BiZzAr721 Posted June 11, 2015 Posted June 11, 2015 I haven't been on these forums in some time, so it was quite the treat when I turned on my shield TV and saw Hyperspin! Thank you for all the hard work. When I first set it up with the HS 1.3 download & some roms to test it everything worked fine. The next night I took the HDD out of my arcade and copied my database files, media & roms. It all was working how I wanted on my PC. I opened HS on Shield, and it worked untill I scrolled to gameboy, at which point it just exited to the launcher. The theme didn't load at all & no error messages. It did the same when I scrolled up to Colecovision. I tried to scroll fast past it but no go. All the Nintendo console main menu themes were fine but closed as soon as I selected one. I changed the Hyperspin directory to !Hyperspin and started fresh with hyperspin 1.3. I'll slowly add some files in to narrow down the cause. I added Atari 2600, atari 7800, atari jaguar, colecovision, gameboy, gameboy color, & Nintendo DS. I am using the database files & system/menu themes downloaded from hypersync. Atari jaguar had no themes so I downloaded the main menu theme from hyperspin downloads. Everything works fine. No jaguar system theme, but it still opens to the gamelist on top of a black background. Next I copied over any main menu videos which were missing, and atari 7800 wheel art, a different Mame wheelart, and the jaguar wheel art pulled from main menu zip. I did not do anything else. Now, everything is working so far in HS android except jaguar which exits when I go to enter to the system theme. I will try removing the main menu wheel art, but I figure if that was it, then it would exit as soon as the wheel art showed up on screen. I'll post back as I narrow it down. Sent from my HTC6525LVW using Tapatalk [sIGPIC][/sIGPIC]
BiZzAr721 Posted June 11, 2015 Author Posted June 11, 2015 Quick update - removed jaguar wheel, video & theme from main menu and still crashes I installed aLogcat if you think that may help. [sIGPIC][/sIGPIC]
reznnate Posted June 11, 2015 Posted June 11, 2015 I've been creating various sized installs for 64GB sd cards, 128GB sd cards, etc. I've been running into similar issues and they are almost always related to missing files or TYPOS. The game boy systems are the worst... gameboy... game boy... Nintendo game boy. The settings file won't match the menu entry or won't match the dbase folder or dbase.xml file. If you see the special.swf and pointer.png images stuck in the top left corner, you're missing a <game system>.ini file. Another difference from PC is that you'll want a transition video in /media/frontend/video/transitions/. PC version works fine without but if you have Animated_Artworks=true, it may crash without one. I suggest focus on a single wheel at a time. Edit the main menu.xml to narrow your focus. You can use <!-- comment --> to temporarily remove them from the list. Confirm the dbase.xml is valid, then settings .ini file, then your media. The last thing that can cause unexpected behavior is filters in the games .ini (roms, theme, etc.)
BiZzAr721 Posted June 11, 2015 Author Posted June 11, 2015 I'll try when I get home this evening. By the way, I added the additional systems using hyper hq, and downloaded the database through hyper sync. I haven't put in your system.ini's. I plan on going one by one to carefully check naming all matches up. Sent from my HTC6525LVW using Tapatalk [sIGPIC][/sIGPIC]
BiZzAr721 Posted June 12, 2015 Author Posted June 12, 2015 So I got Atari Jaguar to stop crashing. I was going through checking the naming and sure enough my database folder was empty. Somehow it got erased. Must have been from hypersync somehow. Anyhow, all main menu themes & videos and system themes are working. Now I'll go through system by system & complete it piece by piece, starting with my databases. I think I also had trasitions off except for system specifics such as the cds dropping for sega CD & bricks smashing for NES. I'll report any finding back here. [sIGPIC][/sIGPIC]
BiZzAr721 Posted June 14, 2015 Author Posted June 14, 2015 So after thouroughly goinging through everything it seems it may have been something to do with transistion videos. I have everything up and running, except I did not carry over any config files. Having HS on the Shield console is awesome. Thank you reznnate [sIGPIC][/sIGPIC]
reznnate Posted June 14, 2015 Posted June 14, 2015 Have you tested with the new 'animated backgrounds' feature that can be used to disable transitions? Might have fixed it. Sent from my iPhone using Tapatalk
BiZzAr721 Posted June 14, 2015 Author Posted June 14, 2015 Not yet but I'll try that when I get home. [sIGPIC][/sIGPIC]
BiZzAr721 Posted June 17, 2015 Author Posted June 17, 2015 I haven't tested the new "animated backgrounds" feature yet, took a couple nights off HS. Still having some minor issues with SNES. I have a DB with Japanese translated games and for some reason the sytem theme stops at "Dragon Ball Z - Super Saiya Densetsu", then rolls back around to the beginning. It shows all on the PC. I am posting my database if anyone is interested in giving it a try. I am fine just using the official xml & dropping the Jap translated. I am more concerned with if it is something that can help improve the development of HS android. <menu> <game name="2020 Super Baseball (USA)" index="true" image="2"> <description>2020 Super Baseball (USA)</description> <cloneof /> <crc>0d77933e</crc> <manufacturer>SNK</manufacturer> <year>1993</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="3 Ninjas Kick Back (USA)" index="true" image="3"> <description>3 Ninjas Kick Back (USA)</description> <cloneof /> <crc>f2ee11f9</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="7th Saga, The (USA)" index="true" image="7"> <description>7th Saga, The (USA)</description> <cloneof /> <crc>b3abdde6</crc> <manufacturer>Enix America Inc.</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="90 Minutes - European Prime Goal (Europe)" index="true" image="9"> <description>90 Minutes - European Prime Goal (Europe)</description> <cloneof /> <crc>1ad61bd0</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="A.S.P. - Air Strike Patrol (USA)" index="true" image="a"> <description>A.S.P. - Air Strike Patrol (USA)</description> <cloneof /> <crc>05c0da54</crc> <manufacturer>Seta Corporation</manufacturer> <year>1994</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aaahh!!! Real Monsters (USA)" index="" image=""> <description>Aaahh!!! Real Monsters (USA)</description> <cloneof /> <crc>27ff5ba1</crc> <manufacturer>Viacom New Media</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ABC Monday Night Football (USA)" index="" image=""> <description>ABC Monday Night Football (USA)</description> <cloneof /> <crc>e0dc8ad7</crc> <manufacturer>Data East</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ACME Animation Factory (USA)" index="" image=""> <description>ACME Animation Factory (USA)</description> <cloneof /> <crc>0944a5c3</crc> <manufacturer>Sun Soft</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ActRaiser (USA)" index="" image=""> <description>ActRaiser (USA)</description> <cloneof /> <crc>eac3358d</crc> <manufacturer>Enix</manufacturer> <year>1991</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ActRaiser 2 (USA)" index="" image=""> <description>ActRaiser 2 (USA)</description> <cloneof /> <crc>4901f718</crc> <manufacturer>Enix</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Addams Family Values (USA)" index="" image=""> <description>Addams Family Values (USA)</description> <cloneof /> <crc>98b07db8</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Addams Family, The - Pugsley's Scavenger Hunt (USA)" index="" image=""> <description>Addams Family, The - Pugsley's Scavenger Hunt (USA)</description> <cloneof /> <crc>153a00a7</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Addams Family, The (USA)" index="" image=""> <description>Addams Family, The (USA)</description> <cloneof /> <crc>2e8034ab</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Adventures of Batman & Robin, The (USA)" index="" image=""> <description>Adventures of Batman & Robin, The (USA)</description> <cloneof /> <crc>b3ef81f5</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Adventures of Dr. Franken, The (USA)" index="" image=""> <description>Adventures of Dr. Franken, The (USA)</description> <cloneof /> <crc>cfab3bba</crc> <manufacturer>DTMC</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Adventures of Kid Kleets, The (USA)" index="" image=""> <description>Adventures of Kid Kleets, The (USA)</description> <cloneof /> <crc>1664ae48</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Adventures of Rocky and Bullwinkle and Friends, The (USA)" index="" image=""> <description>Adventures of Rocky and Bullwinkle and Friends, The (USA)</description> <cloneof /> <crc>dc8f5734</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Adventures of Yogi Bear (USA)" index="" image=""> <description>Adventures of Yogi Bear (USA)</description> <cloneof /> <crc>7448d45c</crc> <manufacturer>Cybersoft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aero Fighters (USA)" index="" image=""> <description>Aero Fighters (USA)</description> <cloneof /> <crc>f194d00a</crc> <manufacturer>Mc O'River</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aero the Acro-Bat (USA)" index="" image=""> <description>Aero the Acro-Bat (USA)</description> <cloneof /> <crc>919f23cb</crc> <manufacturer>Sun Soft</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aero the Acro-Bat 2 (USA)" index="" image=""> <description>Aero the Acro-Bat 2 (USA)</description> <cloneof /> <crc>8c05ed51</crc> <manufacturer>Sun Soft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aerobiz (USA)" index="" image=""> <description>Aerobiz (USA)</description> <cloneof /> <crc>54302a46</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aerobiz Supersonic (USA)" index="" image=""> <description>Aerobiz Supersonic (USA)</description> <cloneof /> <crc>efafab12</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Air Cavalry (USA)" index="" image=""> <description>Air Cavalry (USA)</description> <cloneof /> <crc>6b452801</crc> <manufacturer>Cybersoft</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Al Unser Jr.'s Road to the Top (USA)" index="" image=""> <description>Al Unser Jr.'s Road to the Top (USA)</description> <cloneof /> <crc>d0550624</crc> <manufacturer>Software Toolworks</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Aladdin (USA)" index="" image=""> <description>Aladdin (USA)</description> <cloneof /> <crc>124d8e4d</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Alcahest (Japan - Translated)" index="" image=""> <description>Alcahest (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Squaresoft</manufacturer> <year>1993</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Alien 3 (USA)" index="" image=""> <description>Alien 3 (USA)</description> <cloneof /> <crc>98e2ac15</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Alien vs. Predator (USA)" index="" image=""> <description>Alien vs. Predator (USA)</description> <cloneof /> <crc>1803cf20</crc> <manufacturer>Activision</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="American Gladiators (USA)" index="" image=""> <description>American Gladiators (USA)</description> <cloneof /> <crc>76b151fd</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="American Tail, An - Fievel Goes West (USA)" index="" image=""> <description>American Tail, An - Fievel Goes West (USA)</description> <cloneof /> <crc>eea38aed</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Andre Agassi Tennis (USA)" index="" image=""> <description>Andre Agassi Tennis (USA)</description> <cloneof /> <crc>d1ae87be</crc> <manufacturer>TecMagik</manufacturer> <year>1994</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Animaniacs (USA)" index="" image=""> <description>Animaniacs (USA)</description> <cloneof /> <crc>cf0f14d2</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Arcade's Greatest Hits - The Atari Collection 1 (USA)" index="" image=""> <description>Arcade's Greatest Hits - The Atari Collection 1 (USA)</description> <cloneof /> <crc>02394f36</crc> <manufacturer>Midway</manufacturer> <year>1997</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Arcade's Greatest Hits (USA)" index="" image=""> <description>Arcade's Greatest Hits (USA)</description> <cloneof /> <crc>471b12b0</crc> <manufacturer>Midway</manufacturer> <year>1996</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Arcana (USA)" index="" image=""> <description>Arcana (USA)</description> <cloneof /> <crc>c891b297</crc> <manufacturer>Hal</manufacturer> <year>1992</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Archer Maclean's Super Dropzone (Europe)" index="" image=""> <description>Archer Maclean's Super Dropzone (Europe)</description> <cloneof /> <crc>e1ccce49</crc> <manufacturer>Psygnosis</manufacturer> <year>1995</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ardy Lightfoot (USA)" index="" image=""> <description>Ardy Lightfoot (USA)</description> <cloneof /> <crc>51a5f489</crc> <manufacturer>Titus Software</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Arkanoid - Doh It Again (USA)" index="" image=""> <description>Arkanoid - Doh It Again (USA)</description> <cloneof /> <crc>b50503a0</crc> <manufacturer>Nintendo</manufacturer> <year>1997</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Art of Fighting (USA)" index="" image=""> <description>Art of Fighting (USA)</description> <cloneof /> <crc>9fa74067</crc> <manufacturer>SNK</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Asterix & Obelix (Europe)" index="" image=""> <description>Asterix & Obelix (Europe)</description> <cloneof /> <crc>83af6152</crc> <manufacturer>Infogrames</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Asterix (Europe)" index="" image=""> <description>Asterix (Europe)</description> <cloneof /> <crc>5ddedc28</crc> <manufacturer>Infogrames</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Axelay (USA)" index="" image=""> <description>Axelay (USA)</description> <cloneof /> <crc>f812b533</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="B.O.B. (USA)" index="true" image="b"> <description>B.O.B. (USA)</description> <cloneof /> <crc>4f593c46</crc> <manufacturer>Electronic Arts</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bahamut Lagoon (Japan - Translated)" index="true" image="b"> <description>Bahamut Lagoon (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Squaresoft</manufacturer> <year>1993</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ballz 3D - Fighting at Its Ballziest (USA)" index="" image=""> <description>Ballz 3D - Fighting at Its Ballziest (USA)</description> <cloneof /> <crc>1c058b7d</crc> <manufacturer>Accolade</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Barbie Super Model (USA)" index="" image=""> <description>Barbie Super Model (USA)</description> <cloneof /> <crc>3b73610e</crc> <manufacturer>Hi-Tech</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Barbie Vacation Adventure (USA) (Proto)" index="" image=""> <description>Barbie Vacation Adventure (USA) (Proto)</description> <cloneof /> <crc>8ce1ba79</crc> <manufacturer>High Tech</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Barkley Shut Up and Jam! (USA)" index="" image=""> <description>Barkley Shut Up and Jam! (USA)</description> <cloneof /> <crc>726b6c5a</crc> <manufacturer>Accolade</manufacturer> <year>1994</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="BASS Masters Classic - Pro Edition (USA)" index="" image=""> <description>BASS Masters Classic - Pro Edition (USA)</description> <cloneof /> <crc>c5058634</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="BASS Masters Classic (USA)" index="" image=""> <description>BASS Masters Classic (USA)</description> <cloneof /> <crc>832a27c2</crc> <manufacturer>Malibu</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bassin's Black Bass (USA)" index="" image=""> <description>Bassin's Black Bass (USA)</description> <cloneof /> <crc>7dc5b7b3</crc> <manufacturer>Hot-B</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Batman Forever (USA)" index="" image=""> <description>Batman Forever (USA)</description> <cloneof /> <crc>d9b5e9cf</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Batman Returns (USA)" index="" image=""> <description>Batman Returns (USA)</description> <cloneof /> <crc>e87dfdf6</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battle Blaze (USA)" index="" image=""> <description>Battle Blaze (USA)</description> <cloneof /> <crc>d933bd8d</crc> <manufacturer>Sammy Studios</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battle Cars (USA)" index="" image=""> <description>Battle Cars (USA)</description> <cloneof /> <crc>46043454</crc> <manufacturer>Namco</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battle Clash (USA)" index="" image=""> <description>Battle Clash (USA)</description> <cloneof /> <crc>59c00310</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battle Grand Prix (USA)" index="" image=""> <description>Battle Grand Prix (USA)</description> <cloneof /> <crc>190ff436</crc> <manufacturer>Hudson Soft</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battletoads & Double Dragon (USA)" index="" image=""> <description>Battletoads & Double Dragon (USA)</description> <cloneof /> <crc>8b18ac01</crc> <manufacturer>Tradewest</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Battletoads in Battlemaniacs (USA)" index="" image=""> <description>Battletoads in Battlemaniacs (USA)</description> <cloneof /> <crc>617ac925</crc> <manufacturer>Tradewest</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bazooka Blitzkrieg (USA)" index="" image=""> <description>Bazooka Blitzkrieg (USA)</description> <cloneof /> <crc>49c187f3</crc> <manufacturer>Bandai</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Beauty and the Beast (USA)" index="" image=""> <description>Beauty and the Beast (USA)</description> <cloneof /> <crc>956e183c</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Beavis and Butt-Head (USA)" index="" image=""> <description>Beavis and Butt-Head (USA)</description> <cloneof /> <crc>15cf4bd5</crc> <manufacturer>Viacom New Media</manufacturer> <year>1994</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bebe's Kids (USA)" index="" image=""> <description>Bebe's Kids (USA)</description> <cloneof /> <crc>bda2e412</crc> <manufacturer>Motown Games</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Beethoven - The Ultimate Canine Caper! (USA)" index="" image=""> <description>Beethoven - The Ultimate Canine Caper! (USA)</description> <cloneof /> <crc>beebafa2</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Best of the Best - Championship Karate (USA)" index="" image=""> <description>Best of the Best - Championship Karate (USA)</description> <cloneof /> <crc>7f6ed86e</crc> <manufacturer>Electro Brain</manufacturer> <year>1992</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Big Sky Trooper (USA)" index="" image=""> <description>Big Sky Trooper (USA)</description> <cloneof /> <crc>25c69316</crc> <manufacturer>JVC Musical Industries, Inc.</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Biker Mice from Mars (USA)" index="" image=""> <description>Biker Mice from Mars (USA)</description> <cloneof /> <crc>4e8b2ecb</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bill Laimbeer's Combat Basketball (USA)" index="" image=""> <description>Bill Laimbeer's Combat Basketball (USA)</description> <cloneof /> <crc>468d8cdd</crc> <manufacturer>Hudson Soft</manufacturer> <year>1991</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bill Walsh College Football (USA)" index="" image=""> <description>Bill Walsh College Football (USA)</description> <cloneof /> <crc>25391c9f</crc> <manufacturer>EA Sports</manufacturer> <year>1994</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="BioMetal (USA)" index="" image=""> <description>BioMetal (USA)</description> <cloneof /> <crc>53d8410e</crc> <manufacturer>Activision</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bishoujo Senshi Sailor Moon - Another Story (Japan - Translated)" index="" image=""> <description>Bishoujo Senshi Sailor Moon - Another Story (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Angel</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Blackthorne (USA)" index="" image=""> <description>Blackthorne (USA)</description> <cloneof /> <crc>856beab1</crc> <manufacturer>Interplay</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="BlaZeon - The Bio-Cyborg Challenge (USA)" index="" image=""> <description>BlaZeon - The Bio-Cyborg Challenge (USA)</description> <cloneof /> <crc>3b01d0a3</crc> <manufacturer>Atlus</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Blues Brothers, The (USA)" index="" image=""> <description>Blues Brothers, The (USA)</description> <cloneof /> <crc>82b97464</crc> <manufacturer>Titus Software</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bobby's World (USA) (Proto)" index="" image=""> <description>Bobby's World (USA) (Proto)</description> <cloneof /> <crc>18bbee33</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bonkers (USA)" index="" image=""> <description>Bonkers (USA)</description> <cloneof /> <crc>597aa981</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Boogerman - A Pick and Flick Adventure (USA)" index="" image=""> <description>Boogerman - A Pick and Flick Adventure (USA)</description> <cloneof /> <crc>1899aaff</crc> <manufacturer>Interplay</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Boxing Legends of the Ring (USA)" index="" image=""> <description>Boxing Legends of the Ring (USA)</description> <cloneof /> <crc>c0b632c0</crc> <manufacturer>Electro Brain</manufacturer> <year>1993</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brain Lord (USA)" index="" image=""> <description>Brain Lord (USA)</description> <cloneof /> <crc>ac443d87</crc> <manufacturer>Enix</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brainies, The (USA)" index="" image=""> <description>Brainies, The (USA)</description> <cloneof /> <crc>718cb0df</crc> <manufacturer>Titus Software</manufacturer> <year>1996</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bram Stoker's Dracula (USA)" index="" image=""> <description>Bram Stoker's Dracula (USA)</description> <cloneof /> <crc>5cece690</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brandish (USA)" index="" image=""> <description>Brandish (USA)</description> <cloneof /> <crc>74f70a0b</crc> <manufacturer>Koei</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brawl Brothers (USA)" index="" image=""> <description>Brawl Brothers (USA)</description> <cloneof /> <crc>e822065c</crc> <manufacturer>Jaleco</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="BreakThru! (USA)" index="" image=""> <description>BreakThru! (USA)</description> <cloneof /> <crc>e6c0b5da</crc> <manufacturer>Spectrum Holobyte</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Breath of Fire (USA)" index="" image=""> <description>Breath of Fire (USA)</description> <cloneof /> <crc>c788b696</crc> <manufacturer>SquareSoft</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Breath of Fire II (USA)" index="" image=""> <description>Breath of Fire II (USA)</description> <cloneof /> <crc>67cdacc5</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brett Hull Hockey (USA)" index="" image=""> <description>Brett Hull Hockey (USA)</description> <cloneof /> <crc>fbe35998</crc> <manufacturer>Accolade</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brett Hull Hockey '95 (USA)" index="" image=""> <description>Brett Hull Hockey '95 (USA)</description> <cloneof /> <crc>9ebfe809</crc> <manufacturer>Accolade</manufacturer> <year>1995</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bronkie the