Another system that nobody asked for and nobody needs!
An obscure Czechoslovakian computer from 1985.  Only five games for this one and they are all black and white Spectrum ports.  The games don't have sound (unless you count the horrible screeching of tape loading).  I'm not sure if these games actually have audio.  Mame lists audio as functional and the only gameplay videos I found on original hardware were without sound.
By default, all games load to Ondra BASIC and simply pressing Enter (start on controller) will begin the tape loading process.
But that's not good enough! There is a way to launch directly to the loaded tape for all but one game (Jet Set Willy)
The usual save state (autoload) method will not work, but the alternate autosave method will.
First create an ondrav.ini file.
RetroArch->Quick Menu->Options->Write Configuration
That will create RetroArch\system\mame\ini\ondrav.ini
Edit ondrav.ini to turn on autosave:
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  1
Now every time you exit a game there is a save state created that will load when the game is launched.  This method is able store the entire contents of the tape within the save file and you will always resume the game from the moment you last exited.  Obviously, that's not the best solution if you want to load from the same point every time. Unless you make that file read-only
Autosave files are created in: RetroArch\saves\mame\states\ondrav
Each game will be given its own folder and an "auto.sta" file. After you exit a game the "auto.sta" is automatically saved.  You must adjust the properties of the file to be read-only before you launch the game again.
I have created and uploaded Autosaves for every game using 0.247 core.
If they don't automatically work for you, then you must create your own.
The timing must be correct to capture the full tape.
Here are the correct times to exit the games and successfully make autosaves
galaxian - Exit from title screen
jetpac - Exit on gameover screen
planetoi - Exit on title screen
psst - Exit on gameover screen
jetset - This game will not correctly save! Exit before loading a tape to create an autoload. The autoload will basically do nothing and you have to press Enter/start and manually load the tape every time.
I set Main CPU Overclock =150 on Galaxians and uploaded the galaxian.opt
  • Super Like 8
Recommended Comments
brudibru
I didn't knew it 5 minutes ago, but now I definitely need that system !! 😄
floatingyeti
Now I have to find something more ridiculous and pointless.
brudibru
How to you find those systems ? Just by going through the Mame Software list ?
brudibru
I think that your work is incredibly useful and educative.
There are Mame devs spending hours of their time trying to emulate such unknown computers and nobody but a few knows about it !
floatingyeti
Yes, I have to hunt through the systems one by one. Sometimes it's not obvious that a system has games based off the rom titles.
That's what I was thinking! I know whatever is uploaded eventually makes it on to many people's setups. Now the Ondra ViLi or Sanyo MBC-550 might be played by ten more people. Not a lot but better than nobody.
brudibru
It seems that your recent complete setups have been downloaded around 20 to 25 times. I would have guessed more but that is something already and it will grow with time. I can see that there are new members joining everyday. Maybe people who have discovered Hyperspin recently and will first install the most obvious systems and, later on, your "obscure" ones (You know that adding new wheels can get infectious after a while).
I will probably be able to post my complete setup of the Apple I next week. I will see if a system so archaic and without any graphics can raise some interest. The manufacturer's name might help...or not.
floatingyeti
I could see how far we could take that.  I found a system from 1948.
brudibru
wow, much older than the PDP-1 itself ! Would it be able to decode the German  enigma machine ? 😃
