HyperHQ won't run, "not responding" in task manager
jbyrum
I have my Hyperspin all configured and everything works great with one exception: HyperHQ will not run so I can't get Hyperspin set to run at full screen.
When I launch HyperHQ, nothing happens and when I go into task Manager it is listed as "not responding".
Which file do I need to modify in order to set Hyperspin to run Full Screen without using HyperHQ to do it??
If I can get this done I don't think I'll even need HyperHQ for now.
Thanks in advance!
Jerry
You should be able to set it manually inside an ini, settings.ini maybe ?
I'm away from my cab at the moment so can't tell you which specific file.
sig2.png?raw=1sig.jpg?raw=1
Yes, it was in Settings.ini   Thanks!!
Now I just need to figure out why HyperHQ won't run so that I can make other adjustments to my system.
