Microsoft MSX using fmsx core Retroarch!!!
Sting
Quick tutorial on setting MSX using Retroarch :)
Quick tutorial on getting Microsoft MSX to run through Retroarch and Hyperspin.
BIOS files needed:
(msx.rom, msx2.rom, msx2ext.rom, msx2p.rom, msx2pext.rom)
Hyperspin settings:
exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture
 parameters=cores/fmsx_libretro_android.so
romextension=rom,mx1,mx2
Hi,
Great video. I have done everything you have mentioned, everything showing as present on bios screen in retroarch, rom extension set to rom, settings/exe all correct.
It plays ok when i point it to a file in retroarch, but when i use hyperspin still has a black screen only.
Do the roms need to be on internal drive ? as I have mine on external drive. All other retroarch systems work fine with roms on it but this one is very odd.
I tried both fmsx and blue msx in retroarch directly now, both refuse to run any games. Weird. i have the bios files in place and both those needed directories from the blue msx install.
Has anyone got this working? Wanna tell us how you did?
Yes! I got blueMSX working!
How? I started retroarch from the command line like this:
retroarch --menu --verbose > log.txt 2>&1
and found the following lines in the log:
RetroArch [WARN] :: SYSTEM DIR is empty, assume CONTENT DIR D:\HyperSpin\Emulators\RetroArch\1942 (Japan).rom
RetroArch [iNFO] :: Environ SYSTEM_DIRECTORY: "D:\HyperSpin\Emulators\RetroArch\".
RetroArch [ERROR] :: Failed to load content.
Dooh, my system dir was not set. When i did set it BluMSX works. \o/
Why doesn't it work the normal way?
Shouldn't this be reported to the rocketlauncher guys instead?
This is for Android mate, we don't use Rocket Launcher :)
