rik81
    110
Everything posted by rik81
  1. So I just went through all the systems.... Any wheel that had a main menu theme that worked.... The media also seemed to work in wheel. Anything that the media didnt work... ArcadePC for instance.. which is PC games. And I have a video theme for... Overrides dont take... None of the media will sync either.
  2. PROBLEM - FIXING MEDIA I added a bunch of wheels.... And was able to use the full screen Theme override for things like Atari 2600, 5200 etc... Then for Atari Jaguar... I couldnt get the override theme to work... however after some testing.... I eventually did figure this out.... I had to go into HyperHQ.. delete the system. Go into the main menu media.. renmaed the theme. Closed HyperHQ... Reopened it again. And readded the system. I then reloaded Hyperspin and Voila... I was able to use the Full screen menu override for Atari Jaguar I then tried to do the same exact thing with MUGEN... Which doesnt actually have a theme but is a noted system on the HyperHQ installation process. Well doing this and trying to use an Override... doesnt work at all. Even if I did the above. The wheel also refuses to show any media at all. Other problems.... Some of the wheels have a main menu theme... but the wheel media refuses to show. Its very hard to make heads or tails of anything.... And even using process of elimation is proving difficult because it seems that certain wheels, which seem to have a theme... act differently then other wheels that were seemingly added but the backend code was never completed. This is the only explanation I can think of.. Im going to find another one with a theme and do the same thing..... Also the forums are very active... Zero threads of people testing this stuff.
  3. Small update.... Things are struggling... but I am getting some success by clearing cache... rebuilding and restarting HyperHQ. IDK... ill continue to add systems and stress test things
  4. Ive added 30 systems.... and the process of building everything in HyperHQ is... STRUGGLING HARD. Theres no way this cache system which adds every piece of media to a database will ever be viable. Theyll have to rewrite it.
  5. Yeah it seems that if the list of systems isnt approved... as in... when you do a system search. They wont sync any media at all... you can still see the overrides for the media in HyperHQ though. Hopefully this is addressed in the next update. Theres a few things I would like to add which currently will not work.
  6. Custom Systems still dont add any media. At least Mame and Atari 2600 are working ok. The custom system I added was American Laser games.
  7. A couple of things.... I finally got the media syncing... I think a learned a few things. Do not put the hyperspin folder in with HyperHQ.... Keep them separate. Overrides seem to be working well now. More testing to come.... Going to see if I can make a custom system... if that works! I think ill be able to start using this!
  8. Heard a report that the lastest update hyperspin started working again? Anybody confirm this is true? Not working on my side.
  9. Nope... Nothing... Ive already tried all this btw.
  10. Everything works... Except the Media Syncing to Hyperspin. I think the plugin has to be rewritten or something. (Even tried running everything as Admin All the features are great... THe loading of systems has massively improved... But the media simple wont sync... even with the emumovies video. The only thing that seems to sync are the system themes. Yet you can see all the media, even in overrides... in HyperHQ. Once you get this all working... It should be good! Also if your trying to reassign buttons.... Enter and Escape work great. 2 works fine. 1 doesnt work. Escape works fine. Also when you click on Launch hyperspin in HyperHQ... the button doesnt do anything. Also when I click on Validate media and Validate Overrides... the screen pops up for a brief blip... and vanishes.. Its either Syncing super fast.. or crashing and not syncing at all.
  11. The names are the exact same as i used the same roms This is an old post now... Ill have to try the new version and reportt back later
  12. Ive only got 2 systems added... Mame and Sega Model 3 - Clean installation Loadingn times are still atrocious - Gets stuck at loading wheel data for a long time.. the restt is a bit faster but not much Custom system media doesnt get added at all Pressing the hypersoin launch button from HyperHq doesnt do anything anymore I got mame to sync the overrides but when scrolling between the video themes from emumovies...half the time the new theme doesnt load Getting things to sync at all is a serious choir... I trying model 3 now after resyncing overrides... im hoping it syncs.. Uses the wheel media and and the videos (UPDATE: I didnt sync anything, wheels and media from overrides were ignored) Changing the buttons doesnt work half the time. Kicks you out like your pressing exit The softare is progressing but this cache system of giving everything a directory address in a data file, is killing the entire system. If everything has to be read.... this new version will never get off the ground as your probably talking millionso of hard directory saves. No CPU in the world will be able to read a file with millions of directories in an effecient order. This is 2 systems... Wait till you add MS Dos... Commodore 64... Playstation 2, Playstation 1... Or anything with a lot of games... Your talking TONS of files that all have to have a directory entry in a data base. Coding in one thing... but has anybody from the forums actually setup a system with 100 different wheels and confirmed that its working? I dont think anybody has....
