Metalzoic Posted June 7, 2015 Posted June 7, 2015 These Jezze changes make a huge improvement to how it looks. However does anyone know what ShadowMask settings should be now and which shadowmask is best to use? I used crt_shadow_mask.png before, but now it makes it super massive on the screen.
Metalzoic Posted June 7, 2015 Author Posted June 7, 2015 Ah, found the answer in this post from Jezze! http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=341036&page=0&view=expanded&sb=5&o=&fpart=1&vc=1 He made big changes to how the Shadow Mask X/Y settings work. My old setting were in the 100's, I set them to 6 and it fixed it. Quote Short answer:Code:shadow_mask_texture slot-mask.pngshadow_mask_x_count 6shadow_mask_y_count 6shadow_mask_usize 0.1875shadow_mask_vsize 0.1875Long answer:Direct3D uses textures with a size of power-of-two, which means every texture will be extended to the next power-of-two; e.g. 48x48 will be extended to 64x64. To get a complete tile of the slot-mask you need 12x12 pixel, starting at the left upper corner. Now a simple division...12 / 64 = 0.1875... and you have the size of the tile in uv-coordinates.What's about the xy-count? In previous versions of the shader you could specify how many times the uv-sized texture should be tiled. Now you can specify how large one tile should be displayed on the screen.In this example the 12x12 pixel large tile will be displayed as 6x6 pixel on your screen. In other words you can scale the mask.Unfortunately, a large prescale is required to get a clear result. The slot-mask and the adapture-grill should be used with a prescale of at least 6, the shadow mask can be used with a prescale of 4. A smaller prescale will result in a blurry mask.