Bronchiasaurus (USA)" index="" image=""> <description>Bronkie the Bronchiasaurus (USA)</description> <cloneof /> <crc>1200f3cf</crc> <manufacturer>Raya Systems</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brunswick World Tournament of Champions (USA)" index="" image=""> <description>Brunswick World Tournament of Champions (USA)</description> <cloneof /> <crc>52e4dc92</crc> <manufacturer>Black Pearl</manufacturer> <year>1997</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Brutal - Paws of Fury (USA)" index="" image=""> <description>Brutal - Paws of Fury (USA)</description> <cloneof /> <crc>8fe49f80</crc> <manufacturer>Cybersoft</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bubsy II (USA)" index="" image=""> <description>Bubsy II (USA)</description> <cloneof /> <crc>d0d172fa</crc> <manufacturer>Accolade</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bubsy in Claws Encounters of the Furred Kind (USA)" index="" image=""> <description>Bubsy in Claws Encounters of the Furred Kind (USA)</description> <cloneof /> <crc>444a52c1</crc> <manufacturer>Accolade</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bugs Bunny - Rabbit Rampage (USA)" index="" image=""> <description>Bugs Bunny - Rabbit Rampage (USA)</description> <cloneof /> <crc>832c0cb6</crc> <manufacturer>SunSoft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bulls vs Blazers and the NBA Playoffs (USA) (Rev 1)" index="" image=""> <description>Bulls vs Blazers and the NBA Playoffs (USA) (Rev 1)</description> <cloneof /> <crc>c2e91694</crc> <manufacturer>EA Sports</manufacturer> <year>1992</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Bust-A-Move (USA)" index="" image=""> <description>Bust-A-Move (USA)</description> <cloneof /> <crc>3266fd23</crc> <manufacturer>Taito</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cacoma Knight in Bizyland (USA)" index="true" image="c"> <description>Cacoma Knight in Bizyland (USA)</description> <cloneof /> <crc>ba921443</crc> <manufacturer>Seta Corporation</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cal Ripken Jr. Baseball (USA)" index="" image=""> <description>Cal Ripken Jr. Baseball (USA)</description> <cloneof /> <crc>ce2eaa41</crc> <manufacturer>Mindscape</manufacturer> <year>1992</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="California Games II (USA)" index="" image=""> <description>California Games II (USA)</description> <cloneof /> <crc>21392b00</crc> <manufacturer>DTMC</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cannon Fodder (Europe)" index="" image=""> <description>Cannon Fodder (Europe)</description> <cloneof /> <crc>f3b5cbb1</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cannondale Cup (USA)" index="" image=""> <description>Cannondale Cup (USA)</description> <cloneof /> <crc>b95fe0a0</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Capcom's MVP Football (USA)" index="" image=""> <description>Capcom's MVP Football (USA)</description> <cloneof /> <crc>bd0a0c0e</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Capcom's Soccer Shootout (USA)" index="" image=""> <description>Capcom's Soccer Shootout (USA)</description> <cloneof /> <crc>ee314ae5</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Captain America and the Avengers (USA)" index="" image=""> <description>Captain America and the Avengers (USA)</description> <cloneof /> <crc>456ab5c8</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Captain Commando (USA)" index="" image=""> <description>Captain Commando (USA)</description> <cloneof /> <crc>81db73c7</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Captain Novolin (USA)" index="" image=""> <description>Captain Novolin (USA)</description> <cloneof /> <crc>9fd460a4</crc> <manufacturer>Raya Systems</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Carrier Aces (USA)" index="" image=""> <description>Carrier Aces (USA)</description> <cloneof /> <crc>8bc5b8de</crc> <manufacturer>Cybersoft</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Casper (USA)" index="" image=""> <description>Casper (USA)</description> <cloneof /> <crc>a3b745bc</crc> <manufacturer>Natsume</manufacturer> <year>1996</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Castlevania - Dracula X (USA)" index="" image=""> <description>Castlevania - Dracula X (USA)</description> <cloneof /> <crc>7c4887e1</crc> <manufacturer>Konami</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Champions - World Class Soccer (USA)" index="" image=""> <description>Champions - World Class Soccer (USA)</description> <cloneof /> <crc>bcd59d08</crc> <manufacturer>Flying Edge</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Championship Pool (USA)" index="" image=""> <description>Championship Pool (USA)</description> <cloneof /> <crc>98ef8414</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Sports/Pool and Dart</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Championship Soccer '94 (USA)" index="" image=""> <description>Championship Soccer '94 (USA)</description> <cloneof /> <crc>6b953095</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chavez (USA)" index="" image=""> <description>Chavez (USA)</description> <cloneof /> <crc>a9d604ea</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chavez II (USA)" index="" image=""> <description>Chavez II (USA)</description> <cloneof /> <crc>86981887</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chessmaster, The (USA)" index="" image=""> <description>Chessmaster, The (USA)</description> <cloneof /> <crc>bc671e15</crc> <manufacturer>Mindscape</manufacturer> <year>1991</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chester Cheetah - Too Cool to Fool (USA)" index="" image=""> <description>Chester Cheetah - Too Cool to Fool (USA)</description> <cloneof /> <crc>552bf16a</crc> <manufacturer>Kaneko</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chester Cheetah - Wild Wild Quest (USA)" index="" image=""> <description>Chester Cheetah - Wild Wild Quest (USA)</description> <cloneof /> <crc>557fe962</crc> <manufacturer>Kaneko</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Choplifter III - Rescue & Survive (USA)" index="" image=""> <description>Choplifter III - Rescue & Survive (USA)</description> <cloneof /> <crc>1d2eae52</crc> <manufacturer>Victor Interactive Software</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chrono Trigger (USA)" index="" image=""> <description>Chrono Trigger (USA)</description> <cloneof /> <crc>2d206bf7</crc> <manufacturer>Squaresoft</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Chuck Rock (USA)" index="" image=""> <description>Chuck Rock (USA)</description> <cloneof /> <crc>e237ec45</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Civilization (USA)" index="" image=""> <description>Civilization (USA)</description> <cloneof /> <crc>41fdba82</crc> <manufacturer>Microprose</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Clay Fighter - Tournament Edition (USA)" index="" image=""> <description>Clay Fighter - Tournament Edition (USA)</description> <cloneof /> <crc>b360f7af</crc> <manufacturer>Interplay</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Clay Fighter (USA)" index="" image=""> <description>Clay Fighter (USA)</description> <cloneof /> <crc>c814e3c2</crc> <manufacturer>Interplay</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Clay Fighter 2 - Judgment Clay (USA)" index="" image=""> <description>Clay Fighter 2 - Judgment Clay (USA)</description> <cloneof /> <crc>20b5c364</crc> <manufacturer>Interplay</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Claymates (USA)" index="" image=""> <description>Claymates (USA)</description> <cloneof /> <crc>7ad5ccac</crc> <manufacturer>Interplay</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cliffhanger (USA)" index="" image=""> <description>Cliffhanger (USA)</description> <cloneof /> <crc>12f8a26c</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Clock Tower (Japan - Translated)" index="" image=""> <description>Clock Tower (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Human Entertainment</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Clue (USA)" index="" image=""> <description>Clue (USA)</description> <cloneof /> <crc>a4fbe827</crc> <manufacturer>Parker Bros.</manufacturer> <year>1992</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="College Football USA '97 - The Road to New Orleans (USA)" index="" image=""> <description>College Football USA '97 - The Road to New Orleans (USA)</description> <cloneof /> <crc>a27940c1</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="College Slam (USA)" index="" image=""> <description>College Slam (USA)</description> <cloneof /> <crc>ce842c6d</crc> <manufacturer>Acclaim</manufacturer> <year>1996</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Combatribes, The (USA)" index="" image=""> <description>Combatribes, The (USA)</description> <cloneof /> <crc>9304044a</crc> <manufacturer>Technos</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Congo's Caper (USA)" index="" image=""> <description>Congo's Caper (USA)</description> <cloneof /> <crc>8a24fba8</crc> <manufacturer>Data East</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Contra III - The Alien Wars (USA)" index="" image=""> <description>Contra III - The Alien Wars (USA)</description> <cloneof /> <crc>84da7cfe</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cool Spot (USA)" index="" image=""> <description>Cool Spot (USA)</description> <cloneof /> <crc>44e60e58</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cool World (USA)" index="" image=""> <description>Cool World (USA)</description> <cloneof /> <crc>0730c37c</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cutthroat Island (USA)" index="" image=""> <description>Cutthroat Island (USA)</description> <cloneof /> <crc>19ea457b</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cyber Knight (Japan - Translated)" index="" image=""> <description>Cyber Knight (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Tonkin House</manufacturer> <year>1991</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cyber Knight 2 - Tikyu Teikoku no Yabou (Japan - Translated)" index="" image=""> <description>Cyber Knight 2 - Tikyu Teikoku no Yabou (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Tonkin House</manufacturer> <year>1994</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cyber Spin (USA)" index="" image=""> <description>Cyber Spin (USA)</description> <cloneof /> <crc>44018650</crc> <manufacturer>Takara</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cybernator (USA)" index="" image=""> <description>Cybernator (USA)</description> <cloneof /> <crc>4dfa05b3</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Cyborg 009 (Japan - Translated)" index="" image=""> <description>Cyborg 009 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Interbec</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Daffy Duck - The Marvin Missions (USA)" index="" image=""> <description>Daffy Duck - The Marvin Missions (USA)</description> <cloneof /> <crc>5f02a044</crc> <manufacturer>Sun Soft</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Darius Twin (USA)" index="" image=""> <description>Darius Twin (USA)</description> <cloneof /> <crc>c5341764</crc> <manufacturer>Taito</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dark Half (Japan - Translated)" index="" image=""> <description>Dark Half (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Enix</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dark Law - Meaning of Death (Japan - Translated)" index="" image=""> <description>Dark Law - Meaning of Death (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>ASCII Corporation</manufacturer> <year>1997</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="David Crane's Amazing Tennis (USA)" index="" image=""> <description>David Crane's Amazing Tennis (USA)</description> <cloneof /> <crc>caad18dc</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1992</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Daze Before Christmas (Europe)" index="" image=""> <description>Daze Before Christmas (Europe)</description> <cloneof /> <crc>59909eb5</crc> <manufacturer>SunSoft</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Death and Return of Superman, The (USA)" index="" image=""> <description>Death and Return of Superman, The (USA)</description> <cloneof /> <crc>a567957c</crc> <manufacturer>Sun Soft</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Demolition Man (USA)" index="" image=""> <description>Demolition Man (USA)</description> <cloneof /> <crc>8afe2f91</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Demon's Crest (USA)" index="" image=""> <description>Demon's Crest (USA)</description> <cloneof /> <crc>e8236ad2</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dennis the Menace (USA)" index="" image=""> <description>Dennis the Menace (USA)</description> <cloneof /> <crc>8ee7faa5</crc> <manufacturer>Ocean</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Der Langrisser (Japan - Translated)" index="" image=""> <description>Der Langrisser (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Masaya/NCS Corp</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Desert Strike - Return to the Gulf (USA)" index="" image=""> <description>Desert Strike - Return to the Gulf (USA)</description> <cloneof /> <crc>4ce26787</crc> <manufacturer>Electronic Arts</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dezaemon - Kaite Tsukutte Asoberu (Japan - Translated)" index="" image=""> <description>Dezaemon - Kaite Tsukutte Asoberu (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Athena</manufacturer> <year>1994</year> <genre>Shooting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="D-Force (USA)" index="true" image="d"> <description>D-Force (USA)</description> <cloneof /> <crc>24230807</crc> <manufacturer>Asmik Corporation of America</manufacturer> <year>1991</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dig & Spike Volleyball (USA)" index="" image=""> <description>Dig & Spike Volleyball (USA)</description> <cloneof /> <crc>954340f8</crc> <manufacturer>Hudson</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dino City (USA)" index="" image=""> <description>Dino City (USA)</description> <cloneof /> <crc>94152717</crc> <manufacturer>Irem</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dino Dini's Soccer! (Europe)" index="" image=""> <description>Dino Dini's Soccer! (Europe)</description> <cloneof /> <crc>dbf4a8ab</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dirt Racer (Europe)" index="" image=""> <description>Dirt Racer (Europe)</description> <cloneof /> <crc>0354f4b1</crc> <manufacturer>Elite Systems Ltd.</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dirt Trax FX (USA)" index="" image=""> <description>Dirt Trax FX (USA)</description> <cloneof /> <crc>61a86c7f</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Donkey Kong Country (USA) (Competition Edition)" index="" image=""> <description>Donkey Kong Country (USA) (Competition Edition)</description> <cloneof /> <crc>0e204fbd</crc> <manufacturer>Rare</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Donkey Kong Country (USA) (Rev 2)" index="" image=""> <description>Donkey Kong Country (USA) (Rev 2)</description> <cloneof /> <crc>762af827</crc> <manufacturer>Rare</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Donkey Kong Country 2 - Diddy's Kong Quest (USA) (Rev 1)" index="" image=""> <description>Donkey Kong Country 2 - Diddy's Kong Quest (USA) (Rev 1)</description> <cloneof /> <crc>4e2d90f4</crc> <manufacturer>Rare</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Donkey Kong Country 3 - Dixie Kong's Double Trouble! (USA)" index="" image=""> <description>Donkey Kong Country 3 - Dixie Kong's Double Trouble! (USA)</description> <cloneof /> <crc>448eec19</crc> <manufacturer>Rare</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Doom (USA)" index="" image=""> <description>Doom (USA)</description> <cloneof /> <crc>09e85ea6</crc> <manufacturer>Williams</manufacturer> <year>1996</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Doom Troopers (USA)" index="" image=""> <description>Doom Troopers (USA)</description> <cloneof /> <crc>1889feef</crc> <manufacturer>Playmates</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Doomsday Warrior (USA)" index="" image=""> <description>Doomsday Warrior (USA)</description> <cloneof /> <crc>ceeb7c32</crc> <manufacturer>Renovation</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Doraemon 4 - Nobita to Tsuki no Oukoku (Japan - Translated)" index="" image=""> <description>Doraemon 4 - Nobita to Tsuki no Oukoku (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Agenda / Epoch</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Do-Re-Mi Fantasy - Milon no Dokidoki Daibouken (Japan - Translated)" index="" image=""> <description>Do-Re-Mi Fantasy - Milon no Dokidoki Daibouken (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Hudson Soft</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Double Dragon V - The Shadow Falls (USA)" index="" image=""> <description>Double Dragon V - The Shadow Falls (USA)</description> <cloneof /> <crc>98a96ae8</crc> <manufacturer>Tradewest</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon - The Bruce Lee Story (USA)" index="" image=""> <description>Dragon - The Bruce Lee Story (USA)</description> <cloneof /> <crc>407c5c24</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Ball Z - Hyper Dimension (Japan - Translated)" index="" image=""> <description>Dragon Ball Z - Hyper Dimension (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>BanDai</manufacturer> <year>1996</year> <genre>Fighting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Ball Z - Super Saiya Densetsu (Japan - Translated)" index="" image=""> <description>Dragon Ball Z - Super Saiya Densetsu (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>TOSE / Bandai</manufacturer> <year>1992</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Quest I & II (Japan - Translated)" index="" image=""> <description>Dragon Quest I & II (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>ChunSoft / Enix America</manufacturer> <year>1993</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Quest III (Japan - Translated)" index="" image=""> <description>Dragon Quest III (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Heart Beat / Enix America</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Quest V - Tenkuu no Hanayome (Japan - Translated)" index="" image=""> <description>Dragon Quest V - Tenkuu no Hanayome (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>ChunSoft / Enix America</manufacturer> <year>1992</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon Quest VI - Maboroshi no Daichi (Japan - Translated)" index="" image=""> <description>Dragon Quest VI - Maboroshi no Daichi (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Heart Beat / Enix America</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon View (USA)" index="" image=""> <description>Dragon View (USA)</description> <cloneof /> <crc>ab893412</crc> <manufacturer>Kemco</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dragon's Lair (USA)" index="" image=""> <description>Dragon's Lair (USA)</description> <cloneof /> <crc>24ffe7fd</crc> <manufacturer>Data East</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Drakkhen (USA)" index="" image=""> <description>Drakkhen (USA)</description> <cloneof /> <crc>7dae5c2a</crc> <manufacturer>Infogrames</manufacturer> <year>1991</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dream TV (USA)" index="" image=""> <description>Dream TV (USA)</description> <cloneof /> <crc>ab5a9e40</crc> <manufacturer>Triffix</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dual Orb II (Japan - Translated)" index="" image=""> <description>Dual Orb II (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>I'Max</manufacturer> <year>1994</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Duel, The - Test Drive II (USA)" index="" image=""> <description>Duel, The - Test Drive II (USA)</description> <cloneof /> <crc>ba093e24</crc> <manufacturer>Ballistic</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Dungeon Master (USA)" index="" image=""> <description>Dungeon Master (USA)</description> <cloneof /> <crc>0dfd9ceb</crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="E.V.O. - Search for Eden (USA)" index="true" image="e"> <description>E.V.O. - Search for Eden (USA)</description> <cloneof /> <crc>dd49911e</crc> <manufacturer>Enix</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Earth Defense Force (USA)" index="" image=""> <description>Earth Defense Force (USA)</description> <cloneof /> <crc>ca8ff946</crc> <manufacturer>Jaleco</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="EarthBound (USA)" index="" image=""> <description>EarthBound (USA)</description> <cloneof /> <crc>dc9bb451</crc> <manufacturer>Nintendo</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Earthworm Jim (USA)" index="" image=""> <description>Earthworm Jim (USA)</description> <cloneof /> <crc>3a4a47eb</crc> <manufacturer>Playmates</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Earthworm Jim 2 (USA)" index="" image=""> <description>Earthworm Jim 2 (USA)</description> <cloneof /> <crc>393de197</crc> <manufacturer>Playmates</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Eek! The Cat (USA)" index="" image=""> <description>Eek! The Cat (USA)</description> <cloneof /> <crc>216f2fc7</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Elite Soccer (USA)" index="" image=""> <description>Elite Soccer (USA)</description> <cloneof /> <crc>62abaee1</crc> <manufacturer>GameTek</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Emmitt Smith Football (USA)" index="" image=""> <description>Emmitt Smith Football (USA)</description> <cloneof /> <crc>09c3c0ef</crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1995</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Equinox (USA)" index="" image=""> <description>Equinox (USA)</description> <cloneof /> <crc>96a4d1c0</crc> <manufacturer>Epic Sony Record</manufacturer> <year>1993</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ESPN Baseball Tonight (USA)" index="" image=""> <description>ESPN Baseball Tonight (USA)</description> <cloneof /> <crc>8606d69b</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ESPN National Hockey Night (USA)" index="" image=""> <description>ESPN National Hockey Night (USA)</description> <cloneof /> <crc>75058ede</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ESPN Speedworld (USA)" index="" image=""> <description>ESPN Speedworld (USA)</description> <cloneof /> <crc>c2cff05a</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="ESPN Sunday Night NFL (USA)" index="" image=""> <description>ESPN Sunday Night NFL (USA)</description> <cloneof /> <crc>26849f90</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Exertainment Mountain Bike Rally & Speed Racer (USA)" index="" image=""> <description>Exertainment Mountain Bike Rally & Speed Racer (USA)</description> <cloneof /> <crc>ee5e1906</crc> <manufacturer>Life Fitness</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Exertainment Mountain Bike Rally (USA)" index="" image=""> <description>Exertainment Mountain Bike Rally (USA)</description> <cloneof /> <crc>e6ede101</crc> <manufacturer>Life Fitness</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Extra Innings (USA)" index="" image=""> <description>Extra Innings (USA)</description> <cloneof /> <crc>440a4250</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1992</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Eye of the Beholder (USA)" index="" image=""> <description>Eye of the Beholder (USA)</description> <cloneof /> <crc>20143571</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F1 Pole Position (USA)" index="" image=""> <description>F1 Pole Position (USA)</description> <cloneof /> <crc>b3da1b1d</crc> <manufacturer>Ubisoft</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F1 Pole Position 2 (Europe)" index="" image=""> <description>F1 Pole Position 2 (Europe)</description> <cloneof /> <crc>83fc0f0c</crc> <manufacturer>Ubisoft</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F1 ROC - Race of Champions (USA)" index="" image=""> <description>F1 ROC - Race of Champions (USA)</description> <cloneof /> <crc>2a069989</crc> <manufacturer>Seta Corporation</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F1 ROC II - Race of Champions (USA)" index="" image=""> <description>F1 ROC II - Race of Champions (USA)</description> <cloneof /> <crc>3447609e</crc> <manufacturer>Seta Corporation</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F1 World Championship Edition (Europe)" index="" image=""> <description>F1 World Championship Edition (Europe)</description> <cloneof /> <crc>7ba8fc78</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Faceball 2000 (USA)" index="" image=""> <description>Faceball 2000 (USA)</description> <cloneof /> <crc>8d4df815</crc> <manufacturer>Bullet Proof Software</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Family Dog (USA)" index="" image=""> <description>Family Dog (USA)</description> <cloneof /> <crc>1b53c15a</crc> <manufacturer>Malibu</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Family Feud (USA) (Rev 1)" index="" image=""> <description>Family Feud (USA) (Rev 1)</description> <cloneof /> <crc>0c664b71</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fatal Fury (USA)" index="" image=""> <description>Fatal Fury (USA)</description> <cloneof /> <crc>c67257d0</crc> <manufacturer>Takara</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fatal Fury 2 (USA)" index="" image=""> <description>Fatal Fury 2 (USA)</description> <cloneof /> <crc>a26ebfef</crc> <manufacturer>Takuyo</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fatal Fury Special (USA)" index="" image=""> <description>Fatal Fury Special (USA)</description> <cloneof /> <crc>93935bee</crc> <manufacturer>Takuyo</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Feda - The Emblem of Justice (Japan - Translated)" index="" image=""> <description>Feda - The Emblem of Justice (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Max Entertainment / Yanoman</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="FIFA 98 - Road to World Cup (Europe)" index="" image=""> <description>FIFA 98 - Road to World Cup (Europe)</description> <cloneof /> <crc>5e4f4856</crc> <manufacturer>EA Sports</manufacturer> <year>1998</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="FIFA International Soccer (USA)" index="" image=""> <description>FIFA International Soccer (USA)</description> <cloneof /> <crc>56296426</crc> <manufacturer>Victor Interactive Software</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="FIFA Soccer 96 (USA)" index="" image=""> <description>FIFA Soccer 96 (USA)</description> <cloneof /> <crc>7566347d</crc> <manufacturer>EA Sports</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="FIFA Soccer 97 - Gold Edition (USA)" index="" image=""> <description>FIFA Soccer 97 - Gold Edition (USA)</description> <cloneof /> <crc>9cdbb2f8</crc> <manufacturer>EA Sports</manufacturer> <year>1996</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fighter's History (USA) (Rev 1)" index="" image=""> <description>Fighter's History (USA) (Rev 1)</description> <cloneof /> <crc>3d17f6ea</crc> <manufacturer>Data East</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fantasy - Mystic Quest (USA) (Rev 1)" index="" image=""> <description>Final Fantasy - Mystic Quest (USA) (Rev 1)</description> <cloneof /> <crc>2c52c792</crc> <manufacturer>SquareSoft</manufacturer> <year>1992</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fantasy II (USA) (Rev 1)" index="" image=""> <description>Final Fantasy II (USA) (Rev 1)</description> <cloneof /> <crc>23084fcd</crc> <manufacturer>SquareSoft</manufacturer> <year>1991</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fantasy III (USA) (Rev 1)" index="" image=""> <description>Final Fantasy III (USA) (Rev 1)</description> <cloneof /> <crc>c0fa0464</crc> <manufacturer>SquareSoft</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fight (USA)" index="" image=""> <description>Final Fight (USA)</description> <cloneof /> <crc>4cab21db</crc> <manufacturer>Capcom</manufacturer> <year>1991</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fight 2 (USA)" index="" image=""> <description>Final Fight 2 (USA)</description> <cloneof /> <crc>8c37ff55</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fight 3 (USA)" index="" image=""> <description>Final Fight 3 (USA)</description> <cloneof /> <crc>a916e708</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Final Fight Guy (USA)" index="" image=""> <description>Final Fight Guy (USA)</description> <cloneof /> <crc>bc1ae3c2</crc> <manufacturer>Capcom</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fire Emblem - Monshou no Nazo (Japan - Translated)" index="" image=""> <description>Fire Emblem - Monshou no Nazo (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Intelligent Systems / Nintendo</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fire Emblem - Seisen no Keifu (Japan - Translated)" index="" image=""> <description>Fire Emblem - Seisen no Keifu (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Intelligent Systems / Nintendo</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fire Emblem - Thracia 776 (Japan - Translated)" index="" image=""> <description>Fire Emblem - Thracia 776 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Intelligent Systems / Nintendo</manufacturer> <year>1999</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fire Striker (USA)" index="" image=""> <description>Fire Striker (USA)</description> <cloneof /> <crc>e500c7ba</crc> <manufacturer>DTMC</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Firemen, The (Europe)" index="" image=""> <description>Firemen, The (Europe)</description> <cloneof /> <crc>def665af</crc> <manufacturer>Human Entertainment</manufacturer> <year>1994</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Firepower 2000 (USA)" index="" image=""> <description>Firepower 2000 (USA)</description> <cloneof /> <crc>327416d4</crc> <manufacturer>Sun Soft</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="First Samurai (USA)" index="" image=""> <description>First Samurai (USA)</description> <cloneof /> <crc>4f0a1e2a</crc> <manufacturer>Kemco</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Flashback - The Quest for Identity (USA)" index="" image=""> <description>Flashback - The Quest for Identity (USA)</description> <cloneof /> <crc>1e6aceba</crc> <manufacturer>U.S. Gold</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Flintstones, The - The Treasure of Sierra Madrock (USA)" index="" image=""> <description>Flintstones, The - The Treasure of Sierra Madrock (USA)</description> <cloneof /> <crc>594f5cc6</crc> <manufacturer>Taito</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Flintstones, The (USA)" index="" image=""> <description>Flintstones, The (USA)</description> <cloneof /> <crc>3e7b51e0</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Football Fury (USA)" index="" image=""> <description>Football Fury (USA)</description> <cloneof /> <crc>729a5524</crc> <manufacturer>American Sammy</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Foreman For Real (USA)" index="" image=""> <description>Foreman For Real (USA)</description> <cloneof /> <crc>5fa4d051</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Frank Thomas Big Hurt Baseball (USA)" index="" image=""> <description>Frank Thomas Big Hurt Baseball (USA)</description> <cloneof /> <crc>21239dda</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Frantic Flea (USA)" index="" image=""> <description>Frantic Flea (USA)</description> <cloneof /> <crc>ffa8d1ff</crc> <manufacturer>GameTek</manufacturer> <year>1996</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Frogger (USA)" index="" image=""> <description>Frogger (USA)</description> <cloneof /> <crc>2488b8f2</crc> <manufacturer>Majesco</manufacturer> <year>1998</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Front Mission - Gun Hazard (Japan - Translated)" index="" image=""> <description>Front Mission - Gun Hazard (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Omiya Soft / Square Enix</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Front Mission (Japan - Translated)" index="" image=""> <description>Front Mission (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>G-Craft / Square Enix</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Full Throttle - All-American Racing (USA)" index="" image=""> <description>Full Throttle - All-American Racing (USA)</description> <cloneof /> <crc>2a4a53ca</crc> <manufacturer>Cybersoft</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fun 'n Games (USA)" index="" image=""> <description>Fun 'n Games (USA)</description> <cloneof /> <crc>5d6deac7</crc> <manufacturer>Tradewest</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Fushigi no Dungeon 2 - Fuurai no Shiren (Japan - Translated)" index="true" image="g"> <description>Fushigi no Dungeon 2 - Fuurai no Shiren (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Chunsoft</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="F-Zero (USA)" index="true" image="f"> <description>F-Zero (USA)</description> <cloneof /> <crc>aa0e31de</crc> <manufacturer>Nintendo</manufacturer> <year>1991</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ganbare Goemon 2 (Japan)" index="true" image="g"> <description>Ganbare Goemon 2 (Japan)</description> <cloneof /> <crc /> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ganbare Goemon 3 (Japan)" index="true" image="g"> <description>Ganbare Goemon 3 (Japan)</description> <cloneof /> <crc /> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ganbare Goemon 4 (Japan)" index="true" image="g"> <description>Ganbare Goemon 4 (Japan)</description> <cloneof /> <crc /> <manufacturer>Konami</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ganpuru - Gunman's Proof (Japan - Translated)" index="true" image="g"> <description>Ganpuru - Gunman's Proof (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Lenar</manufacturer> <year>1997</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Gemfire (USA)" index="true" image="g"> <description>Gemfire (USA)</description> <cloneof /> <crc>ee801a54</crc> <manufacturer>Koei</manufacturer> <year>1992</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Genghis Khan II - Clan of the Gray Wolf (USA)" index="" image=""> <description>Genghis Khan II - Clan of the Gray Wolf (USA)</description> <cloneof /> <crc>d7875512</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="George Foreman's KO Boxing (USA) (Rev 1)" index="" image=""> <description>George Foreman's KO Boxing (USA) (Rev 1)</description> <cloneof /> <crc>15194fc9</crc> <manufacturer>Acclaim</manufacturer> <year>1992</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ghoul Patrol (USA)" index="" image=""> <description>Ghoul Patrol (USA)</description> <cloneof /> <crc>ea16b5a2</crc> <manufacturer>JVC Musical Industries, Inc.</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Go Go Ackman (Japan - Translated)" index="" image=""> <description>Go Go Ackman (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Banpresto</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Go Go Ackman 2 (Japan)" index="" image=""> <description>Go Go Ackman 2 (Japan)</description> <cloneof /> <crc /> <manufacturer>Banpresto</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Go Go Ackman 3 (Japan)" index="" image=""> <description>Go Go Ackman 3 (Japan)</description> <cloneof /> <crc /> <manufacturer>Banpresto</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Goal! (USA)" index="" image=""> <description>Goal! (USA)</description> <cloneof /> <crc>935ea22c</crc> <manufacturer>Jaleco</manufacturer> <year>1992</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Gods (USA)" index="" image=""> <description>Gods (USA)</description> <cloneof /> <crc>6779970f</crc> <manufacturer>Mindscape</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Goof Troop (USA)" index="" image=""> <description>Goof Troop (USA)</description> <cloneof /> <crc>4aafa462</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Gourmet Sentai - Bara Yarou (Japan - Translated)" index="" image=""> <description>Gourmet Sentai - Bara Yarou (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Virgin</manufacturer> <year>1995</year> <genre>Fighting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="GP-1 - Part II (USA)" index="" image=""> <description>GP-1 - Part II (USA)</description> <cloneof /> <crc>a9014e12</crc> <manufacturer>Atlus</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="GP-1 (USA)" index="" image=""> <description>GP-1 (USA)</description> <cloneof /> <crc>14bbc357</crc> <manufacturer>Atlus</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Gradius III (USA)" index="" image=""> <description>Gradius III (USA)</description> <cloneof /> <crc>cd973979</crc> <manufacturer>Konami</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Great Circus Mystery Starring Mickey & Minnie, The (USA)" index="" image=""> <description>Great Circus Mystery Starring Mickey & Minnie, The (USA)</description> <cloneof /> <crc>1903ea89</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Great Waldo Search, The (USA)" index="" image=""> <description>Great Waldo Search, The (USA)</description> <cloneof /> <crc>eb49f246</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="GunForce - Battle Fire Engulfed Terror Island (USA)" index="" image=""> <description>GunForce - Battle Fire Engulfed Terror Island (USA)</description> <cloneof /> <crc>6f5c5dc0</crc> <manufacturer>Irem</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hagane - The Final Conflict (USA)" index="true" image="h"> <description>Hagane - The Final Conflict (USA)</description> <cloneof /> <crc>8e0a7034</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="HAL's Hole in One Golf (USA)" index="" image=""> <description>HAL's Hole in One Golf (USA)</description> <cloneof /> <crc>58752baf</crc> <manufacturer>Hal</manufacturer> <year>1991</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hamelin no Violin Hiki (Japan - Translated)" index="" image=""> <description>Hamelin no Violin Hiki (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Enix</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hammerlock Wrestling (USA)" index="" image=""> <description>Hammerlock Wrestling (USA)</description> <cloneof /> <crc>3d2352ea</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="HardBall III (USA)" index="" image=""> <description>HardBall III (USA)</description> <cloneof /> <crc>f3589b15</crc> <manufacturer>Accolade</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Harley's Humongous Adventure (USA)" index="" image=""> <description>Harley's Humongous Adventure (USA)</description> <cloneof /> <crc>91e0c960</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Harvest Moon (USA)" index="" image=""> <description>Harvest Moon (USA)</description> <cloneof /> <crc>f829129e</crc> <manufacturer>Natsume</manufacturer> <year>1997</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Head-On Soccer (USA)" index="" image=""> <description>Head-On Soccer (USA)</description> <cloneof /> <crc>60dc3634</crc> <manufacturer>U.S. Gold</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hebereke's Popoitto (Europe)" index="" image=""> <description>Hebereke's Popoitto (Europe)</description> <cloneof /> <crc>0ce626ba</crc> <manufacturer>SunSoft</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hebereke's Popoon (Europe)" index="" image=""> <description>Hebereke's Popoon (Europe)</description> <cloneof /> <crc>7a313722</crc> <manufacturer>SunSoft</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hit the Ice (USA)" index="" image=""> <description>Hit the Ice (USA)</description> <cloneof /> <crc>ec13477e</crc> <manufacturer>Taito</manufacturer> <year>1993</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Holy Umbrella - Dondera no Mubo!! (Japan - Translated)" index="" image=""> <description>Holy Umbrella - Dondera no Mubo!! (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Earthly Soft</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Home Alone (USA)" index="" image=""> <description>Home Alone (USA)</description> <cloneof /> <crc>07c494b1</crc> <manufacturer>THQ</manufacturer> <year>1991</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Home Alone 2 - Lost in New York (USA)" index="" image=""> <description>Home Alone 2 - Lost in New York (USA)</description> <cloneof /> <crc>d19165d9</crc> <manufacturer>THQ</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Home Improvement (USA)" index="" image=""> <description>Home Improvement (USA)</description> <cloneof /> <crc>fa698c31</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hook (USA)" index="" image=""> <description>Hook (USA)</description> <cloneof /> <crc>0c572ef0</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Humans, The (Europe)" index="" image=""> <description>Humans, The (Europe)</description> <cloneof /> <crc>d2af01d4</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hungry Dinosaurs (Europe)" index="" image=""> <description>Hungry Dinosaurs (Europe)</description> <cloneof /> <crc>5c4b2544</crc> <manufacturer>Sun Soft</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hunt for Red October, The (USA)" index="" image=""> <description>Hunt for Red October, The (USA)</description> <cloneof /> <crc>c796e830</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hurricanes (USA)" index="" image=""> <description>Hurricanes (USA)</description> <cloneof /> <crc>42ff4f08</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Hyper V-Ball (USA)" index="" image=""> <description>Hyper V-Ball (USA)</description> <cloneof /> <crc>7d179e21</crc> <manufacturer>Mc O'River</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="HyperZone (USA)" index="" image=""> <description>HyperZone (USA)</description> <cloneof /> <crc>c95b4129</crc> <manufacturer>Hal</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ignition Factor, The (USA)" index="true" image="i"> <description>Ignition Factor, The (USA)</description> <cloneof /> <crc>ee441564</crc> <manufacturer>Jaleco</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Illusion of Gaia (USA)" index="" image=""> <description>Illusion of Gaia (USA)</description> <cloneof /> <crc>1c3848c0</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Imperium (USA)" index="" image=""> <description>Imperium (USA)</description> <cloneof /> <crc>2624f8bd</crc> <manufacturer>Vic Tokai</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Incantation (USA)" index="" image=""> <description>Incantation (USA)</description> <cloneof /> <crc>d0ff7e9f</crc> <manufacturer>Titus Software</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Incredible Crash Dummies, The (USA)" index="" image=""> <description>Incredible Crash Dummies, The (USA)</description> <cloneof /> <crc>0b6209ba</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Incredible Hulk, The (USA)" index="" image=""> <description>Incredible Hulk, The (USA)</description> <cloneof /> <crc>36b5a429</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Indiana Jones' Greatest Adventures (USA)" index="" image=""> <description>Indiana Jones' Greatest Adventures (USA)</description> <cloneof /> <crc>70da6bb8</crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Inindo - Way of the Ninja (USA)" index="" image=""> <description>Inindo - Way of the Ninja (USA)</description> <cloneof /> <crc>543f3327</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Inspector Gadget (USA)" index="" image=""> <description>Inspector Gadget (USA)</description> <cloneof /> <crc>4ce2b818</crc> <manufacturer>Hudson</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="International Superstar Soccer (Europe)" index="" image=""> <description>International Superstar Soccer (Europe)</description> <cloneof /> <crc>6cd568a9</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Soccer/Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="International Superstar Soccer (USA)" index="" image=""> <description>International Superstar Soccer (USA)</description> <cloneof /> <crc>49627238</crc> <manufacturer>Konami</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="International Superstar Soccer Deluxe (USA)" index="" image=""> <description>International Superstar Soccer Deluxe (USA)</description> <cloneof /> <crc>0a20e602</crc> <manufacturer>Konami</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="International Tennis Tour (USA)" index="" image=""> <description>International Tennis Tour (USA)</description> <cloneof /> <crc>ad3cd5e6</crc> <manufacturer>Taito</manufacturer> <year>1993</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Irem Skins Game, The (USA)" index="" image=""> <description>Irem Skins Game, The (USA)</description> <cloneof /> <crc>b95ddc44</crc> <manufacturer>Irem</manufacturer> <year>1992</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Iron Commando (Japan - Translated)" index="" image=""> <description>Iron Commando (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Arcade Zone LTD / Pop</manufacturer> <year>1995</year> <genre>Fighting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Itchy & Scratchy Game, The (USA)" index="" image=""> <description>Itchy & Scratchy Game, The (USA)</description> <cloneof /> <crc>95b65dfe</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Izzy's Quest for the Olympic Rings (USA)" index="" image=""> <description>Izzy's Quest for the Olympic Rings (USA)</description> <cloneof /> <crc>e9bb68c7</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="J.R.R. Tolkien's The Lord of the Rings - Volume 1 (USA)" index="true" image="j"> <description>J.R.R. Tolkien's The Lord of the Rings - Volume 1 (USA)</description> <cloneof /> <crc>cd2150c8</crc> <manufacturer>Interplay</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jack Nicklaus Golf (USA)" index="" image=""> <description>Jack Nicklaus Golf (USA)</description> <cloneof /> <crc>9abc58e2</crc> <manufacturer>Tradewest</manufacturer> <year>1991</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="James Bond Jr (USA)" index="" image=""> <description>James Bond Jr (USA)</description> <cloneof /> <crc>69c2f850</crc> <manufacturer>THQ</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jammit (USA)" index="" image=""> <description>Jammit (USA)</description> <cloneof /> <crc>7bddd73f</crc> <manufacturer>GTE Entertainment</manufacturer> <year>1994</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jelly Boy (Europe)" index="" image=""> <description>Jelly Boy (Europe)</description> <cloneof /> <crc>f8c72a24</crc> <manufacturer>Ocean</manufacturer> <year>1991</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jeopardy! - Deluxe Edition (USA)" index="" image=""> <description>Jeopardy! - Deluxe Edition (USA)</description> <cloneof /> <crc>6301060c</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jeopardy! - Sports Edition (USA)" index="" image=""> <description>Jeopardy! - Sports Edition (USA)</description> <cloneof /> <crc>bda7de29</crc> <manufacturer>GameTek</manufacturer> <year>1994</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jeopardy! (USA)" index="" image=""> <description>Jeopardy! (USA)</description> <cloneof /> <crc>65bf3a7e</crc> <manufacturer>GameTek</manufacturer> <year>1992</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jetsons, The - Invasion of the Planet Pirates (USA)" index="" image=""> <description>Jetsons, The - Invasion of the Planet Pirates (USA)</description> <cloneof /> <crc>3e3073ce</crc> <manufacturer>Taito</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jim Lee's WildC.A.T.S - Covert Action Teams (USA)" index="" image=""> <description>Jim Lee's WildC.A.T.S - Covert Action Teams (USA)</description> <cloneof /> <crc>10c6f5ad</crc> <manufacturer>Playmates</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jim Power - The Lost Dimension in 3D (USA)" index="" image=""> <description>Jim Power - The Lost Dimension in 3D (USA)</description> <cloneof /> <crc>c469f8f0</crc> <manufacturer>ElectroBrain</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jimmy Connors Pro Tennis Tour (USA)" index="" image=""> <description>Jimmy Connors Pro Tennis Tour (USA)</description> <cloneof /> <crc>913f1555</crc> <manufacturer>Ubisoft</manufacturer> <year>1994</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jimmy Houston's Bass Tournament U.S.A. (USA)" index="" image=""> <description>Jimmy Houston's Bass Tournament U.S.A. (USA)</description> <cloneof /> <crc>e7e488d5</crc> <manufacturer>American Sammy</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Joe & Mac (USA)" index="" image=""> <description>Joe & Mac (USA)</description> <cloneof /> <crc>3a2b6167</crc> <manufacturer>Data East</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Joe & Mac 2 - Lost in the Tropics (USA)" index="" image=""> <description>Joe & Mac 2 - Lost in the Tropics (USA)</description> <cloneof /> <crc>0c3b4201</crc> <manufacturer>Data East</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="John Madden Football (USA)" index="" image=""> <description>John Madden Football (USA)</description> <cloneof /> <crc>796294c6</crc> <manufacturer>Electronic Arts</manufacturer> <year>1991</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="John Madden Football '93 (USA) (Rev 1)" index="" image=""> <description>John Madden Football '93 (USA) (Rev 1)</description> <cloneof /> <crc>dc5a250b</crc> <manufacturer>Electronic Arts</manufacturer> <year>1992</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Judge Dredd (USA)" index="" image=""> <description>Judge Dredd (USA)</description> <cloneof /> <crc>0a3f0288</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jungle Book, The (USA)" index="" image=""> <description>Jungle Book, The (USA)</description> <cloneof /> <crc>3511efb3</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jungle Strike (USA)" index="" image=""> <description>Jungle Strike (USA)</description> <cloneof /> <crc>335487e5</crc> <manufacturer>Electronic Arts</manufacturer> <year>1995</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jurassic Park (USA) (Rev 1)" index="" image=""> <description>Jurassic Park (USA) (Rev 1)</description> <cloneof /> <crc>8bfde0b7</crc> <manufacturer>Ocean</manufacturer> <year>1993</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jurassic Park II - The Chaos Continues (USA)" index="" image=""> <description>Jurassic Park II - The Chaos Continues (USA)</description> <cloneof /> <crc>836ee990</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Justice League Task Force (USA)" index="" image=""> <description>Justice League Task Force (USA)</description> <cloneof /> <crc>31cf46d1</crc> <manufacturer>Sun Soft</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Jutei Senki (Japan - Translated)" index="" image=""> <description>Jutei Senki (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Enix</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kablooey (USA)" index="true" image="k"> <description>Kablooey (USA)</description> <cloneof /> <crc>b2592eae</crc> <manufacturer>Mirrorsoft</manufacturer> <year>1992</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kawasaki Caribbean Challenge (USA)" index="" image=""> <description>Kawasaki Caribbean Challenge (USA)</description> <cloneof /> <crc>37d8ac57</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kawasaki Superbike Challenge (USA)" index="" image=""> <description>Kawasaki Superbike Challenge (USA)</description> <cloneof /> <crc>e8ed176e</crc> <manufacturer>Time Warner Interactive</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ken Griffey Jr. Presents Major League Baseball (USA)" index="" image=""> <description>Ken Griffey Jr. Presents Major League Baseball (USA)</description> <cloneof /> <crc>8bf2b589</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ken Griffey Jr.'s Winning Run (USA)" index="" image=""> <description>Ken Griffey Jr.'s Winning Run (USA)</description> <cloneof /> <crc>e9b4bd73</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kendo Rage (USA)" index="" image=""> <description>Kendo Rage (USA)</description> <cloneof /> <crc>d1048918</crc> <manufacturer>Seta Corporation</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kevin Keegan's Player Manager (Europe)" index="" image=""> <description>Kevin Keegan's Player Manager (Europe)</description> <cloneof /> <crc>fce7bade</crc> <manufacturer>Imagineer</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kick Off (Europe)" index="" image=""> <description>Kick Off (Europe)</description> <cloneof /> <crc>a1306f3b</crc> <manufacturer>Imagineer</manufacturer> <year>1993</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kick Off 3 - European Challenge (Europe)" index="" image=""> <description>Kick Off 3 - European Challenge (Europe)</description> <cloneof /> <crc>1ac7f523</crc> <manufacturer>Vic Tokai</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kid Klown in Crazy Chase (USA)" index="" image=""> <description>Kid Klown in Crazy Chase (USA)</description> <cloneof /> <crc>bd6c8ab1</crc> <manufacturer>Kemco</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kidou Butouden G-Gundam (Japan - Translated)" index="" image=""> <description>Kidou Butouden G-Gundam (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Pandora Box / Bandai</manufacturer> <year>1994</year> <genre>Fighting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Killer Instinct (USA) (Rev 1)" index="" image=""> <description>Killer Instinct (USA) (Rev 1)</description> <cloneof /> <crc>09e9a04e</crc> <manufacturer>Nintendo</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="King Arthur & The Knights of Justice (USA)" index="" image=""> <description>King Arthur & The Knights of Justice (USA)</description> <cloneof /> <crc>615a183b</crc> <manufacturer>Enix</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="King Arthur's World (USA)" index="" image=""> <description>King Arthur's World (USA)</description> <cloneof /> <crc>99bd1fe1</crc> <manufacturer>Jaleco</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="King of Dragons, The (USA)" index="" image=""> <description>King of Dragons, The (USA)</description> <cloneof /> <crc>dd505df7</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="King of the Monsters (USA)" index="" image=""> <description>King of the Monsters (USA)</description> <cloneof /> <crc>c285c7ff</crc> <manufacturer>Takara</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="King of the Monsters 2 (USA)" index="" image=""> <description>King of the Monsters 2 (USA)</description> <cloneof /> <crc>0b677a37</crc> <manufacturer>Takara</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kirby Super Star (USA)" index="" image=""> <description>Kirby Super Star (USA)</description> <cloneof /> <crc>89d0f7dc</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kirby's Avalanche (USA)" index="" image=""> <description>Kirby's Avalanche (USA)</description> <cloneof /> <crc>21e658b8</crc> <manufacturer>Nintendo</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kirby's Dream Course (USA)" index="" image=""> <description>Kirby's Dream Course (USA)</description> <cloneof /> <crc>df8153d9</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kirby's Dream Land 3 (USA)" index="" image=""> <description>Kirby's Dream Land 3 (USA)</description> <cloneof /> <crc>ec8a48f6</crc> <manufacturer>Nintendo</manufacturer> <year>1998</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Knights of the Round (USA)" index="" image=""> <description>Knights of the Round (USA)</description> <cloneof /> <crc>aaa82126</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kouryuu Densetsu Villgust - Kieta Shoujo (Japan - Translated)" index="" image=""> <description>Kouryuu Densetsu Villgust - Kieta Shoujo (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>WinkySoft / Bandai</manufacturer> <year>1992</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Krusty's Super Fun House (USA) (Rev 1)" index="" image=""> <description>Krusty's Super Fun House (USA) (Rev 1)</description> <cloneof /> <crc>ac5116d9</crc> <manufacturer>Acclaim</manufacturer> <year>1992</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kuusou Kagaku Sekai Gulliver Boy (Japan - Translated)" index="" image=""> <description>Kuusou Kagaku Sekai Gulliver Boy (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>BanDai</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Kyle Petty's No Fear Racing (USA)" index="" image=""> <description>Kyle Petty's No Fear Racing (USA)</description> <cloneof /> <crc>aee90a85</crc> <manufacturer>Williams</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lagoon (USA)" index="true" image="l"> <description>Lagoon (USA)</description> <cloneof /> <crc>d2554270</crc> <manufacturer>Kemco</manufacturer> <year>1991</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lamborghini American Challenge (USA)" index="" image=""> <description>Lamborghini American Challenge (USA)</description> <cloneof /> <crc>d2fb701b</crc> <manufacturer>Titus Software</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Last Action Hero (USA)" index="" image=""> <description>Last Action Hero (USA)</description> <cloneof /> <crc>88017df9</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lawnmower Man, The (USA)" index="" image=""> <description>Lawnmower Man, The (USA)</description> <cloneof /> <crc>2736b607</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Legend (USA)" index="" image=""> <description>Legend (USA)</description> <cloneof /> <crc>0a6dd870</crc> <manufacturer>Seika Corp</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Legend of the Mystical Ninja, The (USA)" index="" image=""> <description>Legend of the Mystical Ninja, The (USA)</description> <cloneof /> <crc>82479d6a</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Legend of Zelda, The - A Link to the Past (USA)" index="" image=""> <description>Legend of Zelda, The - A Link to the Past (USA)</description> <cloneof /> <crc>777aac2f</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lemmings (USA) (Rev 1)" index="" image=""> <description>Lemmings (USA) (Rev 1)</description> <cloneof /> <crc>51e3d566</crc> <manufacturer>SunSoft</manufacturer> <year>1992</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lemmings 2 - The Tribes (USA)" index="" image=""> <description>Lemmings 2 - The Tribes (USA)</description> <cloneof /> <crc>df7200c8</crc> <manufacturer>Psygnosis</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lester the Unlikely (USA)" index="" image=""> <description>Lester the Unlikely (USA)</description> <cloneof /> <crc>1a52fee5</crc> <manufacturer>DTMC</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lethal Enforcers (USA)" index="" image=""> <description>Lethal Enforcers (USA)</description> <cloneof /> <crc>5aff8cd5</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lethal Weapon (USA)" index="" image=""> <description>Lethal Weapon (USA)</description> <cloneof /> <crc>a14c3dbc</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Liberty or Death (USA)" index="" image=""> <description>Liberty or Death (USA)</description> <cloneof /> <crc>75e362a6</crc> <manufacturer>Koei</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lion King, The (USA)" index="" image=""> <description>Lion King, The (USA)</description> <cloneof /> <crc>c8fbfaa8</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Little Master - Nijiiro no Maseki (Japan - Translated)" index="" image=""> <description>Little Master - Nijiiro no Maseki (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Tokuma Shoten</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Live A Live (Japan - Translated)" index="" image=""> <description>Live A Live (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Square</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lock On (USA)" index="" image=""> <description>Lock On (USA)</description> <cloneof /> <crc>84f7e078</crc> <manufacturer>Vic Tokai</manufacturer> <year>1993</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lodoss Tou Senki - Record of Lodoss War (Japan - Translated)" index="" image=""> <description>Lodoss Tou Senki - Record of Lodoss War (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Hummingbird Soft</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Looney Tunes B-Ball (USA)" index="" image=""> <description>Looney Tunes B-Ball (USA)</description> <cloneof /> <crc>6d3bc96f</crc> <manufacturer>Sun Soft</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lost Vikings 2 (USA)" index="" image=""> <description>Lost Vikings 2 (USA)</description> <cloneof /> <crc>3aa01dbd</crc> <manufacturer>Interplay</manufacturer> <year>1997</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lost Vikings, The (USA)" index="" image=""> <description>Lost Vikings, The (USA)</description> <cloneof /> <crc>6838be08</crc> <manufacturer>Interplay</manufacturer> <year>1992</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lucky Luke (Europe)" index="" image=""> <description>Lucky Luke (Europe)</description> <cloneof /> <crc>7e2c7143</crc> <manufacturer>Infogrames</manufacturer> <year>1997</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lufia & The Fortress of Doom (USA)" index="" image=""> <description>Lufia & The Fortress of Doom (USA)</description> <cloneof /> <crc>5e1aa1a6</crc> <manufacturer>Taito</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Lufia II - Rise of the Sinistrals (USA)" index="" image=""> <description>Lufia II - Rise of the Sinistrals (USA)</description> <cloneof /> <crc>20f2ac29</crc> <manufacturer>Natsume</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madden NFL '94 (USA)" index="true" image="m"> <description>Madden NFL '94 (USA)</description> <cloneof /> <crc>8bed5914</crc> <manufacturer>Electronic Arts</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madden NFL 95 (USA)" index="" image=""> <description>Madden NFL 95 (USA)</description> <cloneof /> <crc>021a3f69</crc> <manufacturer>EA Sports</manufacturer> <year>1994</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madden NFL 96 (USA)" index="" image=""> <description>Madden NFL 96 (USA)</description> <cloneof /> <crc>51a1fe86</crc> <manufacturer>EA Sports</manufacturer> <year>1995</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madden NFL 97 (USA)" index="" image=""> <description>Madden NFL 97 (USA)</description> <cloneof /> <crc>abcf026e</crc> <manufacturer>EA Sports</manufacturer> <year>1996</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madden NFL 98 (USA)" index="" image=""> <description>Madden NFL 98 (USA)</description> <cloneof /> <crc>cf10cc01</crc> <manufacturer>Black Pearl</manufacturer> <year>1997</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Madou Monogatari - Hanamaru Daiyouchi Enji (Japan - Translated)" index="" image=""> <description>Madou Monogatari - Hanamaru Daiyouchi Enji (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Compile / Tokuma Shoten</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magic Boy (USA)" index="" image=""> <description>Magic Boy (USA)</description> <cloneof /> <crc>ab57a2f9</crc> <manufacturer>JVC Musical Industries, Inc</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magic Knight Rayearth (Japan - Translated)" index="" image=""> <description>Magic Knight Rayearth (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Pandora Box / Tomy Corporation</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magic Sword (USA)" index="" image=""> <description>Magic Sword (USA)</description> <cloneof /> <crc>27325e4d</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magical Pop'n (Japan - Translated)" index="" image=""> <description>Magical Pop'n (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Polestar / Pack-In-Video</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magical Quest Starring Mickey Mouse, The (USA)" index="" image=""> <description>Magical Quest Starring Mickey Mouse, The (USA)</description> <cloneof /> <crc>10874c70</crc> <manufacturer>Capcom</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Magna Braban - Henreki no Yuusha (Japan - Translated)" index="" image=""> <description>Magna Braban - Henreki no Yuusha (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Lenar / ASK</manufacturer> <year>1994</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Majuu Ou (Japan - Translated)" index="" image=""> <description>Majuu Ou (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>KSS</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Manchester United Championship Soccer (Europe)" index="" image=""> <description>Manchester United Championship Soccer (Europe)</description> <cloneof /> <crc>8d2596a7</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Marchen Adventure Cotton 100 (Japan - Translated)" index="" image=""> <description>Marchen Adventure Cotton 100 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Success / Datam Polystar</manufacturer> <year>1994</year> <genre>Shoot Em Up</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario Is Missing! (USA)" index="" image=""> <description>Mario Is Missing! (USA)</description> <cloneof /> <crc>e51a3fcd</crc> <manufacturer>Software Toolworks</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario Paint (Japan, USA)" index="" image=""> <description>Mario Paint (Japan, USA)</description> <cloneof /> <crc>38c9626c</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario's Early Years! - Fun with Letters (USA)" index="" image=""> <description>Mario's Early Years! - Fun with Letters (USA)</description> <cloneof /> <crc>480b043a</crc> <manufacturer>Software Toolworks</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario's Early Years! - Fun with Numbers (USA)" index="" image=""> <description>Mario's Early Years! - Fun with Numbers (USA)</description> <cloneof /> <crc>8c0c37f4</crc> <manufacturer>Software Toolworks</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario's Early Years! - Preschool Fun (USA)" index="" image=""> <description>Mario's Early Years! - Preschool Fun (USA)</description> <cloneof /> <crc>85a6b2a8</crc> <manufacturer>Mindscape</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mario's Time Machine (USA)" index="" image=""> <description>Mario's Time Machine (USA)</description> <cloneof /> <crc>5e7397e0</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mark Davis' The Fishing Master (USA)" index="" image=""> <description>Mark Davis' The Fishing Master (USA)</description> <cloneof /> <crc>22a109b9</crc> <manufacturer>Natsume</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Marko's Magic Football (Europe)" index="" image=""> <description>Marko's Magic Football (Europe)</description> <cloneof /> <crc>4824a630</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Marvel Super Heroes - War of the Gems (USA)" index="" image=""> <description>Marvel Super Heroes - War of the Gems (USA)</description> <cloneof /> <crc>00af56e8</crc> <manufacturer>Capcom</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mary Shelley's Frankenstein (USA)" index="" image=""> <description>Mary Shelley's Frankenstein (USA)</description> <cloneof /> <crc>91415d1e</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mask, The (USA)" index="" image=""> <description>Mask, The (USA)</description> <cloneof /> <crc>e17626e2</crc> <manufacturer>Black Pearl</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Math Blaster - Episode 1 (USA)" index="" image=""> <description>Math Blaster - Episode 1 (USA)</description> <cloneof /> <crc>4c4e5f4a</crc> <manufacturer>Davidson & Associates</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Maui Mallard in Cold Shadow (USA)" index="" image=""> <description>Maui Mallard in Cold Shadow (USA)</description> <cloneof /> <crc>2d3b9662</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mecarobot Golf (USA)" index="" image=""> <description>Mecarobot Golf (USA)</description> <cloneof /> <crc>82ceee3a</crc> <manufacturer>Toho</manufacturer> <year>1993</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="MechWarrior (USA)" index="" image=""> <description>MechWarrior (USA)</description> <cloneof /> <crc>40b7a858</crc> <manufacturer>Activision</manufacturer> <year>1993</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="MechWarrior 3050 (USA)" index="" image=""> <description>MechWarrior 3050 (USA)</description> <cloneof /> <crc>c0acc92d</crc> <manufacturer>Activision</manufacturer> <year>1995</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega lo Mania (Europe)" index="" image=""> <description>Mega lo Mania (Europe)</description> <cloneof /> <crc>e8042edf</crc> <manufacturer>Imagineer</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega Man 7 (USA)" index="" image=""> <description>Mega Man 7 (USA)</description> <cloneof /> <crc>2d947536</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega Man Soccer (USA)" index="" image=""> <description>Mega Man Soccer (USA)</description> <cloneof /> <crc>fa9ee2ce</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega Man X (USA) (Rev 1)" index="" image=""> <description>Mega Man X (USA) (Rev 1)</description> <cloneof /> <crc>ded53c64</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega Man X2 (USA)" index="" image=""> <description>Mega Man X2 (USA)</description> <cloneof /> <crc>947b0355</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mega Man X3 (USA)" index="" image=""> <description>Mega Man X3 (USA)</description> <cloneof /> <crc>fa0fe671</crc> <manufacturer>Capcom</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Metal Combat - Falcon's Revenge (USA)" index="" image=""> <description>Metal Combat - Falcon's Revenge (USA)</description> <cloneof /> <crc>c3131b49</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Metal Marines (USA)" index="" image=""> <description>Metal Marines (USA)</description> <cloneof /> <crc>66787df6</crc> <manufacturer>Namco</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Metal Max Returns (Japan - Translated)" index="" image=""> <description>Metal Max Returns (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Crea-Tech / Data East</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Metal Morph (USA)" index="" image=""> <description>Metal Morph (USA)</description> <cloneof /> <crc>0adaa9da</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Metal Warriors (USA)" index="" image=""> <description>Metal Warriors (USA)</description> <cloneof /> <crc>f2ab92d4</crc> <manufacturer>Konami</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Michael Andretti's IndyCar Challenge (USA)" index="" image=""> <description>Michael Andretti's IndyCar Challenge (USA)</description> <cloneof /> <crc>0fdb210e</crc> <manufacturer>Bullet Proof Software</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Michael Jordan - Chaos in the Windy City (USA)" index="" image=""> <description>Michael Jordan - Chaos in the Windy City (USA)</description> <cloneof /> <crc>f57dba3b</crc> <manufacturer>Electronic Arts</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mickey Mania - The Timeless Adventures of Mickey Mouse (USA)" index="" image=""> <description>Mickey Mania - The Timeless Adventures of Mickey Mouse (USA)</description> <cloneof /> <crc>08806b5b</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mickey to Donald - Magical Adventure 3 (Japan - Translated)" index="" image=""> <description>Mickey