Terror Drome (PC GAMES) Exiting Help
demonseed
Hey.
So I got terror drome working, but it wont exit? I tried using the "H" key and set it to hold for three seconds but it wont exit. Is there a way to exit a pc game?
thanks
Jim
Yes using RL.. is there a decent tutorial about PC games, I had to go on youtube and do some hackish way :) the way of using PCLAUNCHER.ahk and adding the EXE in RL did not work.
I can teamviewer you and take a look if you want to pm me your info. It's super easy
Instagram : baddeolv
Facebook : Brian Addeo
Thanks for offer but Before I do that I would like to try and get it going so I understand how it works... Is there a descent tutorial?
Ok I got it running fine in hyperspin but still wont exit. I went into PC MODULE and tired all the exit methods but it wont work?
So I tried another PC game and it does the same thing, so it must be a setting I am not doing.  I got my tutorial off youtube (cant paste link here, not sure why).. but its rather old maybe it is different.? I tried newer tutorials but got nothing, not even the games to load. This one loads but doesn't exit.
I also do not understand why I can not copy a URL and paste it here? it will not work
Set an "appwaitexe" then set exit method to "process close appwaitexe
Well I tried both ways it seems to do nothing... I did notice that when I try to run terror drome from RL it does not load, only in HS.  Maybe that is the issue? Is there a how too set it up from scratch?
I'm sure it's something minor, but I'd actually need to see it for myself. If all else fails, try posting about it in the rocketlauncher forums
