smockbee Posted September 7, 2016 Posted September 7, 2016 Hey guys, new to this hyperspin set up. I watched a lot of videos by simply Austin, however I am still coming short on making the rocket launcher work with hyperspin. They do not seem to be communicating correctly. I've done what was said on post #23, but still no luck. Issue: Getting an error message when I click on the rocket icon "Could not find your emulator application: " C:Hyperspin\Emulator\SNES9x\snes9x-1.53-win32-x64-x64.exe." Troubleshooting: I'm just doing baby steps for now and trying to launch Super Nintendo Entertainment System. I've tried the znes151 emulator and that was not successful and now I tried the snes9x emulator with the same end result of not working. Each emulator works on it it's on fine with the roms, but still can't connect to hypespin front end. Also 95% of the games in the audit tab are green and good to go Below is the log for hyperspin. 08:19:15 PM | HyperSpin Started08:19:15 PM | Going FullScreen08:19:15 PM | Checking for updates08:19:15 PM | Update Check Complete08:19:15 PM | Startup program unavailable08:19:15 PM | Playing intro video08:19:33 PM | Error intializing joysticks08:19:33 PM | Menu Mode is multi08:19:33 PM | Loading Main Menu.xml08:19:33 PM | Main Menu.xml successfully loaded08:19:34 PM | Main Menu wheel loaded successfully08:19:37 PM | Loading Super Nintendo Entertainment System.xml08:19:37 PM | Main Menu.xml successfully loaded08:19:38 PM | Super Nintendo Entertainment System wheel loaded successfully08:20:03 PM | Super Nintendo Entertainment System wheel loaded successfully08:20:24 PM | Launching Game08:20:24 PM | Using HyperLaunch08:20:24 PM | Getting Launcher path08:20:24 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe08:20:24 PM | Running Launcher08:20:24 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "Super Nintendo Entertainment System" "Adventures of Batman & Robin, The (USA)"08:20:35 PM | Loading Main Menu.xml08:20:35 PM | Main Menu.xml successfully loaded08:20:35 PM | Main Menu wheel loaded successfully08:20:39 PM | Exit program unavailable08:20:39 PM | Quiting Hyperspin08:20:39 PM | Bye! Please help! Trying to get this set up for the myself and the kids!
tanuki Posted September 7, 2016 Posted September 7, 2016 I did what was in post #23. It did not help. I also modified the Settings.ini file to point to RocketLauncher.exe as suggested elsewhere in this thread.
JoyStickKilla Posted September 7, 2016 Posted September 7, 2016 Did you setup the emulator in RLUI though?
tanuki Posted September 9, 2016 Posted September 9, 2016 Yes. I can launch everything fine from RLUI. It's only when I try to use HyperSpin that it fails.
tanuki Posted September 10, 2016 Posted September 10, 2016 My mistake was exactly as you described. Thanks for helping out the clueless
teffers2412 Posted March 28, 2017 Posted March 28, 2017 I'm having similar issues tried all of the above running latest rlauncher and 1.4 hyperspin don't know what the issue is tried renaming rlauncher to hyperlaunch tried the transition tool but nothing all works fine in rlauncherui and loads perfectly but try hyperspin and I just get error after error all on my d: drive database etc are looking fine looked at the .ini file looks right buy error after error help is understatement as to what I need right now error is cannot find database mame/mame.xml if your able and can help pleeeeeeeeaaaaaaaaaassseeeee do
teffers2412 Posted March 28, 2017 Posted March 28, 2017 I'll let you know how I get on any further issues I'll post but thanks for quick reply it's frustrated the crap out of me the last couple of days thought I was missing something in hq if I'm honest also I remembered you mentioning something about database only needed either in hyperspin or rl folders where should they initially be as I have one in hs and one in rl just found it caused less issues in the past
