wheel as well as game to game. This isn't an inferno of a PC I've built but I would like to think it should handle a simple hyperspin set-up plenty well enough. This is a mini ITX build. Specs as follows:
-MSI AM1I motherboard
-AMD Athlon 5350 APU quadcore 2.1ghz
-4GB GSkill Ripjaw DDR3 1600
-Gigabyte nVidia GeForce 210 1GB DD3 64bit GPU
-1TB WD Blue 7200rpm HDD
-InWinn Mini ITX Case w/300w ITX PSU case
I'm only running cartridge based systems on this build so the low end card should handle it, I would think. But the games seem to emulate fine, it's just hyperspin that is performing slow. Any suggestions as to why or things I can try to get better performance? I've messed with the optimization in HQ and it didn't seem to make any difference turning things off in that menu. Thanks in advance for reviewing and offering advice.
-John
Thanks, guys. I've been trying the beta. It resolved an issue I was having with not being able to use my controller on the main menu. However, I can't launch any games now. The path in the ini file still has hyperlaunch in the same spot. Any ideas? Also, where do I put the script file that came with the beta?
better read this topic
http://www.hyperspin-fe.com/topic/8392-hyperspin-14-private-beta-testing/?p=148010
for the beta you have to add something in the ini and so on.
