Convert Zip files to 7z files
Howdy folks.
Just thought I would share a quick tip if you ever wanted to convert any of your compressed roms in the zip format to 7z to save few extra megabytes.
Copy the code below into a batch file (e.g. 7z.bat)
for %%F in (*.zip) do ( "C:\Program Files\7-Zip\7z.exe" x -y -o"%%F_tmp" "%%F" * & pushd %%F_tmp & "C:\Program Files\7-Zip\7z.exe" a -y -r -t7z ..\"%%~nF".7z * & popd & rmdir /s /q "%%F_tmp" )
Then place the batch file within the directory full of your zip files and run it.
This code will run 7zip and extract all files with the .zip extension within a particular directory, then compress them again in the .7z format.
e.g. 1942.zip                                                   ---> 1942.7z
       hyperspin.zip                                           ---> mariobros.7z
       iNTiGODsavedmespaceandsanity.zip     ---> iNTiGODsavedmespaceandmysanity.7z
Extra notes:
+ This does not delete your .zip files.
+ This code assumes you have 7-zip installed into your c:\program files\7-zip\ folder (you can change the code above to suite your needs)
+ Very rarely after recompressing a file the .7z extension is not added.
      e.g. 1942.zip gets extracted and recompressed into a 7z file as 1942   ----> simply add the .7z extension e.g. 1942.7z (double click the file and it should open in 7zip)
Cheers