teffers2412 Posted March 28, 2017 Posted March 28, 2017 ok so I tried what you said agent47 however still having issues so heres my log 05:43:35 PM | HyperSpin Started 05:43:35 PM | Going windowed mode 05:43:35 PM | Checking for updates 05:43:35 PM | Update Check Complete 05:43:35 PM | Startup program unavailable 05:43:35 PM | Playing intro video 05:43:40 PM | Error intializing joysticks 05:43:40 PM | Menu Mode is multi 05:43:40 PM | Loading Main Menu.xml 05:43:40 PM | Main Menu.xml successfully loaded 05:43:41 PM | Main Menu wheel loaded successfully 05:43:42 PM | Loading MAME.xml 05:43:42 PM | Main Menu.xml successfully loaded 05:43:43 PM | MAME wheel loaded successfully 05:43:47 PM | Launching Game 05:43:47 PM | Using HyperLaunch 05:43:47 PM | Getting Launcher path 05:43:47 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 05:43:47 PM | Cannot find Launcher 05:43:48 PM | Launching Game 05:43:48 PM | Using HyperLaunch 05:43:49 PM | Getting Launcher path 05:43:49 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 05:43:49 PM | Cannot find Launcher 05:43:50 PM | Launching Game 05:43:50 PM | Using HyperLaunch 05:43:50 PM | Getting Launcher path 05:43:50 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 05:43:50 PM | Cannot find Launcher 05:43:51 PM | Launching Game 05:43:51 PM | Using HyperLaunch 05:43:51 PM | Getting Launcher path 05:43:51 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 05:43:51 PM | Cannot find Launcher 05:43:53 PM | Launching Game 05:43:53 PM | Using HyperLaunch 05:43:53 PM | Getting Launcher path 05:43:53 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 05:43:53 PM | Cannot find Launcher and heres my settings ini any further help appreciated now says "cannot find launcher" the mind is fried lol Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=no Exit_Action=exit Version=1.0.0.0 Last_System=MAME HyperLaunch_Path=D:Hyperspin\RocketLauncher\RocketLauncher.exe Use_Last_Game=false [Resolution] FullScreen=false Width=800 Height=600 Scanlines_Active=false Scanlines_Image=Artwork2 Scanlines_Scale=2 Scanlines_Alpha=0.1 [Optimizer] CPU_Priority=normal Quality=BEST Image_Smoothing=true Animated_Backgrounds=true Inter_Backgrounds=false Level1_Backgrounds=true Level2_Backgrounds=true Level3_Backgrounds=false Level4_Backgrounds=false Special_Backgrounds=true Wait_For_Special=false Animated_Artworks=true Level1_Artworks=true Level2_Artworks=true [IntroVideo] Use_Intro=true Stop_On_Keypress=true [Sound] Master_Volume=100 Video_Volume=100 Wheel_Volume=20 Interface_Volume=100 [AttractMode] Active=true Time=60 MaxSpinTime=10 HyperSpin=true Wait_For_Video=false [Keyboard] Key_Delay=true [P1 Controls] Start=13 Exit=27 Up=38 Down=40 SkipUp=37 SkipDown=39 SkipUpNumber=70 SkipDownNumber=86 HyperSpin=32 Genre=71 Favorites=76 [P2 Controls] Start=69 Exit=81 Up=87 Down=83 SkipUp=65 SkipDown=68 SkipUpNumber=74 SkipDownNumber=77 HyperSpin=88 Genre=72 Favorites=90 [P1 Joystick] Enabled=true Joy=0 Threshold=40 Start=Button_10 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [P2 Joystick] Enabled=true Joy=1 Threshold=40 Start=Button_1 Exit=Button_2 Up=Analog_Up Down=Analog_Down SkipUp=Analog_Left SkipDown=Analog_Right SkipUpNumber=Button_3 SkipDownNumber=Button_4 HyperSpin=Button_5 Genre=Button_6 Favorites=Button_7 [Trackball] Enabled=false Sensitivity=90 [Spinner] Enabled=false Sensitivity=90 [Startup Program] Executable= Paramaters= Working_Directory= WinState=NORMAL [Exit Program] Executable= Paramaters= Working_Directory= WinState=NORMAL [LEDBlinky] Active=false Path= [HiScore] Active=false Y=550 Delay=2 [HyperLaunch] Last_System=MAME Last_Rom=zigzag Exit_Script_Key=~q & ~s Exit_Emulator_Key=Esc Toggle_Cursor_Key=t MultiGame_Key=NumpadSub MultiGame_Select_Key=Enter MultiGame_Exit_Key=Esc Path_To_Daemontools= Path_To_CPWizard= Fade_In_Interrupt_Keys=anykey Keymapper_Path= Keymapper_Profiles_Path=D:\Hyperspin\Keymapper Profiles\
teffers2412 Posted March 28, 2017 Posted March 28, 2017 ok done that now its saying cannot find database on whatever system I try to load I give up its got to be something simple I know but if it jumped up and bit me in the nose id have a clue any suggestions 47
teffers2412 Posted March 28, 2017 Posted March 28, 2017 path to hyperspin is correct I'm currently overlooking databases where does it need to be currently I have it in Hyperspin under databases also have same folder in rlui I swear I cant thak you enough for being so patient I did it all fine on other laptop just cant access it arrggggghhhhh!!!!!!!
