Small tool to replace hypermarquee for displaying mp4, png or jpg marquee files. You can select multiple dirs with marquee files ( current limit is 3 but can be changed ), static or animated. Mp4 is first, if not found any static image that matches the rom name will be used. If no rom marquee can be found, a fallback option for the system marquee is there.
It spawns a monitor process so when the main marquee script is killed, it also kills mpc-hc.
Dir\SystemName\RomName.mp4
Dir\Main Menu\SystemName.mp4
Source included.
If video is not looping or the images are not stretched, just open mpc-hc and enable it, closing will save the settings:
Play -> Repeat -> Foreever + file
View -> Video Frame -> Stretch to window
I am running it through EDS, a screenshot for settings is included.
What's New in Version 1.0.1
Added intro video support ( check the EDS screenshot for proper settings, for some reason in attract mode, HS sends eventid 5 having EDS kill the script )
Fixed some naming options
  • Super Like 4
