Yabause ahk file
raysweater
Hey, so I'm essentially done setting up HyperSpin. Every emulator is working, except Yabause. Here's the issue.
It works great from RocketLauncherUI, the problem is that once I launch HyperSpin and try to load a game, it says I'm missing the .ahk file.
The only .ahk files in the proper folder are for the SSF emulator, and not Yabause. Can anybody share the file with me, or point to where I can download it?
if you can launch your Yabause emulator with RoccketLauncherUI,  then you have the Yabause ahk file in its proper place.
what you don't have is Hyperspin configured to work with Rocketlauncher.
Look at your HyperSpin Log,  You are probably getting an  "Cant find Hyperlaunch" error followed by a "  using default Hyperlaunch 2  line.
since yo don't have  a Yabuse  Hyperlaunch 2 AHK (Module)  its giving you the "Missing Module" error.
even if you get a Hyperlaunch 2 Yabuse module you are still going to have problems until you configure your Hyperspin to work with Rocketlauncher.
Hyperspin loads every other emulator except for Yabause, so RocketLauncher and HyperSpin are configured together. The ahk file I'm missing is in the Hyperspin/Modules/Sega Saturn folder. There are a couple in there, but they are for the SSF emulator, and I can't get that one to work like I can Yabause.
Hyperspin/Modules/Sega Saturn  --> Modules for Hyeprlaunch 2
in this post
http://www.hyperspin-fe.com/topic/7625-hyperspin-1330-new-user-guide/
I state that you can delete that entire folder IF YOU ARE USING ROCKETLAUNCHER!!!
HyperSpin\RocketLauncher\Modules  -->  Modules for Rocketlauncher
unless you deleted the file  your Yabuse ahk should already be at
HyperSpin\RocketLauncher\Modules\Yabause\
since you are able to load a game with RLUI, I'm 100% positive its in their.
and NO!!   the RocketLauncher  AHK  will not work if you move it to   Hyperspin/Modules/Sega Saturn
post your path to Hyperlaunch found in
HyperSpin\Settings\Settings.ini
it should start with    Hyperlaunch_Path=
also post what version of HS you are using  1.3.3  or  1.4 Beta
Your hyperlaunch path is not set up correctly or is configured to work with Hyperlaunch 2  that's why HS is asking you for HL2 modules,