  13. 2.0.34 - Hyperspin Core 1.1.0 - Hyperspin Core essentials
  14. From what I can see... there are large problems with the Cache as well as other things. (It actually worked better in previous iterations... I think) THings seem to work in HyperHQ... but when transfering over to hyperspin. Nothing is being transferred over the way it should.. 1. Full screen videos arent working for anything 2. Wheels sometimes work... 3. The video in mame sometimes doesnt match the border. Not all the time though. 4. The boxart is getting stuck behind the wheels... not all the time though. 5. Ive only added 3 systems. Your version of mame, which seems to have better overrides but still not 100 perccent. My version of mame for testing to compare. And Atari 7800. MAME - My version - No overrides work... Meaning no media at all. MAME - Your Version - Some of the overrides work. Wheel overrides are ignored but show up in HyperHQ, your wheels with the weird codes show up though, Videos do seem to work. Themes dont work at all. Theyre just ignored. Atari 7800 - Wheel overrides seem to work. Main menu - Wheel overrides seem to work... I think... But not working for your version of mame. Ive renamed mame to "Arcade (MAME)" Theme Menu - Atari 7800 seems to work... Both mames dont Also the loading... for only 3 systems is getting quite long.. takes like 5 mins for the loading to complete when hyperspin is loaded. Also the media syncs also take a minute. And this is for 3 systems... Imagine adding a 100 or more....
  15. The improvements are massive! Testing out the custom system.. Added mame. Cause I already have my own set. Added the emumovies movies and logo set to overrides. Nothing is being added to Hyperspin. You can see it however in HyperHQ. I went into the settings and validated both regular and override tabs. But nothing got nothing but a grey wheel in hyperspin.
  16. You probably added the roms accidently
  17. Emulators get stuck... Mame wont unpack when adding mame to the setup either.
  18. 1. Adding MAME Emulator is stuck. Wouldnt unpack Mame. (I clicked the settings tab and it kicked me back to the system menu) 2. Then I decided to add a custom emulator. Which was mame... and it hung on the Emulator screen after trying to choose/create an emulator. (Just the blue background) Also version 45... Took an hour to install. It would slowly go up 1 percent. (I think this was fixed as when it was done it asked me to install a new version)
  19. I want to add one more thing.... The cache database doesnt handle the data very well once it gets past a certain point. For instance... once you start adding a lot of games. Like the microsoft dos set...wtiht thosands of media..... it takes a long time to sync... and it seems to just freeze up at the 97 percent mark. Then when you go in and test it... hyperspin also freezes as the database file never actually finalized. The idea to put checks and balances in place etc... is ok... but the structuring of the database needs to be either scrapped and go back to the regular hyperspin model of just reading media from the folder... without writing every file a hard directory address to a cache. Theres obviously problems with the syncing of media. This thing never gets off the ground otherwise. I think im going to take a week or two off and come back when theres more fixes... Cause right now... im just burning a lot of time messing with things.
  20. 1. M.U.G.E.N folder breaks the file system on windows, And you cant delete it. Get rid of the dots. 2. Overrides dont sync with the MainMenu. Or might do it partially.
  21. I was using Mame when the video was playing in the background. As stated... It was a theme.. I dumped some mame videos into the theme folder to test the full screen capability.
  22. Also... I mentioned this before... but if you could move the delete button to the system screen please./.. it would make cleaning up roms that you dotn want or that arent supposed to be there much easier. Thanks!
  23. Things are coming together nicely! Great job on the improvements! I had to wipe everything and start fresh again. A couple of things 1. Videos seem to continuously play after the game launches... I dont think the frontend is being frozen. And the videos play in a loop, you can hear them in the background. This is for themes btw. 2. Custom systems still dont add to hyperspin after setup. Tried to add Dice again... Doesnt appear. Everything else I think you nailed it!