teffers2412 Posted March 28, 2017 Posted March 28, 2017 Ive checked its all there all files are D:\Hyperspin\Databases\System\System.xml rl is set to hs .exe path Ive removed database from rlui stil same issue "cannot find databases\system\system.xml my feeling is its something in the ahk or script file but if I'm honest I'm lost for ideas anything I could be missing in hhq but thanks for your help agent 47 oh and all running in admin????
teffers2412 Posted March 28, 2017 Posted March 28, 2017 Finally got it working Thank you Thank you Thank you it seemed to be that the database wasn't in correct folder simple error but at least its fixed only issue I have now is when I launch nes it brings up a window to prevent me using full screen as if it was generating a arcade coin op screen checked media but cant seem to find it any ideaas and once again thanks agent 47 and apologies for the copy and paste noticed the error and thought it would have helped
YaYaLand Posted June 4, 2017 Posted June 4, 2017 Hello All ! I'm new to HyperSpin but not new to emulation. I'm a bit lost because i have troubles launching games within HS1.4.16 with RL1.2.0.1. In RLUI, under General Settings, RocketLauncher, i've set Default Frontend Path to the exe of HyperSpin (..\Hyperspin\HyperSpin.exe) and then choosed Default Plugin to be HyperSpin as i will only use only one frontend. In RocketLauncherUI tab, under Frontends, i created a new frontend with path ..\..\Hyperspin\HyperSpin.exe, RocketLauncherUI set to HyperSpin, RocketLauncherUI plugin set to HyperSpin. In HS, i've modified the file settings.ini under D:\Games\Hyperspin\Settings to [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=SNK Neo Geo Hyperlaunch_Path=D:\Games\RocketLauncher\RocketLauncher.exe In HyperHQ, i have two wheels, one for SEGA Genesis and one for SNK Neo Geo. Both setup with Execution : HyperLaunch PC Game : disabled Executable : empty Rom Path : empty Params : empty Extensions : zip Use full path to rom : enabled Search SUbfolders : enabled (should i put disabled ??) winstate : hidden Command line preview returns : HyperLaunch.exe "Sega Genesis" "RomName" and HyperLaunch.exe "SNK Neo Geo" "RomName" In RLUI, both emulators are setup and ALL games launches properly. No missing rom, no alerts. When back to HS, if i choose any of the Genesis games, nothing happens, even no error message... I need to quit, quit RL in the systray, then relaunch HS to be able to launch ONE SNK Game. Only one, if i quit this game, nothing more can happen. I need to quit HS, quit RL in systray, then launch again HS, choose one game in SNK Neo Geo, play it, and then quit etc.... Whatever i do, i cannot get one Genesis to run... What am i missing ??? Thanks a lot for your help EDIT : after a complete reboot of the whole system, i now have this error message but still no roms loading from Genesis, and only one possible game loading from SNK when fresh rebooting the Frontend
Avar Posted June 4, 2017 Posted June 4, 2017 Have you tried running as administrator in compatibility? Also, could you please post your log.txt? Cheers!
