sonicboom88 Posted May 25, 2015 Posted May 25, 2015 hi guys trying to help me friend with hes daphne singe hes american laser games work fine but with wow action max every time he starts the same game it keeps saying press any key to parse file any ideas what the problem could be ? here is hes log... --DAPHNE version 1.0.10 --Command line is: H:\Hyperspin\emulators\daphne-singe\daphne.exe singe vldp -x 1024 -y 768 -fullscreen_window -framefile H:\Hyperspin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.txt -script H:\Hyperspin\Emulators\daphne-singe\singe\ActionMax\38AmbushAlley.singe --CPU : AuthenticAMD 4100 MHz || Mem : 4096 megs --OS : Windows XP/.NET || Video : AMD 760G --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting screen width to 1024 Setting screen height to 768 Set 1280x1024 at 32 bpp with flags: 20 Initializing sound system ... Joystick #0 was successfully opened Framefile parse succeeded. Video/Audio directory is: H:/Hyperspin/Emulators/daphne-singe/singe/ActionMax/./ YUV overlay is done in software (ie unaccelerated). LDP-VLDP: Could not parse video because file video_Menu.m2v could not be opened. Booting ROM ... Starting Singe version 1.14 Search to 1 received [blocking] NOTE: converting FPKS from 23976 to 29970. This may be less accurate. Search to 819 received [blocking] Freeing memory used to store audio stream... NOTE: converting FPKS from 23976 to 29970. This may be less accurate. Search to 28175 received [blocking] LDP-VLDP.CPP : Could not open video file video_Menu.m2v LDP : search failed immediately Play Search to 1 received [blocking] Freeing memory used to store audio stream... NOTE: converting FPKS from 23976 to 29970. This may be less accurate. Play End of audio stream detected! Search to 355 received [blocking] Freeing memory used to store audio stream... NOTE: converting FPKS from 23976 to 29970. This may be less accurate. Play Stop Freeing memory used to store audio stream... Shutting down sound system... Shutting down video display... Hyper Helper Ready To Help
sonicboom88 Posted May 26, 2015 Author Posted May 26, 2015 yeah same with mine but my friends it keeps coming up Hyper Helper Ready To Help