to Donald - Magical Adventure 3 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mickey's Playtown Adventure - A Day of Discovery! (USA) (Proto)" index="" image=""> <description>Mickey's Playtown Adventure - A Day of Discovery! (USA) (Proto)</description> <cloneof /> <crc>53524952</crc> <manufacturer>Hi-Tech</manufacturer> <year>1994</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mickey's Ultimate Challenge (USA)" index="" image=""> <description>Mickey's Ultimate Challenge (USA)</description> <cloneof /> <crc>d6c60a84</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Micro Machines (USA)" index="" image=""> <description>Micro Machines (USA)</description> <cloneof /> <crc>364e68bb</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Micro Machines 2 - Turbo Tournament (Europe)" index="" image=""> <description>Micro Machines 2 - Turbo Tournament (Europe)</description> <cloneof /> <crc>1619b619</crc> <manufacturer>Ocean</manufacturer> <year>1996</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Might and Magic II - Gates to Another World (Europe)" index="" image=""> <description>Might and Magic II - Gates to Another World (Europe)</description> <cloneof /> <crc>4062244b</crc> <manufacturer>Sammy Studios</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Might and Magic III - Isles of Terra (USA)" index="" image=""> <description>Might and Magic III - Isles of Terra (USA)</description> <cloneof /> <crc>8af25e7e</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mighty Max (USA)" index="" image=""> <description>Mighty Max (USA)</description> <cloneof /> <crc>6fc3c105</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mighty Morphin Power Rangers - The Fighting Edition (USA)" index="" image=""> <description>Mighty Morphin Power Rangers - The Fighting Edition (USA)</description> <cloneof /> <crc>460b0a60</crc> <manufacturer>Bandai</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mighty Morphin Power Rangers - The Movie (USA)" index="" image=""> <description>Mighty Morphin Power Rangers - The Movie (USA)</description> <cloneof /> <crc>e3ef6201</crc> <manufacturer>Bandai</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mighty Morphin Power Rangers (USA)" index="" image=""> <description>Mighty Morphin Power Rangers (USA)</description> <cloneof /> <crc>a56eb77a</crc> <manufacturer>Bandai</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="MLBPA Baseball (USA)" index="" image=""> <description>MLBPA Baseball (USA)</description> <cloneof /> <crc>62a92e57</crc> <manufacturer>EA Sports</manufacturer> <year>1994</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mohawk & Headphone Jack (USA)" index="" image=""> <description>Mohawk & Headphone Jack (USA)</description> <cloneof /> <crc>0b207e7f</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Monopoly (USA) (Rev 1)" index="" image=""> <description>Monopoly (USA) (Rev 1)</description> <cloneof /> <crc>88d54085</crc> <manufacturer>Parker Brothers</manufacturer> <year>1992</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Monstania (Japan - Translated)" index="" image=""> <description>Monstania (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Bits Laboratory / Pack-In-Video</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mortal Kombat (USA)" index="" image=""> <description>Mortal Kombat (USA)</description> <cloneof /> <crc>def42945</crc> <manufacturer>Acclaim</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mortal Kombat 3 (USA)" index="" image=""> <description>Mortal Kombat 3 (USA)</description> <cloneof /> <crc>4e6af725</crc> <manufacturer>Williams</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mortal Kombat II (USA) (Rev 1)" index="" image=""> <description>Mortal Kombat II (USA) (Rev 1)</description> <cloneof /> <crc>70bb5513</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mr. Do! (USA)" index="" image=""> <description>Mr. Do! (USA)</description> <cloneof /> <crc>1c1025e2</crc> <manufacturer>Black Pearl</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mr. Nutz (USA)" index="" image=""> <description>Mr. Nutz (USA)</description> <cloneof /> <crc>a99bdd9a</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ms. Pac-Man (USA)" index="" image=""> <description>Ms. Pac-Man (USA)</description> <cloneof /> <crc>74d210d3</crc> <manufacturer>Midway</manufacturer> <year>1996</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Musya (USA)" index="" image=""> <description>Musya (USA)</description> <cloneof /> <crc>011907a4</crc> <manufacturer>Seta Corporation</manufacturer> <year>1992</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Mystic Ark (Japan - Translated)" index="true" image="n"> <description>Mystic Ark (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Produce / Enix America, Inc.</manufacturer> <year>1995</year> <genre>Role Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nangoku Shounen Papuwa-kun (Japan - Translated)" index="true" image="n"> <description>Nangoku Shounen Papuwa-kun (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Enix / Daft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Natsume Championship Wrestling (USA)" index="true" image="n"> <description>Natsume Championship Wrestling (USA)</description> <cloneof /> <crc>d4dc20e1</crc> <manufacturer>Natsume</manufacturer> <year>1994</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA All-Star Challenge (USA)" index="" image=""> <description>NBA All-Star Challenge (USA)</description> <cloneof /> <crc>a905a565</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1993</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Give 'n Go (USA)" index="" image=""> <description>NBA Give 'n Go (USA)</description> <cloneof /> <crc>68c8b643</crc> <manufacturer>KCEO</manufacturer> <year>1995</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Hang Time (USA)" index="" image=""> <description>NBA Hang Time (USA)</description> <cloneof /> <crc>262ce76b</crc> <manufacturer>Midway</manufacturer> <year>1996</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Jam - Tournament Edition (USA)" index="" image=""> <description>NBA Jam - Tournament Edition (USA)</description> <cloneof /> <crc>1fbc1ddb</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Jam (USA) (Rev 1)" index="" image=""> <description>NBA Jam (USA) (Rev 1)</description> <cloneof /> <crc>8f42cae7</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Live 95 (USA)" index="" image=""> <description>NBA Live 95 (USA)</description> <cloneof /> <crc>1cd2393d</crc> <manufacturer>EA Sports</manufacturer> <year>1994</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Live 96 (USA)" index="" image=""> <description>NBA Live 96 (USA)</description> <cloneof /> <crc>042a6495</crc> <manufacturer>EA Sports</manufacturer> <year>1995</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Live 97 (USA)" index="" image=""> <description>NBA Live 97 (USA)</description> <cloneof /> <crc>5115b8e5</crc> <manufacturer>EA Sports</manufacturer> <year>1996</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Live 98 (USA)" index="" image=""> <description>NBA Live 98 (USA)</description> <cloneof /> <crc>514bfcb5</crc> <manufacturer>EA Sports</manufacturer> <year>1998</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NBA Showdown (USA)" index="" image=""> <description>NBA Showdown (USA)</description> <cloneof /> <crc>65746f02</crc> <manufacturer>EA Sports</manufacturer> <year>1993</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NCAA Basketball (USA) (Rev 1)" index="" image=""> <description>NCAA Basketball (USA) (Rev 1)</description> <cloneof /> <crc>200370a2</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NCAA Final Four Basketball (USA)" index="" image=""> <description>NCAA Final Four Basketball (USA)</description> <cloneof /> <crc>b07cfa91</crc> <manufacturer>Mindscape</manufacturer> <year>1995</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NCAA Football (USA)" index="" image=""> <description>NCAA Football (USA)</description> <cloneof /> <crc>2641c12a</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nekketsu Tairiku Burning Heroes (Japan - Translated)" index="" image=""> <description>Nekketsu Tairiku Burning Heroes (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>J-Force / Enix America, Inc.</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Neugier (Japan - Translated)" index="" image=""> <description>Neugier (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Wolf Team / Telenet Japan</manufacturer> <year>1993</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="New Horizons (USA)" index="" image=""> <description>New Horizons (USA)</description> <cloneof /> <crc>3c3c63e6</crc> <manufacturer>Koei</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Newman-Haas IndyCar featuring Nigel Mansell (USA)" index="" image=""> <description>Newman-Haas IndyCar featuring Nigel Mansell (USA)</description> <cloneof /> <crc>a0f80c02</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NFL Football (USA)" index="" image=""> <description>NFL Football (USA)</description> <cloneof /> <crc>adb7731b</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NFL Quarterback Club (USA)" index="" image=""> <description>NFL Quarterback Club (USA)</description> <cloneof /> <crc>79f16421</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1995</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NFL Quarterback Club 96 (USA)" index="" image=""> <description>NFL Quarterback Club 96 (USA)</description> <cloneof /> <crc>e557689f</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL '94 (USA)" index="" image=""> <description>NHL '94 (USA)</description> <cloneof /> <crc>42212a77</crc> <manufacturer>Electronic Arts</manufacturer> <year>1993</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL '95 (USA)" index="" image=""> <description>NHL '95 (USA)</description> <cloneof /> <crc>2e9b1463</crc> <manufacturer>EA Sports</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL '96 (USA)" index="" image=""> <description>NHL '96 (USA)</description> <cloneof /> <crc>b6c6e7f3</crc> <manufacturer>EA Sports</manufacturer> <year>1995</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL '97 (USA)" index="" image=""> <description>NHL '97 (USA)</description> <cloneof /> <crc>06badb74</crc> <manufacturer>EA Sports</manufacturer> <year>1996</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL '98 (USA)" index="" image=""> <description>NHL '98 (USA)</description> <cloneof /> <crc>03cad2d2</crc> <manufacturer>EA Sports</manufacturer> <year>1997</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHL Stanley Cup (USA)" index="" image=""> <description>NHL Stanley Cup (USA)</description> <cloneof /> <crc>584ce502</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="NHLPA Hockey '93 (USA)" index="" image=""> <description>NHLPA Hockey '93 (USA)</description> <cloneof /> <crc>c858eac4</crc> <manufacturer>EA Sports</manufacturer> <year>1992</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nickelodeon GUTS (USA)" index="" image=""> <description>Nickelodeon GUTS (USA)</description> <cloneof /> <crc>233fec8c</crc> <manufacturer>Viacom New Media</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nigel Mansell's World Championship Racing (USA)" index="" image=""> <description>Nigel Mansell's World Championship Racing (USA)</description> <cloneof /> <crc>162252e2</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ninja Gaiden Trilogy (USA)" index="" image=""> <description>Ninja Gaiden Trilogy (USA)</description> <cloneof /> <crc>066fe797</crc> <manufacturer>Tecmo</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ninja Warriors, The (USA)" index="" image=""> <description>Ninja Warriors, The (USA)</description> <cloneof /> <crc>7537d8d7</crc> <manufacturer>Taito corporation</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="No Escape (USA)" index="" image=""> <description>No Escape (USA)</description> <cloneof /> <crc>c1082880</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nobunaga's Ambition - Lord of Darkness (USA)" index="" image=""> <description>Nobunaga's Ambition - Lord of Darkness (USA)</description> <cloneof /> <crc>4d7b39cd</crc> <manufacturer>Koei</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nobunaga's Ambition (USA)" index="" image=""> <description>Nobunaga's Ambition (USA)</description> <cloneof /> <crc>49da3583</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nolan Ryan's Baseball (USA)" index="" image=""> <description>Nolan Ryan's Baseball (USA)</description> <cloneof /> <crc>1919baff</crc> <manufacturer>Romstar</manufacturer> <year>1992</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Nosferatu (USA)" index="" image=""> <description>Nosferatu (USA)</description> <cloneof /> <crc>de762764</crc> <manufacturer>Seta Corporation</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Obitus (USA)" index="true" image="o"> <description>Obitus (USA)</description> <cloneof /> <crc>7c495b36</crc> <manufacturer>Bullet Proof Software</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ogre Battle - The March of the Black Queen (USA)" index="" image=""> <description>Ogre Battle - The March of the Black Queen (USA)</description> <cloneof /> <crc>acfdb7b8</crc> <manufacturer>Enix</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Olympic Summer Games (USA)" index="" image=""> <description>Olympic Summer Games (USA)</description> <cloneof /> <crc>6b882d11</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="On the Ball (USA)" index="" image=""> <description>On the Ball (USA)</description> <cloneof /> <crc>50ad3fe8</crc> <manufacturer>Taito</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Operation Europe - Path to Victory 1939-45 (USA)" index="" image=""> <description>Operation Europe - Path to Victory 1939-45 (USA)</description> <cloneof /> <crc>f84c2bb6</crc> <manufacturer>Koei</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Operation Logic Bomb (USA)" index="" image=""> <description>Operation Logic Bomb (USA)</description> <cloneof /> <crc>65bbe8b4</crc> <manufacturer>Jaleco</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Operation Starfi5h (Europe)" index="" image=""> <description>Operation Starfi5h (Europe)</description> <cloneof /> <crc>9d3e313f</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Operation Thunderbolt (USA)" index="" image=""> <description>Operation Thunderbolt (USA)</description> <cloneof /> <crc>3042b049</crc> <manufacturer>Taito</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Oscar (USA)" index="" image=""> <description>Oscar (USA)</description> <cloneof /> <crc>cdf463c0</crc> <manufacturer>Titus</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Out of This World (USA)" index="" image=""> <description>Out of This World (USA)</description> <cloneof /> <crc>5f40a869</crc> <manufacturer>Interplay</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Out to Lunch (USA)" index="" image=""> <description>Out to Lunch (USA)</description> <cloneof /> <crc>3d0c8974</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Outlander (USA)" index="" image=""> <description>Outlander (USA)</description> <cloneof /> <crc>a978b36f</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="P.T.O. - Pacific Theater of Operations (USA)" index="true" image="p"> <description>P.T.O. - Pacific Theater of Operations (USA)</description> <cloneof /> <crc>e51bbac8</crc> <manufacturer>Koei</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="P.T.O. II - Pacific Theater of Operations (USA)" index="" image=""> <description>P.T.O. II - Pacific Theater of Operations (USA)</description> <cloneof /> <crc>a614d268</crc> <manufacturer>Koei</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pac-Attack (USA)" index="" image=""> <description>Pac-Attack (USA)</description> <cloneof /> <crc>191b1a19</crc> <manufacturer>Namco</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pac-in-Time (USA)" index="" image=""> <description>Pac-in-Time (USA)</description> <cloneof /> <crc>44375368</crc> <manufacturer>Namco</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Packy & Marlon (USA)" index="" image=""> <description>Packy & Marlon (USA)</description> <cloneof /> <crc>bab26e9c</crc> <manufacturer>Raya Systems</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pac-Man 2 - The New Adventures (USA)" index="" image=""> <description>Pac-Man 2 - The New Adventures (USA)</description> <cloneof /> <crc>9fc62bcc</crc> <manufacturer>Namco</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pagemaster, The (USA)" index="" image=""> <description>Pagemaster, The (USA)</description> <cloneof /> <crc>26c38eee</crc> <manufacturer>Fox Interactive</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Paladin's Quest (USA)" index="" image=""> <description>Paladin's Quest (USA)</description> <cloneof /> <crc>37fe8126</crc> <manufacturer>Enix</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Paperboy 2 (USA)" index="" image=""> <description>Paperboy 2 (USA)</description> <cloneof /> <crc>c85aa66a</crc> <manufacturer>Mindscape</manufacturer> <year>1991</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Parodius (Europe)" index="" image=""> <description>Parodius (Europe)</description> <cloneof /> <crc>6ffa308c</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Peace Keepers, The (USA)" index="" image=""> <description>Peace Keepers, The (USA)</description> <cloneof /> <crc>8071e5db</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="PGA European Tour (USA)" index="" image=""> <description>PGA European Tour (USA)</description> <cloneof /> <crc>914f2ea3</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="PGA Tour 96 (USA)" index="" image=""> <description>PGA Tour 96 (USA)</description> <cloneof /> <crc>bc5df071</crc> <manufacturer>Black Pearl</manufacturer> <year>1995</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="PGA Tour Golf (USA)" index="" image=""> <description>PGA Tour Golf (USA)</description> <cloneof /> <crc>b6566944</crc> <manufacturer>Electronic Arts</manufacturer> <year>1993</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Phalanx - The Enforce Fighter A-144 (USA)" index="" image=""> <description>Phalanx - The Enforce Fighter A-144 (USA)</description> <cloneof /> <crc>dc90a8ab</crc> <manufacturer>Kemco</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Phantom 2040 (USA)" index="" image=""> <description>Phantom 2040 (USA)</description> <cloneof /> <crc>35e8fb28</crc> <manufacturer>Viacom New Media</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pieces (USA)" index="" image=""> <description>Pieces (USA)</description> <cloneof /> <crc>bb6c3c54</crc> <manufacturer>Atlus</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pilotwings (USA)" index="" image=""> <description>Pilotwings (USA)</description> <cloneof /> <crc>266c44ed</crc> <manufacturer>Nintendo</manufacturer> <year>1991</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pinball Dreams (USA)" index="" image=""> <description>Pinball Dreams (USA)</description> <cloneof /> <crc>81107ce2</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Pinball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pinball Fantasies (USA)" index="" image=""> <description>Pinball Fantasies (USA)</description> <cloneof /> <crc>822ad378</crc> <manufacturer>GameTek</manufacturer> <year>1995</year> <genre>Pinball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pink Goes to Hollywood (USA)" index="" image=""> <description>Pink Goes to Hollywood (USA)</description> <cloneof /> <crc>8bae9438</crc> <manufacturer>TecMagik</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pinocchio (USA)" index="" image=""> <description>Pinocchio (USA)</description> <cloneof /> <crc>00fad8fd</crc> <manufacturer>Disney</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pirates of Dark Water, The (USA)" index="" image=""> <description>Pirates of Dark Water, The (USA)</description> <cloneof /> <crc>7ca0ca4d</crc> <manufacturer>SunSoft</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pitfall - The Mayan Adventure (USA)" index="" image=""> <description>Pitfall - The Mayan Adventure (USA)</description> <cloneof /> <crc>03e67d38</crc> <manufacturer>Activision</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pit-Fighter (USA)" index="" image=""> <description>Pit-Fighter (USA)</description> <cloneof /> <crc>9fab69fc</crc> <manufacturer>THQ</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Plok! (USA)" index="" image=""> <description>Plok! (USA)</description> <cloneof /> <crc>bbd678f6</crc> <manufacturer>Tradewest</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pocky & Rocky (USA)" index="" image=""> <description>Pocky & Rocky (USA)</description> <cloneof /> <crc>2b0e7ea3</crc> <manufacturer>Natsume</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pocky & Rocky 2 (USA)" index="" image=""> <description>Pocky & Rocky 2 (USA)</description> <cloneof /> <crc>fc00bb1b</crc> <manufacturer>Natsume</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pop'n TwinBee - Rainbow Bell Adventures (Europe)" index="" image=""> <description>Pop'n TwinBee - Rainbow Bell Adventures (Europe)</description> <cloneof /> <crc>91a03035</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pop'n TwinBee (Europe)" index="" image=""> <description>Pop'n TwinBee (Europe)</description> <cloneof /> <crc>588a9707</crc> <manufacturer>Palcom</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Populous (USA)" index="" image=""> <description>Populous (USA)</description> <cloneof /> <crc>2df4aa0f</crc> <manufacturer>Acclaim</manufacturer> <year>1991</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Populous II - Trials of the Olympian Gods (Europe)" index="" image=""> <description>Populous II - Trials of the Olympian Gods (Europe)</description> <cloneof /> <crc>6c28cc39</crc> <manufacturer>Imagineer</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Porky Pig's Haunted Holiday (USA)" index="" image=""> <description>Porky Pig's Haunted Holiday (USA)</description> <cloneof /> <crc>f09e91a1</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Power Drive (Europe)" index="" image=""> <description>Power Drive (Europe)</description> <cloneof /> <crc>0bfdca70</crc> <manufacturer>U.S. Gold</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Power Instinct (USA)" index="" image=""> <description>Power Instinct (USA)</description> <cloneof /> <crc>cb8a4f8e</crc> <manufacturer>Atlus</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Power Moves (USA)" index="" image=""> <description>Power Moves (USA)</description> <cloneof /> <crc>c2e094b5</crc> <manufacturer>Kaneko</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Power Piggs of the Dark Age (USA)" index="" image=""> <description>Power Piggs of the Dark Age (USA)</description> <cloneof /> <crc>e945530d</crc> <manufacturer>Titus</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Power Rangers Zeo - Battle Racers (USA)" index="" image=""> <description>Power Rangers Zeo - Battle Racers (USA)</description> <cloneof /> <crc>389300cf</crc> <manufacturer>Bandai</manufacturer> <year>1996</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="PowerMonger (Europe)" index="" image=""> <description>PowerMonger (Europe)</description> <cloneof /> <crc>bc06f982</crc> <manufacturer>Imagineer</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Prehistorik Man (USA)" index="" image=""> <description>Prehistorik Man (USA)</description> <cloneof /> <crc>cb4f87bb</crc> <manufacturer>Titus</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Primal Rage (USA)" index="" image=""> <description>Primal Rage (USA)</description> <cloneof /> <crc>3753e4b6</crc> <manufacturer>Bitmasters</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Prince of Persia (USA)" index="" image=""> <description>Prince of Persia (USA)</description> <cloneof /> <crc>891bb2bb</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Prince