RocketLaunch Help
mastermark
Hi,
Looks like your HyperSpin is looking for a HyperLaunch V2.
Check this out: http://www.rlauncher.com/wiki/index.php?title=RocketLauncher_Updating_an_Install_from_v2
And this:  http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3
Thanks,
Ron
I wanted to start from scratch i downloaded HS 1.3.3 and RL v1.0 (full Setup)
i dragged them into the same folder C: Hyperspin
I then renamed the Global Emulators (Example) deleted the Example.
I then ran RocketLauncher updated and made HS default frontend
Added super nintendo Emu + roms
then get this error where am i going wrong.
Im not updating an old hyperspin i want to start from fresh.
Hi,
They are not intended to go in the same folder at all.
You should put HyperSpin in C:\HyperSpin
And put RL in C:\RocketLauncher
Thanks,
Ron
Ok,
HyperSpin comes with HyperLaunch v2.  So, to use RocketLauncher, I do recommend.  Follow and read the first link I posted above.  That explains how to transition from HyperLaunch V2 to RocketLauncher V1.
There is also wiki on how to do a clean RL install.  Take a look at the RL WiKi:  http://www.rlauncher.com/wiki/index.php?title=Main_Page
Thanks,
Ron
Now done that but still getting same errors i have no idea what to do