YaYaLand Posted June 4, 2017 Posted June 4, 2017 Thanks a lot for your reply Avar. I've already tried launching all programs with admin rights but it does not change anything. Then i've already tried compatibility mode with many different options and still the same. The fact is that when it "crashes" i cannot do anything without a complete reboot. I've managed to run Genesis games several time, from fresh reboot, i can play non stop to genesis but for example if i try to launch then a SNK, nothing happens and i cannot then launch anymore a Genesis. If i boot fresh and try directly to launch SNK, i can launch only ONE game, then nothing more happens (nor SNK nor Genesis)... Really strange... The above error message... i dug a bit and i found that it may occur from wrong version of emu but i have fusion 3.64 from official site and i've loaded the good module Here's my log.txt found under Hyperspin folder. Thanks a lot for any further help. 07:22:43 PM | HyperSpin Started 07:22:43 PM | Going FullScreen 07:22:44 PM | Checking for updates 07:22:44 PM | Update Check Complete 07:22:44 PM | Startup program unavailable 07:22:44 PM | Playing intro video 07:22:45 PM | Error intializing joysticks 07:22:45 PM | Menu Mode is multi 07:22:45 PM | Loading Main Menu.xml 07:22:45 PM | Main Menu.xml successfully loaded 07:22:45 PM | Main Menu wheel loaded successfully 07:22:47 PM | Loading Sega Genesis.xml 07:22:47 PM | Main Menu.xml successfully loaded 07:22:47 PM | Sega Genesis wheel loaded successfully 07:22:48 PM | Launching Game 07:22:48 PM | Using HyperLaunch 07:22:48 PM | Getting Launcher path 07:22:48 PM | Launcher located at D:\Games\RocketLauncher\RocketLauncher.exe 07:22:48 PM | Running Launcher 07:22:48 PM | Launcher Command Line is: D:\Games\RocketLauncher\RocketLauncher.exe "Sega Genesis" "Sonic Eraser (Japan) (Translated En)" 07:22:54 PM | Launching Game 07:22:54 PM | Using HyperLaunch 07:22:54 PM | Getting Launcher path 07:22:54 PM | Launcher located at D:\Games\RocketLauncher\RocketLauncher.exe 07:22:54 PM | Running Launcher 07:22:54 PM | Launcher Command Line is: D:\Games\RocketLauncher\RocketLauncher.exe "Sega Genesis" "Sonic Eraser (Japan) (Translated En)" 07:23:07 PM | Loading Main Menu.xml 07:23:07 PM | Main Menu.xml successfully loaded 07:23:07 PM | Main Menu wheel loaded successfully 07:23:12 PM | Exit program unavailable 07:23:12 PM | Quiting Hyperspin 07:23:12 PM | Bye!
YaYaLand Posted June 4, 2017 Posted June 4, 2017 Maybe it can help, i'm using : Final Burn alpha 0.2.97.40 instead of 0.2.97.38 as described in module. But i've tried version 0.2.97.38 both 32 and 64 bits, and also tried 0.2.97.40 both 32 and 64 bits and the problem is always the same : i can launch only one SNK Neo Geo game and if i quit that game, i cannot launch any other games from any other systems (only 2 available for now as i'm starting a complete from scratch build) As for Fusion, i'm using version 3.64 (i guess 32 bits as not specified)
Avar Posted June 4, 2017 Posted June 4, 2017 Ok and you said everything runs fine through RLUI when you audit and launch there? Also, please confirm HS is set as both default -and- active frontend in RLUI. I think you did but it wasn't clear. Does the same thing happen if you use MAME for Neo Geo?
YaYaLand Posted June 4, 2017 Posted June 4, 2017 Yes i confirm that in RLUI, HS is both set active and default (sorry i forgot to specify). And yes, in RLUI, audit and launch is perfect and i never had any error. I didn't try to launch with MAME or any other emulators, i will test and let you know... But this can eventually solve my SNK problem but i will still have a problem with Genesis as it won't launch and will display the specified error randomly... I can for example launch and play 10 games and then no more, or i can play 2 and then no more... And between each test, either i reboot the laptop, either i kill all processes to completely clear the memory from resident data. I must add that i'm a computer addict since '92, and playing EMU's since '97, i was a programmer also so i'm not really a noob about all these stuffs even if i'm discovering HS. I'm really surprised of the behaviour i'm having and i've also tried many things before posting here. Thanks for your help
Avar Posted June 4, 2017 Posted June 4, 2017 Yes it sounds like your difficulties are abnormal and you've covered the basics. What's your exit key set to? And could you please attach your Genesis/Neo Geo specific inis.