of Persia 2 - The Shadow & The Flame (USA)" index="" image=""> <description>Prince of Persia 2 - The Shadow & The Flame (USA)</description> <cloneof /> <crc>50581d9d</crc> <manufacturer>Titus</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pro Quarterback (USA)" index="" image=""> <description>Pro Quarterback (USA)</description> <cloneof /> <crc>6910626d</crc> <manufacturer>Tradewest</manufacturer> <year>1992</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Pro Sport Hockey (USA)" index="" image=""> <description>Pro Sport Hockey (USA)</description> <cloneof /> <crc>a9cc0a74</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Push-Over (USA)" index="" image=""> <description>Push-Over (USA)</description> <cloneof /> <crc>fa06d5f5</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Putty Squad (Europe)" index="" image=""> <description>Putty Squad (Europe)</description> <cloneof /> <crc>c061f0a8</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Q-bert 3 (USA)" index="true" image="q"> <description>Q-bert 3 (USA)</description> <cloneof /> <crc>694cbfe4</crc> <manufacturer>NTVIC</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="R.P.M. Racing (USA)" index="" image=""> <description>R.P.M. Racing (USA)</description> <cloneof /> <crc>f7933734</crc> <manufacturer>Interplay</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Race Drivin' (USA)" index="" image=""> <description>Race Drivin' (USA)</description> <cloneof /> <crc>c5bab870</crc> <manufacturer>THQ</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Radical Rex (USA)" index="" image=""> <description>Radical Rex (USA)</description> <cloneof /> <crc>e2b8da18</crc> <manufacturer>Activision</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Raiden Trad (USA)" index="" image=""> <description>Raiden Trad (USA)</description> <cloneof /> <crc>02ce6c96</crc> <manufacturer>Electro Brain</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rampart (USA)" index="" image=""> <description>Rampart (USA)</description> <cloneof /> <crc>aed8892a</crc> <manufacturer>Electronic Arts</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ranma 1-2 - Hard Battle (USA)" index="" image=""> <description>Ranma 1-2 - Hard Battle (USA)</description> <cloneof /> <crc>8e4dadcd</crc> <manufacturer>NCS</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rap Jam - Volume One (USA)" index="" image=""> <description>Rap Jam - Volume One (USA)</description> <cloneof /> <crc>adf4ffce</crc> <manufacturer>Mandingo</manufacturer> <year>1995</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Realm (USA)" index="" image=""> <description>Realm (USA)</description> <cloneof /> <crc>0744ba5b</crc> <manufacturer>Titus</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Redline F-1 Racer (USA)" index="" image=""> <description>Redline F-1 Racer (USA)</description> <cloneof /> <crc>e5faadd2</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Relief Pitcher (USA)" index="" image=""> <description>Relief Pitcher (USA)</description> <cloneof /> <crc>2f48ff14</crc> <manufacturer>Left Field Productions</manufacturer> <year>1994</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ren & Stimpy Show, The - Buckeroos! (USA)" index="" image=""> <description>Ren & Stimpy Show, The - Buckeroos! (USA)</description> <cloneof /> <crc>672ebf39</crc> <manufacturer>THQ</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ren & Stimpy Show, The - Fire Dogs (USA)" index="" image=""> <description>Ren & Stimpy Show, The - Fire Dogs (USA)</description> <cloneof /> <crc>0b472197</crc> <manufacturer>THQ</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ren & Stimpy Show, The - Time Warp (USA)" index="" image=""> <description>Ren & Stimpy Show, The - Time Warp (USA)</description> <cloneof /> <crc>de8fe3e8</crc> <manufacturer>THQ</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ren & Stimpy Show, The - Veediots! (USA)" index="" image=""> <description>Ren & Stimpy Show, The - Veediots! (USA)</description> <cloneof /> <crc>fd1c12a3</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rendering Ranger R2 (Japan - Translated)" index="" image=""> <description>Rendering Ranger R2 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Rainbow Arts / Virgin Interactive</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Revolution X (USA)" index="" image=""> <description>Revolution X (USA)</description> <cloneof /> <crc>0dc5e7ba</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rex Ronan - Experimental Surgeon (USA)" index="" image=""> <description>Rex Ronan - Experimental Surgeon (USA)</description> <cloneof /> <crc>105ac679</crc> <manufacturer>Raya Systems</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Riddick Bowe Boxing (USA)" index="" image=""> <description>Riddick Bowe Boxing (USA)</description> <cloneof /> <crc>a967a041</crc> <manufacturer>Extreme Entertainment Group</manufacturer> <year>1993</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rise of the Phoenix (USA)" index="" image=""> <description>Rise of the Phoenix (USA)</description> <cloneof /> <crc>908b90b1</crc> <manufacturer>Koei</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rise of the Robots (USA)" index="" image=""> <description>Rise of the Robots (USA)</description> <cloneof /> <crc>83ba0ac0</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rival Turf! (USA)" index="" image=""> <description>Rival Turf! (USA)</description> <cloneof /> <crc>ca988f59</crc> <manufacturer>Jaleco</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Road Riot 4WD (USA)" index="" image=""> <description>Road Riot 4WD (USA)</description> <cloneof /> <crc>20367643</crc> <manufacturer>THQ</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Road Runner's Death Valley Rally (USA)" index="" image=""> <description>Road Runner's Death Valley Rally (USA)</description> <cloneof /> <crc>5980d75d</crc> <manufacturer>Sun Soft</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="RoboCop 3 (USA)" index="" image=""> <description>RoboCop 3 (USA)</description> <cloneof /> <crc>3502f9b3</crc> <manufacturer>Ocean</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="RoboCop versus The Terminator (USA)" index="" image=""> <description>RoboCop versus The Terminator (USA)</description> <cloneof /> <crc>f5ab5d91</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Robotrek (USA)" index="" image=""> <description>Robotrek (USA)</description> <cloneof /> <crc>7ad4aadc</crc> <manufacturer>Enix</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rock n' Roll Racing (USA)" index="" image=""> <description>Rock n' Roll Racing (USA)</description> <cloneof /> <crc>7d06f473</crc> <manufacturer>Blizzard Entertainment</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rocketeer, The (USA)" index="" image=""> <description>Rocketeer, The (USA)</description> <cloneof /> <crc>4c68a3c7</crc> <manufacturer>IGS</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rockman & Forte (Japan - Translated)" index="" image=""> <description>Rockman & Forte (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Capcom</manufacturer> <year>1998</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rocko's Modern Life - Spunky's Dangerous Day (USA)" index="" image=""> <description>Rocko's Modern Life - Spunky's Dangerous Day (USA)</description> <cloneof /> <crc>197b4cba</crc> <manufacturer>Viacom New Media</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rocky Rodent (USA)" index="" image=""> <description>Rocky Rodent (USA)</description> <cloneof /> <crc>c81a7b07</crc> <manufacturer>Irem</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Roger Clemens' MVP Baseball (USA) (Rev 1)" index="" image=""> <description>Roger Clemens' MVP Baseball (USA) (Rev 1)</description> <cloneof /> <crc>a012d1ad</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1992</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Romance of the Three Kingdoms II (USA)" index="" image=""> <description>Romance of the Three Kingdoms II (USA)</description> <cloneof /> <crc>8033574a</crc> <manufacturer>Koei</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Romance of the Three Kingdoms III - Dragon of Destiny (USA)" index="" image=""> <description>Romance of the Three Kingdoms III - Dragon of Destiny (USA)</description> <cloneof /> <crc>523b0d02</crc> <manufacturer>Koei</manufacturer> <year>1994</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Romance of the Three Kingdoms IV - Wall of Fire (USA)" index="" image=""> <description>Romance of the Three Kingdoms IV - Wall of Fire (USA)</description> <cloneof /> <crc>82af5b69</crc> <manufacturer>Koei</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Romancing SaGa 3 (Japan - Translated)" index="" image=""> <description>Romancing SaGa 3 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Squaresoft</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="R-Type III - The Third Lightning (USA)" index="true" image="r"> <description>R-Type III - The Third Lightning (USA)</description> <cloneof /> <crc>642b656b</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Rudra no Hihou (Japan - Translated)" index="" image=""> <description>Rudra no Hihou (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>SquareSoft / Square Enix</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Run Saber (USA)" index="" image=""> <description>Run Saber (USA)</description> <cloneof /> <crc>8708e5bb</crc> <manufacturer>Atlus</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sailormoon (France)" index="true" image="s"> <description>Sailormoon (France)</description> <cloneof /> <crc>CD89020D</crc> <manufacturer>Bandai</manufacturer> <year>1994</year> <genre>Beat-'Em-Up</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Samurai Shodown (USA)" index="" image=""> <description>Samurai Shodown (USA)</description> <cloneof /> <crc>2e614a53</crc> <manufacturer>Takara</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Saturday Night Slam Masters (USA)" index="" image=""> <description>Saturday Night Slam Masters (USA)</description> <cloneof /> <crc>54161830</crc> <manufacturer>Capcom</manufacturer> <year>1996</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Scooby-Doo Mystery (USA)" index="" image=""> <description>Scooby-Doo Mystery (USA)</description> <cloneof /> <crc>98d7611e</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SeaQuest DSV (USA)" index="" image=""> <description>SeaQuest DSV (USA)</description> <cloneof /> <crc>a6579e03</crc> <manufacturer>Malibu</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Secret of Evermore (USA)" index="" image=""> <description>Secret of Evermore (USA)</description> <cloneof /> <crc>a5c0045e</crc> <manufacturer>SquareSoft</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Secret of Mana (USA)" index="" image=""> <description>Secret of Mana (USA)</description> <cloneof /> <crc>d0176b24</crc> <manufacturer>SquareSoft</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Seiken Densetsu 3 (Japan - Translated)" index="" image=""> <description>Seiken Densetsu 3 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>SquareSoft / Square Enix</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shadow, The (USA) (Proto)" index="" image=""> <description>Shadow, The (USA) (Proto)</description> <cloneof /> <crc>13380511</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre /> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shadowrun (USA)" index="" image=""> <description>Shadowrun (USA)</description> <cloneof /> <crc>3f34dff0</crc> <manufacturer>Data East</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shanghai II - Dragon's Eye (USA)" index="" image=""> <description>Shanghai II - Dragon's Eye (USA)</description> <cloneof /> <crc>2fec70b6</crc> <manufacturer>Activision</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shaq Fu (USA)" index="" image=""> <description>Shaq Fu (USA)</description> <cloneof /> <crc>52916c9d</crc> <manufacturer>Electronic Arts</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shien's Revenge (USA)" index="" image=""> <description>Shien's Revenge (USA)</description> <cloneof /> <crc>5bb2e6c3</crc> <manufacturer>Vic Tokai</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shin Kidou Senki Gundam W - Endless Duel (Japan - Translated)" index="" image=""> <description>Shin Kidou Senki Gundam W - Endless Duel (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>BanDai</manufacturer> <year>1996</year> <genre>Fighting</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Shin Nekketsu Kouha - Kunio-tachi no Banka (Japan - Translated)" index="" image=""> <description>Shin Nekketsu Kouha - Kunio-tachi no Banka (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Almanic Corp. / Technos Japan</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Side Pocket (USA)" index="" image=""> <description>Side Pocket (USA)</description> <cloneof /> <crc>597c2bfe</crc> <manufacturer>Data East</manufacturer> <year>1993</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SimAnt (USA)" index="" image=""> <description>SimAnt (USA)</description> <cloneof /> <crc>d08c05df</crc> <manufacturer>Maxis</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SimCity (USA)" index="" image=""> <description>SimCity (USA)</description> <cloneof /> <crc>8aedd3a1</crc> <manufacturer>Nintendo</manufacturer> <year>1991</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SimCity 2000 (USA)" index="" image=""> <description>SimCity 2000 (USA)</description> <cloneof /> <crc>2d5dc011</crc> <manufacturer>Black Pearl</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SimEarth - The Living Planet (USA)" index="" image=""> <description>SimEarth - The Living Planet (USA)</description> <cloneof /> <crc>7fa5b218</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Simpsons, The - Bart's Nightmare (USA)" index="" image=""> <description>Simpsons, The - Bart's Nightmare (USA)</description> <cloneof /> <crc>ed1c03c2</crc> <manufacturer>Acclaim</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sink or Swim (USA)" index="" image=""> <description>Sink or Swim (USA)</description> <cloneof /> <crc>dd329f85</crc> <manufacturer>Titus</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Skuljagger - Revolt of the Westicans (USA)" index="" image=""> <description>Skuljagger - Revolt of the Westicans (USA)</description> <cloneof /> <crc>e58a6d01</crc> <manufacturer>American Softworks</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Skyblazer (USA)" index="" image=""> <description>Skyblazer (USA)</description> <cloneof /> <crc>f13b00b0</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Slayers (Japan - Translated)" index="" image=""> <description>Slayers (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Bec / Banpresto</manufacturer> <year>1994</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Smart Ball (USA)" index="" image=""> <description>Smart Ball (USA)</description> <cloneof /> <crc>3cfe77ab</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1991</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Smash Tennis (Europe)" index="" image=""> <description>Smash Tennis (Europe)</description> <cloneof /> <crc>6f7d1745</crc> <manufacturer>Namco</manufacturer> <year>1993</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Smurfs Travel the World, The (Europe)" index="" image=""> <description>Smurfs Travel the World, The (Europe)</description> <cloneof /> <crc>22947169</crc> <manufacturer>Infogrames</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Smurfs, The (Europe)" index="" image=""> <description>Smurfs, The (Europe)</description> <cloneof /> <crc>2ae148d6</crc> <manufacturer>Infogrames</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Snow White in Happily Ever After (USA)" index="" image=""> <description>Snow White in Happily Ever After (USA)</description> <cloneof /> <crc>d68d1ab3</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Soldiers of Fortune (USA)" index="" image=""> <description>Soldiers of Fortune (USA)</description> <cloneof /> <crc>cf719a93</crc> <manufacturer>Spectrum Holobyte</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sonic Blast Man (USA)" index="" image=""> <description>Sonic Blast Man (USA)</description> <cloneof /> <crc>8886396e</crc> <manufacturer>Taito</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sonic Blast Man II (USA)" index="" image=""> <description>Sonic Blast Man II (USA)</description> <cloneof /> <crc>24229a34</crc> <manufacturer>Taito</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SOS (USA)" index="" image=""> <description>SOS (USA)</description> <cloneof /> <crc>09ae53f5</crc> <manufacturer>Vic Tokai</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Soul Blazer (USA)" index="" image=""> <description>Soul Blazer (USA)</description> <cloneof /> <crc>31b965db</crc> <manufacturer>Enix</manufacturer> <year>1992</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Space Ace (USA)" index="" image=""> <description>Space Ace (USA)</description> <cloneof /> <crc>f4bb0888</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Space Football - One on One (USA)" index="" image=""> <description>Space Football - One on One (USA)</description> <cloneof /> <crc>55dcf09e</crc> <manufacturer>Triffix</manufacturer> <year>1992</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Space Invaders - The Original Game (USA)" index="" image=""> <description>Space Invaders - The Original Game (USA)</description> <cloneof /> <crc>caf035f5</crc> <manufacturer>Nintendo</manufacturer> <year>1997</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Space Megaforce (USA)" index="" image=""> <description>Space Megaforce (USA)</description> <cloneof /> <crc>11202781</crc> <manufacturer>Toho</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spanky's Quest (USA)" index="" image=""> <description>Spanky's Quest (USA)</description> <cloneof /> <crc>ca68c5c3</crc> <manufacturer>Natsume</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sparkster (USA)" index="" image=""> <description>Sparkster (USA)</description> <cloneof /> <crc>40d11c94</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spawn (USA)" index="" image=""> <description>Spawn (USA)</description> <cloneof /> <crc>4e1dafd0</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spectre (USA)" index="" image=""> <description>Spectre (USA)</description> <cloneof /> <crc>ade6e0d8</crc> <manufacturer>Cybersoft</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Speed Racer in My Most Dangerous Adventures (USA)" index="" image=""> <description>Speed Racer in My Most Dangerous Adventures (USA)</description> <cloneof /> <crc>aa44287c</crc> <manufacturer>Accolade</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Speedy Gonzales - Los Gatos Bandidos (USA) (Rev 1)" index="" image=""> <description>Speedy Gonzales - Los Gatos Bandidos (USA) (Rev 1)</description> <cloneof /> <crc>cb0653d0</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spider-Man (USA)" index="" image=""> <description>Spider-Man (USA)</description> <cloneof /> <crc>c99e174e</crc> <manufacturer>LJN</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spider-Man-Venom - Maximum Carnage (USA)" index="" image=""> <description>Spider-Man-Venom - Maximum Carnage (USA)</description> <cloneof /> <crc>7ef2bb0c</crc> <manufacturer>LJN</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spider-Man-X-Men - Arcade's Revenge (USA)" index="" image=""> <description>Spider-Man-X-Men - Arcade's Revenge (USA)</description> <cloneof /> <crc>ae878ccb</crc> <manufacturer>LJN</manufacturer> <year>1992</year> <genre>platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spindizzy Worlds (USA)" index="" image=""> <description>Spindizzy Worlds (USA)</description> <cloneof /> <crc>52b68163</crc> <manufacturer>ASCII Entertainment</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Spirou (Europe)" index="" image=""> <description>Spirou (Europe)</description> <cloneof /> <crc>797e2e82</crc> <manufacturer>Infogrames</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sporting News Power Baseball, The (USA)" index="" image=""> <description>Sporting News Power Baseball, The (USA)</description> <cloneof /> <crc>315af696</crc> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sports Illustrated Championship Football & Baseball (USA)" index="" image=""> <description>Sports Illustrated Championship Football & Baseball (USA)</description> <cloneof /> <crc>d4874966</crc> <manufacturer>Malibu</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Fox (USA) (Rev 2)" index="" image=""> <description>Star Fox (USA) (Rev 2)</description> <cloneof /> <crc>8fc4e6d0</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Fox (USA) (Super Weekend Competition)" index="" image=""> <description>Star Fox (USA) (Super Weekend Competition)</description> <cloneof /> <crc>cd1f04b8</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Ocean (Japan - Translated)" index="" image=""> <description>Star Ocean (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Tri-Ace / Enix</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Trek - Deep Space Nine - Crossroads of Time (USA)" index="" image=""> <description>Star Trek - Deep Space Nine - Crossroads of Time (USA)</description> <cloneof /> <crc>9a245fa3</crc> <manufacturer>Playmates</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Trek - Starfleet Academy - Starship Bridge Simulator (USA)" index="" image=""> <description>Star Trek - Starfleet Academy - Starship Bridge Simulator (USA)</description> <cloneof /> <crc>2db38d24</crc> <manufacturer>Interplay</manufacturer> <year>1994</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Star Trek - The Next Generation - Future's Past (USA)" index="" image=""> <description>Star Trek - The Next Generation - Future's Past (USA)</description> <cloneof /> <crc>8de80428</crc> <manufacturer>Spectrum Holobyte</manufacturer> <year>1995</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Stargate (USA)" index="" image=""> <description>Stargate (USA)</description> <cloneof /> <crc>526ce576</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Steel Talons (USA)" index="" image=""> <description>Steel Talons (USA)</description> <cloneof /> <crc>4ea9f93f</crc> <manufacturer>Left Field Productions</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sterling Sharpe - End 2 End (USA)" index="" image=""> <description>Sterling Sharpe - End 2 End (USA)</description> <cloneof /> <crc>70d9c906</crc> <manufacturer>Jaleco</manufacturer> <year>1995</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Stone Protectors (USA)" index="" image=""> <description>Stone Protectors (USA)</description> <cloneof /> <crc>a7e58592</crc> <manufacturer>Kemco</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Combat (USA)" index="" image=""> <description>Street Combat (USA)</description> <cloneof /> <crc>1969bbd9</crc> <manufacturer>Irem</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Fighter Alpha 2 (USA)" index="" image=""> <description>Street Fighter Alpha 2 (USA)</description> <cloneof /> <crc>9c59ddff</crc> <manufacturer>Capcom</manufacturer> <year>1996</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Fighter II (USA)" index="" image=""> <description>Street Fighter II (USA)</description> <cloneof /> <crc>bc3dcd9d</crc> <manufacturer>Capcom</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Fighter II Turbo (USA)" index="" image=""> <description>Street Fighter II Turbo (USA)</description> <cloneof /> <crc>a45cadd6</crc> <manufacturer>Capcom</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Hockey '95 (USA)" index="" image=""> <description>Street Hockey '95 (USA)</description> <cloneof /> <crc>97357a1b</crc> <manufacturer>GTE Entertainment</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Street Racer (USA)" index="" image=""> <description>Street Racer (USA)</description> <cloneof /> <crc>63e8b7d5</crc> <manufacturer>Ubisoft</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Strike Gunner S.T.G (USA)" index="" image=""> <description>Strike Gunner S.T.G (USA)</description> <cloneof /> <crc>d054e288</crc> <manufacturer>NTVIC</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Stunt Race FX (USA) (Rev 1)" index="" image=""> <description>Stunt Race FX (USA) (Rev 1)</description> <cloneof /> <crc>380c2635</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Sunset Riders (USA)" index="" image=""> <description>Sunset Riders (USA)</description> <cloneof /> <crc>52ada404</crc> <manufacturer>Konami</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Adventure Island (USA)" index="" image=""> <description>Super Adventure Island (USA)</description> <cloneof /> <crc>dcd46848</crc> <manufacturer>Hudson</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Adventure Island II (USA)" index="" image=""> <description>Super Adventure Island II (USA)</description> <cloneof /> <crc>52fe16fd</crc> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Alfred Chicken (USA)" index="" image=""> <description>Super Alfred Chicken (USA)</description> <cloneof /> <crc>f21c5a9d</crc> <manufacturer>Mindscape</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Aquatic Games Starring the Aquabats, The (USA)" index="" image=""> <description>Super Aquatic Games Starring the Aquabats, The (USA)</description> <cloneof /> <crc>2a5ddac0</crc> <manufacturer>Seika Corp.