or8ital Posted May 7, 2015 Posted May 7, 2015 File Name: Hyper Helper File Submitter: or8ital File Submitted: 06 May 2015 File Category: Other Credits: Or8ital Used to display info on a second screen http://www.hyperspin-fe.com/topic/930-or8itals-hyperspin-helper-software-2nd-3rd-display-controller/ Features: - Will display game / controls information on a secondary display * Displays logos for system, game, genre, and rating * Displays actions for each button if available (mame, but could work with others following same format) * Displays primary control (4 way, 8 way, steering, spinner, etc) - Makes sure all windows stay in place going into and out of emulators so there is no screen shifting (some emulators cause this today) - Removes the taskbar whenever hyperspin starts (and restores it when it closes). This is for folks not running fullscreen. - Primarily using assets already present in hyperspin. No dual maintenance of files / art when possible. - Runs in system tray. Automatically shows when HS launches and hides when HS closes. - Shows a "please select game" / splash graphic when between games. - Display marquee images on screen above main screen Click here to download this file Info on HyperspinHelper Software: http://hyperspinhelper.wordpress.com. Allows you to enable two additional displays as a Marquee and a controls help screen as well as map UltraStik 360 controls. Works exclusively with Hyperspin.
guts46and2 Posted September 8, 2015 Posted September 8, 2015 I have been working with this program for the better part of a day. It has been relatively easy so far. I have one problem. I only have two folders on my FE Mame and Daphne. Mame works just fine but when I launch Daphne the marquee image on the second screen disappears. If I use the windows key to toggle in and out of the program it will return and stay like it's supposed to and when I exit Daphne the HS screen's resolution is messed up even though the resolutions all match. Any advice would be helpful, thanks in advance.