YaYaLand Posted June 4, 2017 Posted June 4, 2017 For the moment, my exit key is mapped by default to ESC, i didn't not mess with any options other that setting the EMU's, modules and linking HS to RL. Her's my ini for Genesis from HS [exe info] path= rompath= userompath=true exe= romextension=zip parameters= searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true [filters] parents_only=false themes_only=false wheels_only=false [themes] use_parent_vids=true use_parent_themes=true animate_out_default=true reload_backgrounds=true [wheel] alpha=.15 small_alpha = 1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=400 norm_small=200 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=D:\Games\Hyperspin\Media\Sega Genesis\Video [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=true jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=true last_game=Shadow of the Beast (USA, Europe) random_game=false start_on_favorites=false [Special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640 And here is the ini for SNK from HS [exe info] path= rompath= userompath=true exe= romextension=zip parameters= searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true [filters] parents_only=false themes_only=false wheels_only=false [themes] use_parent_vids=true use_parent_themes=true animate_out_default=true reload_backgrounds=true [wheel] alpha=.15 small_alpha = 1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=D:\Games\Hyperspin\Media\SNK Neo Geo\Video [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=true jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=true last_game=androdun random_game=false start_on_favorites=false [Special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640 Following is the ini from RL for Genesis [ROMS] Default_Emulator=Kega Fusion 3.64 Rom_Path=..\Hyperspin\ROMS\Sega Genesis [Kega Fusion 3.64] Emu_Path=..\Hyperspin\Emulators\Fusion364\Fusion.exe Rom_Extension=zip Module=..\Fusion\Fusion.ahk Pause_Save_State_Keys= Pause_Load_State_Keys= And last one, the ini from RL for SNK [ROMS] Default_Emulator=Final Burn Alpha 0.2.97.40 Rom_Path=..\Hyperspin\ROMS\SNK Neo Geo [Final Burn Alpha 0.2.97.40] Emu_Path=..\Hyperspin\Emulators\fba64_029740\fba.exe Rom_Extension=zip Module=..\Final Burn Alpha\Final Burn Alpha.ahk Pause_Save_State_Keys= Pause_Load_State_Keys= If you need any other file, please let me know. Thanks.
YaYaLand Posted June 4, 2017 Posted June 4, 2017 ok i made some more tests and now i discovered that i can no longer launch more than one game in RLUI. If i want to launch another game either from SNK or Genesis, i need to kill the systray daemon RocketLauncher.exe :/ I don't understand what's happening. Does this daemon normally should kill every time i quit a game ? or is it remaining resident ? So, to summarize : i can launch any game in RLUI but to be able to launch another one when i quit one game, i need to kill the daemon, i don't need to quit RLUI, just kill the daemon, and then i can laucnh another game from whatever system... Strange behavior, seems to be a problem with RocketLauncher itself
Avar Posted June 4, 2017 Posted June 4, 2017 Do you have every Visual C++ and .net redistributable? And does the same behaviour occur if you change your exit key? Nothing glaring's standing out to me atm but I'm not at my rig to check stuff. Prolly worth asking on RocketLauncher about this as well.
YaYaLand Posted June 4, 2017 Posted June 4, 2017 As you can see there, i have all the VCC I changed the EXIT key in HS to something else but it does not affect EXIT in RL as it's independant, in RL i didn't find any way to map an exit key except the emergency exit key if a module get stuck. Within HS, the new mapped EXIT key only behave on the frontend not in the EMU's so it does not change anything mapping another EXIT key. I'm going to register on RL.com to ask there also, thanks for your help, i keep searching to resolve this problem and i will post there any further result.