</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Back to the Future Part II (Japan - Translated)" index="" image=""> <description>Super Back to the Future Part II (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Daft</manufacturer> <year>1993</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Baseball Simulator 1.000 (USA)" index="" image=""> <description>Super Baseball Simulator 1.000 (USA)</description> <cloneof /> <crc>aa760fec</crc> <manufacturer>Culture Brain</manufacturer> <year>1991</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bases Loaded (USA)" index="" image=""> <description>Super Bases Loaded (USA)</description> <cloneof /> <crc>6b971f1e</crc> <manufacturer>Jaleco</manufacturer> <year>1991</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bases Loaded 3 - License to Steal (USA)" index="" image=""> <description>Super Bases Loaded 3 - License to Steal (USA)</description> <cloneof /> <crc>f0540d1b</crc> <manufacturer>Jaleco</manufacturer> <year>1995</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bases Loaded II (USA)" index="" image=""> <description>Super Bases Loaded II (USA)</description> <cloneof /> <crc>e14128ca</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Batter Up (USA)" index="" image=""> <description>Super Batter Up (USA)</description> <cloneof /> <crc>5896c854</crc> <manufacturer>Namco</manufacturer> <year>1992</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Battleship (USA)" index="" image=""> <description>Super Battleship (USA)</description> <cloneof /> <crc>6fcea1a1</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Battletank - War in the Gulf (USA) (Rev 1)" index="" image=""> <description>Super Battletank - War in the Gulf (USA) (Rev 1)</description> <cloneof /> <crc>77811b34</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1992</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Battletank 2 (USA)" index="" image=""> <description>Super Battletank 2 (USA)</description> <cloneof /> <crc>70a292d6</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1993</year> <genre>Simulation</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Black Bass (USA)" index="" image=""> <description>Super Black Bass (USA)</description> <cloneof /> <crc>57d9fd61</crc> <manufacturer>Hot-B</manufacturer> <year>1993</year> <genre>Sports/Fishing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bomberman (USA)" index="" image=""> <description>Super Bomberman (USA)</description> <cloneof /> <crc>63a8e2c6</crc> <manufacturer>Hudson</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bomberman 2 (USA)" index="" image=""> <description>Super Bomberman 2 (USA)</description> <cloneof /> <crc>9c1f11e4</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bomberman 3 (Europe)" index="" image=""> <description>Super Bomberman 3 (Europe)</description> <cloneof /> <crc>a096a6e5</crc> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bomberman 4 (Japan - Translated)" index="" image=""> <description>Super Bomberman 4 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bomberman 5 (Japan)" index="" image=""> <description>Super Bomberman 5 (Japan)</description> <cloneof /> <crc>a096a6e5</crc> <manufacturer>Hudson</manufacturer> <year>1997</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bonk (USA)" index="" image=""> <description>Super Bonk (USA)</description> <cloneof /> <crc>5688b581</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Bowling (USA)" index="" image=""> <description>Super Bowling (USA)</description> <cloneof /> <crc>94945b50</crc> <manufacturer>Technos</manufacturer> <year>1992</year> <genre>Sports/Bowling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Buster Bros. (USA) (Rev 1)" index="" image=""> <description>Super Buster Bros. (USA) (Rev 1)</description> <cloneof /> <crc>9526d1aa</crc> <manufacturer>Capcom</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Caesars Palace (USA)" index="" image=""> <description>Super Caesars Palace (USA)</description> <cloneof /> <crc>a2381221</crc> <manufacturer>Virgion</manufacturer> <year>1993</year> <genre>Casino</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Castlevania IV (USA)" index="" image=""> <description>Super Castlevania IV (USA)</description> <cloneof /> <crc>b64ffb12</crc> <manufacturer>Konami</manufacturer> <year>1991</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Chase H.Q. (USA)" index="" image=""> <description>Super Chase H.Q. (USA)</description> <cloneof /> <crc>6ef3b9c7</crc> <manufacturer>Taito</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Conflict - The Mideast (USA)" index="" image=""> <description>Super Conflict - The Mideast (USA)</description> <cloneof /> <crc>f254d5cf</crc> <manufacturer>Vic Tokai</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Copa (Brazil) (Es,Pt)" index="" image=""> <description>Super Copa (Brazil) (Es,Pt)</description> <cloneof /> <crc>49e53877</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Soccer/Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Dany (France)" index="" image=""> <description>Super Dany (France)</description> <cloneof /> <crc>0F578F67</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1998</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Double Dragon (USA)" index="" image=""> <description>Super Double Dragon (USA)</description> <cloneof /> <crc>09ed12a5</crc> <manufacturer>Tradewest</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Genjin 2 (Japan - Translated)" index="" image=""> <description>Super Genjin 2 (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Platformer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Ghouls'n Ghosts (USA)" index="" image=""> <description>Super Ghouls'n Ghosts (USA)</description> <cloneof /> <crc>6aaba901</crc> <manufacturer>Capcom</manufacturer> <year>1991</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Goal! 2 (USA)" index="" image=""> <description>Super Goal! 2 (USA)</description> <cloneof /> <crc>c5829306</crc> <manufacturer>Jaleco</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Godzilla (USA)" index="" image=""> <description>Super Godzilla (USA)</description> <cloneof /> <crc>6a187c70</crc> <manufacturer>Toho</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super High Impact (USA)" index="" image=""> <description>Super High Impact (USA)</description> <cloneof /> <crc>2eed70fb</crc> <manufacturer>Acclaim</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Ice Hockey (Europe)" index="" image=""> <description>Super Ice Hockey (Europe)</description> <cloneof /> <crc>fb1d16c4</crc> <manufacturer>Sun Soft</manufacturer> <year>1994</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super International Cricket (Europe)" index="" image=""> <description>Super International Cricket (Europe)</description> <cloneof /> <crc>89cd72b0</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super James Pond (USA)" index="" image=""> <description>Super James Pond (USA)</description> <cloneof /> <crc>d7c34122</crc> <manufacturer>American Softworks</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario All-Stars (USA)" index="" image=""> <description>Super Mario All-Stars (USA)</description> <cloneof /> <crc>925637c7</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario All-Stars + Super Mario World (USA)" index="" image=""> <description>Super Mario All-Stars + Super Mario World (USA)</description> <cloneof /> <crc>f84305b1</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario Kart (USA)" index="" image=""> <description>Super Mario Kart (USA)</description> <cloneof /> <crc>cd80db86</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario RPG - Legend of the Seven Stars (USA)" index="" image=""> <description>Super Mario RPG - Legend of the Seven Stars (USA)</description> <cloneof /> <crc>1b8a0625</crc> <manufacturer>SquareSoft</manufacturer> <year>1996</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario World (USA)" index="" image=""> <description>Super Mario World (USA)</description> <cloneof /> <crc>b19ed489</crc> <manufacturer>Nintendo</manufacturer> <year>1991</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Mario World 2 - Yoshi's Island (USA) (Rev 1)" index="" image=""> <description>Super Mario World 2 - Yoshi's Island (USA) (Rev 1)</description> <cloneof /> <crc>cf98ddaa</crc> <manufacturer>Nintendo</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Metroid (Japan, USA)" index="" image=""> <description>Super Metroid (Japan, USA)</description> <cloneof /> <crc>d63ed5f8</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Morph (Europe)" index="" image=""> <description>Super Morph (Europe)</description> <cloneof /> <crc>388f6daa</crc> <manufacturer>Sony Imagesoft</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Ninja Boy (USA)" index="" image=""> <description>Super Ninja Boy (USA)</description> <cloneof /> <crc>6bcbba10</crc> <manufacturer>Culture Brain</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Noah's Ark 3D (USA) (Unl)" index="" image=""> <description>Super Noah's Ark 3D (USA) (Unl)</description> <cloneof /> <crc>A2315A14</crc> <manufacturer>Wisdom Tree</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Nova (USA)" index="" image=""> <description>Super Nova (USA)</description> <cloneof /> <crc>460def25</crc> <manufacturer>Taito</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Off Road - The Baja (USA)" index="" image=""> <description>Super Off Road - The Baja (USA)</description> <cloneof /> <crc>cb483ead</crc> <manufacturer>Tradewest</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Off Road (USA)" index="" image=""> <description>Super Off Road (USA)</description> <cloneof /> <crc>fe263383</crc> <manufacturer>Tradewest</manufacturer> <year>1991</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Pinball - Behind the Mask (USA) (Rev 1)" index="" image=""> <description>Super Pinball - Behind the Mask (USA) (Rev 1)</description> <cloneof /> <crc>008463a0</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Pinball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Play Action Football (USA)" index="" image=""> <description>Super Play Action Football (USA)</description> <cloneof /> <crc>0f359a60</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Punch-Out!! (USA)" index="" image=""> <description>Super Punch-Out!! (USA)</description> <cloneof /> <crc>e2f92f84</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Putty (USA)" index="" image=""> <description>Super Putty (USA)</description> <cloneof /> <crc>746087c1</crc> <manufacturer>U.S. Gold</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super R.B.I. Baseball (USA)" index="" image=""> <description>Super R.B.I. Baseball (USA)</description> <cloneof /> <crc>31db6cfe</crc> <manufacturer>Time Warner</manufacturer> <year>1995</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super R-Type (USA)" index="" image=""> <description>Super R-Type (USA)</description> <cloneof /> <crc>8b22c830</crc> <manufacturer>Irem</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Scope 6 (USA)" index="" image=""> <description>Super Scope 6 (USA)</description> <cloneof /> <crc>b141ea99</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Slam Dunk (USA)" index="" image=""> <description>Super Slam Dunk (USA)</description> <cloneof /> <crc>3effc9e5</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Slap Shot (USA)" index="" image=""> <description>Super Slap Shot (USA)</description> <cloneof /> <crc>7355c9b9</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Smash T.V. (USA)" index="" image=""> <description>Super Smash T.V. (USA)</description> <cloneof /> <crc>2d0b20d0</crc> <manufacturer>Acclaim</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Soccer (USA)" index="" image=""> <description>Super Soccer (USA)</description> <cloneof /> <crc>4fd164d8</crc> <manufacturer>Nintendo</manufacturer> <year>1992</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Soccer Champ (USA)" index="" image=""> <description>Super Soccer Champ (USA)</description> <cloneof /> <crc>b31d35a5</crc> <manufacturer>Taito</manufacturer> <year>1992</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Solitaire (USA)" index="" image=""> <description>Super Solitaire (USA)</description> <cloneof /> <crc>c8e80d55</crc> <manufacturer>Extreme Entertainment Group</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Star Wars - Return of the Jedi (USA) (Rev 1)" index="" image=""> <description>Super Star Wars - Return of the Jedi (USA) (Rev 1)</description> <cloneof /> <crc>4a5f30d8</crc> <manufacturer>Victor Interactive Software</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Star Wars - The Empire Strikes Back (USA) (Rev 1)" index="" image=""> <description>Super Star Wars - The Empire Strikes Back (USA) (Rev 1)</description> <cloneof /> <crc>1e7ea62c</crc> <manufacturer>JVC Musical Industries, Inc.</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Star Wars (USA) (Rev 1)" index="" image=""> <description>Super Star Wars (USA) (Rev 1)</description> <cloneof /> <crc>be47f6c6</crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Street Fighter II (USA)" index="" image=""> <description>Super Street Fighter II (USA)</description> <cloneof /> <crc>f16d5ce9</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Strike Eagle (USA)" index="" image=""> <description>Super Strike Eagle (USA)</description> <cloneof /> <crc>ecf79841</crc> <manufacturer>Asmik Ace Entertainment, Inc</manufacturer> <year>1993</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Tennis (USA)" index="" image=""> <description>Super Tennis (USA)</description> <cloneof /> <crc>8d383776</crc> <manufacturer>Nintendo</manufacturer> <year>1991</year> <genre>Sports/Tennis</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Troll Islands (USA)" index="" image=""> <description>Super Troll Islands (USA)</description> <cloneof /> <crc>f9690be9</crc> <manufacturer>ASC Games</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Turrican (USA)" index="" image=""> <description>Super Turrican (USA)</description> <cloneof /> <crc>3a7e8215</crc> <manufacturer>Seika Corp.</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Turrican 2 (USA)" index="" image=""> <description>Super Turrican 2 (USA)</description> <cloneof /> <crc>d2ffabac</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Valis IV (USA)" index="" image=""> <description>Super Valis IV (USA)</description> <cloneof /> <crc>29e8ac9f</crc> <manufacturer>Atlus</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Super Widget (USA)" index="" image=""> <description>Super Widget (USA)</description> <cloneof /> <crc>7dd199ec</crc> <manufacturer>Atlus</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Suzuka 8 Hours (USA)" index="" image=""> <description>Suzuka 8 Hours (USA)</description> <cloneof /> <crc>54740b9b</crc> <manufacturer>Namco</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="SWAT Kats - The Radical Squadron (USA)" index="" image=""> <description>SWAT Kats - The Radical Squadron (USA)</description> <cloneof /> <crc>ea2a23fb</crc> <manufacturer>Hudson</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Syndicate (USA)" index="" image=""> <description>Syndicate (USA)</description> <cloneof /> <crc>d74570d3</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Syvalion (Europe)" index="" image=""> <description>Syvalion (Europe)</description> <cloneof /> <crc>f1884ecb</crc> <manufacturer>JVC Digital Studios</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="T2 - The Arcade Game (USA)" index="true" image="t"> <description>T2 - The Arcade Game (USA)</description> <cloneof /> <crc>5dc6b9fe</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tactics Ogre - Let Us Cling Together (Japan - Translated)" index="true" image="t"> <description>Tactics Ogre - Let Us Cling Together (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Quest / Square / Enix</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tales of Phantasia (Japan - Translated)" index="true" image="t"> <description>Tales of Phantasia (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Namco</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Taz-Mania (USA) (Rev 1)" index="" image=""> <description>Taz-Mania (USA) (Rev 1)</description> <cloneof /> <crc>b17230ae</crc> <manufacturer>SunSoft</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Secret of the Stars (USA)" index="" image=""> <description>Tecmo Secret of the Stars (USA)</description> <cloneof /> <crc>ef968ed1</crc> <manufacturer>Tecmo</manufacturer> <year>1995</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Super Baseball (USA)" index="" image=""> <description>Tecmo Super Baseball (USA)</description> <cloneof /> <crc>e302d853</crc> <manufacturer>Tecmo</manufacturer> <year>1994</year> <genre>Sports/Baseball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Super Bowl (USA)" index="" image=""> <description>Tecmo Super Bowl (USA)</description> <cloneof /> <crc>cde3746b</crc> <manufacturer>Tecmo</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Super Bowl II - Special Edition (USA)" index="" image=""> <description>Tecmo Super Bowl II - Special Edition (USA)</description> <cloneof /> <crc>d67d507b</crc> <manufacturer>Tecmo</manufacturer> <year>1994</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Super Bowl III - Final Edition (USA)" index="" image=""> <description>Tecmo Super Bowl III - Final Edition (USA)</description> <cloneof /> <crc>8ef1411f</crc> <manufacturer>Tecmo</manufacturer> <year>1995</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tecmo Super NBA Basketball (USA)" index="" image=""> <description>Tecmo Super NBA Basketball (USA)</description> <cloneof /> <crc>1b6f0b43</crc> <manufacturer>Tecmo</manufacturer> <year>1993</year> <genre>Sports/Basketball</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Teenage Mutant Ninja Turtles - Tournament Fighters (USA)" index="" image=""> <description>Teenage Mutant Ninja Turtles - Tournament Fighters (USA)</description> <cloneof /> <crc>e2fe5dbf</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Teenage Mutant Ninja Turtles IV - Turtles in Time (USA)" index="" image=""> <description>Teenage Mutant Ninja Turtles IV - Turtles in Time (USA)</description> <cloneof /> <crc>5940bd99</crc> <manufacturer>Konami</manufacturer> <year>1992</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tenchi Muyou! Game Hen (Japan - Translated)" index="" image=""> <description>Tenchi Muyou! Game Hen (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Banpresto</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Terminator 2 - Judgment Day (USA)" index="" image=""> <description>Terminator 2 - Judgment Day (USA)</description> <cloneof /> <crc>f729b19e</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Terminator, The (USA)" index="" image=""> <description>Terminator, The (USA)</description> <cloneof /> <crc>d71e6c3b</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Terranigma (Europe)" index="" image=""> <description>Terranigma (Europe)</description> <cloneof /> <crc>974523ff</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tetris & Dr. Mario (USA)" index="" image=""> <description>Tetris & Dr. Mario (USA)</description> <cloneof /> <crc>6c852ef3</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tetris 2 (USA) (Rev 1)" index="" image=""> <description>Tetris 2 (USA) (Rev 1)</description> <cloneof /> <crc>3bc7054a</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tetris Attack (USA)" index="" image=""> <description>Tetris Attack (USA)</description> <cloneof /> <crc>6c128210</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Theme Park (Europe)" index="" image=""> <description>Theme Park (Europe)</description> <cloneof /> <crc>ca0e041c</crc> <manufacturer>Ocean</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Thomas the Tank Engine and Friends (USA)" index="" image=""> <description>Thomas the Tank Engine and Friends (USA)</description> <cloneof /> <crc>bb4cd5a4</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Thunder Spirits (USA)" index="" image=""> <description>Thunder Spirits (USA)</description> <cloneof /> <crc>522fe837</crc> <manufacturer>Seika Corp.</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tick, The (USA)" index="" image=""> <description>Tick, The (USA)</description> <cloneof /> <crc>12ab22a7</crc> <manufacturer>Fox Interactive</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Time Slip (USA)" index="" image=""> <description>Time Slip (USA)</description> <cloneof /> <crc>838d0304</crc> <manufacturer>Vic Tokai</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Time Trax (USA)" index="" image=""> <description>Time Trax (USA)</description> <cloneof /> <crc>f6628157</crc> <manufacturer>Malibu</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Timecop (USA)" index="" image=""> <description>Timecop (USA)</description> <cloneof /> <crc>130b0933</crc> <manufacturer>JVC Musical Industries, Inc.