Missing items on the wheel with Filter ROMs
shadersrjj
For my 3DO setup I have 15 CDs (a mix of ISOs and NRGs).
With Wheel Filters: Rom Only unchecked all the games run fine.
However, with it checked the wheel only displays 14.
Has anyone else noticed this (or is there a fix) ?
Thanks
RJJ
I'm having an issue with locating games when "rom only" is checked. When selecting an emulator from the main menu I get booted back to the main menu. The log reports that no games are found even though when "rom only" is unchecked I can access the emulators/games.
Have you set the rom path and extension in HyperHQ? If not, it won't know which roms to display.
+1 to Agrajag.
A couple more hints as well:
Seperate the rom extensions in HyperHQ with a comma.
The extensions are case sensitive, so you have to put iso,ISO,nrg,NRG etc
The files must all be in the same directory, not in sub-directories.
Thanks,
Ron
Thanks for the steer.
Actually is was the case of the ROM name rather than the extension.
The file name was "Out Of This World (USA)" and the xml database entry had "Out of this World (USA)"
You can see that the upper case 'O' and 'T' seem to make a difference.
I changed the file name and everything worked fine
I can't help thinking that this should be case insensitive.
Many Thanks
