Help getting games to launch
snstay
Hey all im trying to get my games to launch, Im using rocketlauncher and cant figure out what the deal is.
Now im not sure if i have the right path set up. This is what i have in my settings ini
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Hyperlaunch_Path=C:\Hyperspin\HyperLaunch\
Is that path correct for rocketlauncher?
If thats not the problem any help on getting games to launch would be appreciated.
Thanks
From your settings I assumed that you extracted your RocketLauncher zip files into HyperLaunch folder? By default it is recommended to extract it into RocketLauncher folder. If you do so, also change your Hyperlaunch_Path to point to the RocketLauncher folder instead:
[Main]
Menu_Mode=multi
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Bandai WonderSwan Color
Hyperlaunch_Path=G:\Hyperspin\RocketLauncher\