</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Timon & Pumbaa's Jungle Games (USA)" index="" image=""> <description>Timon & Pumbaa's Jungle Games (USA)</description> <cloneof /> <crc>341c6fb0</crc> <manufacturer>THQ</manufacturer> <year>1997</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tin Star (USA)" index="" image=""> <description>Tin Star (USA)</description> <cloneof /> <crc>ec26f75b</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tintin - Prisoners of the Sun (Europe)" index="" image=""> <description>Tintin - Prisoners of the Sun (Europe)</description> <cloneof /> <crc>a94a47be</crc> <manufacturer>Infogrames</manufacturer> <year>1997</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tintin in Tibet (Europe)" index="" image=""> <description>Tintin in Tibet (Europe)</description> <cloneof /> <crc>f1dce2b7</crc> <manufacturer>Infogrames</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tiny Toon Adventures - Buster Busts Loose! (USA)" index="" image=""> <description>Tiny Toon Adventures - Buster Busts Loose! (USA)</description> <cloneof /> <crc>ab48d27a</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tiny Toon Adventures - Wacky Sports Challenge (USA)" index="" image=""> <description>Tiny Toon Adventures - Wacky Sports Challenge (USA)</description> <cloneof /> <crc>afe72ff0</crc> <manufacturer>Konami</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="TKO Super Championship Boxing (USA)" index="" image=""> <description>TKO Super Championship Boxing (USA)</description> <cloneof /> <crc>fd4af462</crc> <manufacturer>Sofel</manufacturer> <year>1992</year> <genre>Sports/Boxing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="TNN Bass Tournament of Champions (USA)" index="" image=""> <description>TNN Bass Tournament of Champions (USA)</description> <cloneof /> <crc>c367b683</crc> <manufacturer>American Softworks</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tom & Jerry (USA)" index="" image=""> <description>Tom & Jerry (USA)</description> <cloneof /> <crc>8b1dafbb</crc> <manufacturer>Hi Tech Expressions</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tommy Moe's Winter Extreme - Skiing and Snowboarding (USA)" index="" image=""> <description>Tommy Moe's Winter Extreme - Skiing and Snowboarding (USA)</description> <cloneof /> <crc>3d005f22</crc> <manufacturer>Electro Brain</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tony Meola's Sidekicks Soccer (USA)" index="" image=""> <description>Tony Meola's Sidekicks Soccer (USA)</description> <cloneof /> <crc>32b658c1</crc> <manufacturer>Electro Brain</manufacturer> <year>1993</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Top Gear (USA)" index="" image=""> <description>Top Gear (USA)</description> <cloneof /> <crc>d34c49b7</crc> <manufacturer>Kemco</manufacturer> <year>1992</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Top Gear 2 (USA)" index="" image=""> <description>Top Gear 2 (USA)</description> <cloneof /> <crc>2b88bee8</crc> <manufacturer>Kemco</manufacturer> <year>1993</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Top Gear 3000 (USA)" index="" image=""> <description>Top Gear 3000 (USA)</description> <cloneof /> <crc>a20be998</crc> <manufacturer>Kemco</manufacturer> <year>1995</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Torneko no Daibouken - Fushigi no Dungeon (Japan - Translated)" index="" image=""> <description>Torneko no Daibouken - Fushigi no Dungeon (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Chunsoft</manufacturer> <year>1993</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Total Carnage (USA)" index="" image=""> <description>Total Carnage (USA)</description> <cloneof /> <crc>e27ff2bc</crc> <manufacturer>Malibu</manufacturer> <year>1993</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Toy Story (USA)" index="" image=""> <description>Toy Story (USA)</description> <cloneof /> <crc>8328822b</crc> <manufacturer>Capcom</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Toys (USA)" index="" image=""> <description>Toys (USA)</description> <cloneof /> <crc>efebf501</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Treasure Hunter G (Japan - Translated)" index="" image=""> <description>Treasure Hunter G (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Squaresoft</manufacturer> <year>1996</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Troddlers (USA)" index="" image=""> <description>Troddlers (USA)</description> <cloneof /> <crc>6a7ff02d</crc> <manufacturer>Seika Corp.</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Troy Aikman NFL Football (USA)" index="" image=""> <description>Troy Aikman NFL Football (USA)</description> <cloneof /> <crc>0b26446b</crc> <manufacturer>Tradewest</manufacturer> <year>1994</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="True Golf Classics - Pebble Beach Golf Links (USA)" index="" image=""> <description>True Golf Classics - Pebble Beach Golf Links (USA)</description> <cloneof /> <crc>18c5ad58</crc> <manufacturer>T&E Soft</manufacturer> <year>1992</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="True Golf Classics - Waialae Country Club (USA)" index="" image=""> <description>True Golf Classics - Waialae Country Club (USA)</description> <cloneof /> <crc>e9d6c61e</crc> <manufacturer>T&E Soft</manufacturer> <year>1991</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="True Golf Classics - Wicked 18 (USA)" index="" image=""> <description>True Golf Classics - Wicked 18 (USA)</description> <cloneof /> <crc>26177842</crc> <manufacturer>Bullet Proof Software</manufacturer> <year>1993</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="True Lies (USA)" index="" image=""> <description>True Lies (USA)</description> <cloneof /> <crc>40ca49ae</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Tuff E Nuff (USA)" index="" image=""> <description>Tuff E Nuff (USA)</description> <cloneof /> <crc>865f37bf</crc> <manufacturer>Jaleco Entertainment</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Turbo Toons (Europe)" index="" image=""> <description>Turbo Toons (Europe)</description> <cloneof /> <crc>26a9c3f4</crc> <manufacturer>Empire Interactive</manufacturer> <year>1994</year> <genre>Miscellaneous</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Turn and Burn - No-Fly Zone (USA)" index="" image=""> <description>Turn and Burn - No-Fly Zone (USA)</description> <cloneof /> <crc>87bfa0b8</crc> <manufacturer>Absolute Entertainment</manufacturer> <year>1992</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Twisted Tales of Spike McFang, The (USA)" index="" image=""> <description>Twisted Tales of Spike McFang, The (USA)</description> <cloneof /> <crc>8c2068d1</crc> <manufacturer>Naxat Soft</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="U.N. Squadron (USA)" index="true" image="u"> <description>U.N. Squadron (USA)</description> <cloneof /> <crc>231f0f67</crc> <manufacturer>Capcom</manufacturer> <year>1991</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultima - Runes of Virtue II (USA)" index="" image=""> <description>Ultima - Runes of Virtue II (USA)</description> <cloneof /> <crc>cc4eebf4</crc> <manufacturer>Electronic Arts Victor</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultima VI - The False Prophet (USA)" index="" image=""> <description>Ultima VI - The False Prophet (USA)</description> <cloneof /> <crc>9277c9f7</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1992</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultima VII - The Black Gate (USA)" index="" image=""> <description>Ultima VII - The Black Gate (USA)</description> <cloneof /> <crc>e790f52f</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultimate Fighter (USA)" index="" image=""> <description>Ultimate Fighter (USA)</description> <cloneof /> <crc>9dfc8897</crc> <manufacturer>Culture Brain</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultimate Mortal Kombat 3 (USA)" index="" image=""> <description>Ultimate Mortal Kombat 3 (USA)</description> <cloneof /> <crc>f5bfe41e</crc> <manufacturer>Williams</manufacturer> <year>1996</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ultraman - Towards the Future (USA)" index="" image=""> <description>Ultraman - Towards the Future (USA)</description> <cloneof /> <crc>1ded2814</crc> <manufacturer>Bandai</manufacturer> <year>1991</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Uncharted Waters (USA)" index="" image=""> <description>Uncharted Waters (USA)</description> <cloneof /> <crc>95724a2f</crc> <manufacturer>Koei</manufacturer> <year>1992</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Uniracers (USA)" index="" image=""> <description>Uniracers (USA)</description> <cloneof /> <crc>383858c7</crc> <manufacturer>Nintendo</manufacturer> <year>1994</year> <genre>Driving</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Universal Soldier (USA) (Proto)" index="" image=""> <description>Universal Soldier (USA) (Proto)</description> <cloneof /> <crc>59180F1C</crc> <manufacturer>Accolade</manufacturer> <year>1992</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Untouchables, The (USA)" index="" image=""> <description>Untouchables, The (USA)</description> <cloneof /> <crc>c70f2374</crc> <manufacturer>Ocean</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Urban Strike (USA)" index="" image=""> <description>Urban Strike (USA)</description> <cloneof /> <crc>b9bf7990</crc> <manufacturer>Black Pearl</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Utopia - The Creation of a Nation (USA)" index="" image=""> <description>Utopia - The Creation of a Nation (USA)</description> <cloneof /> <crc>252a96c7</crc> <manufacturer>Jaleco</manufacturer> <year>1993</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Vegas Stakes (USA)" index="true" image="v"> <description>Vegas Stakes (USA)</description> <cloneof /> <crc>03a0e935</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Casino</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Venom-Spider-Man - Separation Anxiety (USA)" index="" image=""> <description>Venom-Spider-Man - Separation Anxiety (USA)</description> <cloneof /> <crc>919c509d</crc> <manufacturer>Acclaim</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Virtual Bart (USA)" index="" image=""> <description>Virtual Bart (USA)</description> <cloneof /> <crc>5d0addda</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Virtual Soccer (Europe)" index="" image=""> <description>Virtual Soccer (Europe)</description> <cloneof /> <crc>ecb8a53a</crc> <manufacturer>Hudson</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Vortex (USA)" index="" image=""> <description>Vortex (USA)</description> <cloneof /> <crc>31b1ad00</crc> <manufacturer>Electro Brain</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="War 2410 (USA)" index="true" image="w"> <description>War 2410 (USA)</description> <cloneof /> <crc>ad2dc53a</crc> <manufacturer>Advanced Productions</manufacturer> <year>1995</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="War 3010 - The Revolution (USA)" index="" image=""> <description>War 3010 - The Revolution (USA)</description> <cloneof /> <crc>98c974be</crc> <manufacturer>Advanced Productions Inc.</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wario's Woods (USA)" index="" image=""> <description>Wario's Woods (USA)</description> <cloneof /> <crc>2d1004f1</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Warlock (USA)" index="" image=""> <description>Warlock (USA)</description> <cloneof /> <crc>a47884d0</crc> <manufacturer>Acclaim</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WarpSpeed (USA)" index="" image=""> <description>WarpSpeed (USA)</description> <cloneof /> <crc>1e10a1d1</crc> <manufacturer>Accolade</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Waterworld (Europe)" index="" image=""> <description>Waterworld (Europe)</description> <cloneof /> <crc>7acf2ac6</crc> <manufacturer>Ocean</manufacturer> <year>1995</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wayne Gretzky and the NHLPA All-Stars (USA)" index="" image=""> <description>Wayne Gretzky and the NHLPA All-Stars (USA)</description> <cloneof /> <crc>0b7d22b2</crc> <manufacturer>Time Warner</manufacturer> <year>1995</year> <genre>Sports/Hockey</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wayne's World (USA)" index="" image=""> <description>Wayne's World (USA)</description> <cloneof /> <crc>0d426a15</crc> <manufacturer>THQ</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WCW Super Brawl Wrestling (USA)" index="" image=""> <description>WCW Super Brawl Wrestling (USA)</description> <cloneof /> <crc>8b477300</crc> <manufacturer>FCI, Inc.</manufacturer> <year>1994</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WeaponLord (USA)" index="" image=""> <description>WeaponLord (USA)</description> <cloneof /> <crc>0e7e7102</crc> <manufacturer>Namco</manufacturer> <year>1995</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="We're Back! - A Dinosaur's Story (USA)" index="" image=""> <description>We're Back! - A Dinosaur's Story (USA)</description> <cloneof /> <crc>3f654414</crc> <manufacturer>Hi-Tech</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wheel of Fortune - Deluxe Edition (USA)" index="" image=""> <description>Wheel of Fortune - Deluxe Edition (USA)</description> <cloneof /> <crc>d6a5984c</crc> <manufacturer>GameTek</manufacturer> <year>1993</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wheel of Fortune (USA)" index="" image=""> <description>Wheel of Fortune (USA)</description> <cloneof /> <crc>1c384b11</crc> <manufacturer>GameTek</manufacturer> <year>1992</year> <genre>Quiz</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Where in the World Is Carmen Sandiego (USA)" index="" image=""> <description>Where in the World Is Carmen Sandiego (USA)</description> <cloneof /> <crc>9ef83223</crc> <manufacturer>Hi-Tech</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Where in Time Is Carmen Sandiego (USA)" index="" image=""> <description>Where in Time Is Carmen Sandiego (USA)</description> <cloneof /> <crc>1712018b</crc> <manufacturer>Hi-Tech</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Whirlo (Europe)" index="" image=""> <description>Whirlo (Europe)</description> <cloneof /> <crc>7379e3b3</crc> <manufacturer>Namco</manufacturer> <year>1992</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Whizz (USA)" index="" image=""> <description>Whizz (USA)</description> <cloneof /> <crc>ea8df334</crc> <manufacturer>Titus</manufacturer> <year>1996</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wild Guns (USA)" index="" image=""> <description>Wild Guns (USA)</description> <cloneof /> <crc>085d8d14</crc> <manufacturer>Natsume</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WildSnake (USA)" index="" image=""> <description>WildSnake (USA)</description> <cloneof /> <crc>025adbf9</crc> <manufacturer>Spectrum Holobyte</manufacturer> <year>1994</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wing Commander - The Secret Missions (USA)" index="" image=""> <description>Wing Commander - The Secret Missions (USA)</description> <cloneof /> <crc>d5e9af7f</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wing Commander (USA)" index="" image=""> <description>Wing Commander (USA)</description> <cloneof /> <crc>65ad4f8d</crc> <manufacturer>Mindscape</manufacturer> <year>1993</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wings 2 - Aces High (USA)" index="" image=""> <description>Wings 2 - Aces High (USA)</description> <cloneof /> <crc>1637d1a5</crc> <manufacturer>Namco</manufacturer> <year>1992</year> <genre>Flying</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Winter Gold (Europe)" index="" image=""> <description>Winter Gold (Europe)</description> <cloneof /> <crc>0f8378a6</crc> <manufacturer>Nintendo</manufacturer> <year>1996</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Winter Olympic Games - Lillehammer '94 (USA)" index="" image=""> <description>Winter Olympic Games - Lillehammer '94 (USA)</description> <cloneof /> <crc>0704abe4</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Sports</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wizard of Oz, The (USA)" index="" image=""> <description>Wizard of Oz, The (USA)</description> <cloneof /> <crc>d5ce2db5</crc> <manufacturer>Seta Corporation</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wizardry V - Heart of the Maelstrom (USA)" index="" image=""> <description>Wizardry V - Heart of the Maelstrom (USA)</description> <cloneof /> <crc>d8fddd76</crc> <manufacturer>Capcom</manufacturer> <year>1994</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wolfchild (USA)" index="" image=""> <description>Wolfchild (USA)</description> <cloneof /> <crc>13bfb3a0</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wolfenstein 3D (USA)" index="" image=""> <description>Wolfenstein 3D (USA)</description> <cloneof /> <crc>6582a8f5</crc> <manufacturer>Imagineer</manufacturer> <year>1994</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wolverine - Adamantium Rage (USA)" index="" image=""> <description>Wolverine - Adamantium Rage (USA)</description> <cloneof /> <crc>4e62d6bf</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1994</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wonder Project J (Japan - Translated)" index="" image=""> <description>Wonder Project J (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Enix</manufacturer> <year>1994</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Wordtris (USA)" index="" image=""> <description>Wordtris (USA)</description> <cloneof /> <crc>856ab0bb</crc> <manufacturer>Spectrum Holobyte</manufacturer> <year>1992</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Class Rugby (Europe)" index="" image=""> <description>World Class Rugby (Europe)</description> <cloneof /> <crc>d73d6c80</crc> <manufacturer>Imagineer</manufacturer> <year>1993</year> <genre>Sports/Football</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Cup Striker (Europe)" index="" image=""> <description>World Cup Striker (Europe)</description> <cloneof /> <crc>6d16f5e7</crc> <manufacturer>Elite</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Cup USA 94 (USA)" index="" image=""> <description>World Cup USA 94 (USA)</description> <cloneof /> <crc>fb1c9082</crc> <manufacturer>U.S. Gold</manufacturer> <year>1994</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Heroes (USA)" index="" image=""> <description>World Heroes (USA)</description> <cloneof /> <crc>1228ad30</crc> <manufacturer>Sun Soft</manufacturer> <year>1993</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Heroes 2 (USA)" index="" image=""> <description>World Heroes 2 (USA)</description> <cloneof /> <crc>098d7eaa</crc> <manufacturer>Takara</manufacturer> <year>1994</year> <genre>Fighter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World League Soccer (USA)" index="" image=""> <description>World League Soccer (USA)</description> <cloneof /> <crc>591cbb2d</crc> <manufacturer>Mindscape</manufacturer> <year>1992</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Masters Golf (Europe)" index="" image=""> <description>World Masters Golf (Europe)</description> <cloneof /> <crc>e0ee681f</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1995</year> <genre>Sports/Golf</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="World Soccer 94 - Road to Glory (USA)" index="" image=""> <description>World Soccer 94 - Road to Glory (USA)</description> <cloneof /> <crc>0aae0a10</crc> <manufacturer>Atlus</manufacturer> <year>1993</year> <genre>Sports/Soccer</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Worms (Europe)" index="" image=""> <description>Worms (Europe)</description> <cloneof /> <crc>90d0fac0</crc> <manufacturer>Ocean</manufacturer> <year>1996</year> <genre>Strategy</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WOZZ (Japan - Translated)" index="" image=""> <description>WOZZ (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>Bullet Proof Software</manufacturer> <year>1995</year> <genre>Role Playing Game</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WWF Raw (USA)" index="" image=""> <description>WWF Raw (USA)</description> <cloneof /> <crc>3e0038bf</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1994</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WWF Royal Rumble (USA)" index="" image=""> <description>WWF Royal Rumble (USA)</description> <cloneof /> <crc>2101d515</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1993</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WWF Super WrestleMania (USA)" index="" image=""> <description>WWF Super WrestleMania (USA)</description> <cloneof /> <crc>676cb638</crc> <manufacturer>LJN Ltd.</manufacturer> <year>1992</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="WWF WrestleMania - The Arcade Game (USA)" index="" image=""> <description>WWF WrestleMania - The Arcade Game (USA)</description> <cloneof /> <crc>1ba08495</crc> <manufacturer>Acclaim</manufacturer> <year>1996</year> <genre>Sports/Wrestling</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="X Zone (Japan, USA)" index="true" image="x"> <description>X Zone (Japan, USA)</description> <cloneof /> <crc>99627bb0</crc> <manufacturer>Kemco</manufacturer> <year>1992</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Xardion (USA)" index="" image=""> <description>Xardion (USA)</description> <cloneof /> <crc>c7c12a57</crc> <manufacturer>Asmik Ace Entertainment, Inc</manufacturer> <year>1992</year> <genre>Shooter</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="X-Kaliber 2097 (USA)" index="" image=""> <description>X-Kaliber 2097 (USA)</description> <cloneof /> <crc>e83eceea</crc> <manufacturer>Activision</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="X-Men - Mutant Apocalypse (USA)" index="" image=""> <description>X-Men - Mutant Apocalypse (USA)</description> <cloneof /> <crc>5e34822a</crc> <manufacturer>Capcom</manufacturer> <year>1995</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Yoshi's Cookie (USA)" index="true" image="y"> <description>Yoshi's Cookie (USA)</description> <cloneof /> <crc>ef15f4c3</crc> <manufacturer>Bullet Proof Software</manufacturer> <year>1993</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Yoshi's Safari (USA)" index="" image=""> <description>Yoshi's Safari (USA)</description> <cloneof /> <crc>59490ce8</crc> <manufacturer>Nintendo</manufacturer> <year>1993</year> <genre>Gun</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Young Merlin (USA)" index="" image=""> <description>Young Merlin (USA)</description> <cloneof /> <crc>7ea1afe8</crc> <manufacturer>Virgin Interactive</manufacturer> <year>1993</year> <genre>Adventure</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ys III - Wanderers from Ys (USA)" index="" image=""> <description>Ys III - Wanderers from Ys (USA)</description> <cloneof /> <crc>64a91e64</crc> <manufacturer>American Sammy</manufacturer> <year>1991</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Ys IV - Mask of the Sun (Japan - Translated)" index="" image=""> <description>Ys IV - Mask of the Sun (Japan - Translated)</description> <cloneof /> <crc /> <manufacturer>American Sammy</manufacturer> <year>1993</year> <genre>Role-Playing</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Zero the Kamikaze Squirrel (USA)" index="true" image="z"> <description>Zero the Kamikaze Squirrel (USA)</description> <cloneof /> <crc>5397d5bc</crc> <manufacturer>Sun Soft</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Zombies Ate My Neighbors (USA)" index="" image=""> <description>Zombies Ate My Neighbors (USA)</description> <cloneof /> <crc>7cfc0c7c</crc> <manufacturer>Konami</manufacturer> <year>1993</year> <genre>Action</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Zool - Ninja of the Nth Dimension (USA)" index="" image=""> <description>Zool - Ninja of the Nth Dimension (USA)</description> <cloneof /> <crc>3c10daf1</crc> <manufacturer>GameTek</manufacturer> <year>1994</year> <genre>Platform</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> <game name="Zoop (USA)" index="" image=""> <description>Zoop (USA)</description> <cloneof /> <crc>06f0e94c</crc> <manufacturer>Viacom New Media</manufacturer> <year>1995</year> <genre>Puzzle</genre> <rating>Other - NR (Not Rated)</rating> <enabled>Yes</enabled> <exe>Super Nintendo Entertainment System</exe> </game> </menu> [sIGPIC][/sIGPIC]
reznnate Posted June 17, 2015 Posted June 17, 2015 The problem is related to use of special characters in the .xml file. In this case "&". According to XML spec, change to & and the dbase should work fine. Ideally the xml parser on Android would deal with these characters in the same way as PC so ALL existing data files would 'just work' but this feature is low on the priority list.
BiZzAr721 Posted June 17, 2015 Author Posted June 17, 2015 Awesome, thanks. Sorry for the long xml in the post, I thought it would be scrollable wrapping it in code tags, not just a long list, which ended up giving errors when I tried to edit the post. [sIGPIC][/sIGPIC]
BiZzAr721 Posted June 26, 2017 Author Posted June 26, 2017 I sure am glad I made this post (and with this system no less) I was messing with Hyperbase Live, forgot to back up the database and lost it. It was customized to include Jap Translated with genres. Let this be a public service announcement: ALWAYS remember to back up when working with setting and database files! [sIGPIC][/sIGPIC]
