HyperElectronicGames (Launcher for Electronic Games)
r0man0
  • Replies 166
hi shitoken , your config is ok ,
do you have all games folders from package in the same directory as hyperelectronicgames.exe ?
(otherwise hyperelectronicgames will not run)
r0man0
Nope,  it just open and close the cmd box within seconds
Have you also try to launch as administrator ? I'm not sure but maybe your problem come from your windows OS configuration.
Yea I tried with admin but same problem
Anyone else having same issue with win8?
Tapatalk を使用して私の A0001 から送信
Hi , hyperelectronicgames package have been updated on main post:
Version 0.9.4
12/23/2015 - Added --> Exit when 2 buttons pressed simultaneously
(see "Installation" for details)
12/23/2015 - Added --> MADrigal CD Collection 59.22 Update
(Snoopy panorama screen,Mario's Bomb away panorama screen)
12/23/2015 - Fixed --> All pop-up windows from MADrigal CD
Collection games are now hidden.
merry chrismas to hyperspin community
r0man0
Happy new year everybody!
Games release time again. And again it is a Game & Watch Panorama Screen classic with Donkey Kong as the main character. The setting is not exactly my cup of tea, but the game is fun and addictive so I hope you enjoy playing the simulator.
Big thanks to René van Egmond, Raphael Rafaël Lepoutre and Roberto De Gregorio for providing stuff and priceless support!
This is the list of new downloadable files:
- Donkey Kong Circus (Nintendo, Panorama Screen) S4/1.06 (Standard 4, complete rewrite)
- MADrigal CD Collection ver. 59.23
- ClrMamePro DATfile ver. 20160104 [59.23]
Grab them from the popular downloads page.
URL: http://www.madrigaldesign.it/sim/
Enjoy! :-)
great set here omano. Question about setting up universal controls. Where is the ini located for this? The games run fine however if I manually try opening the electrogame.exe manually, the exe doesn't open nor does it create an ini. When opening games from rocketlauncher, the games boot up fine but looking to controlling these things :Dalso where do I put the background art to ensure I hide the front end
Hi ninja2bceen , hyperelectronicgames.ini and background.*** must be placed on same directory as executable & electronic games folders.
you can select any picture you want instead of the existing background.png , just renamed it as "background".
Executable need at least the game name parameter to be launched (for ex : "hyperelectronicgames.exe snoopy")
To set up ini file check read-me inside package or main post.
r0man0
Ok so basically I just need to put a background.png in the same folder as the hyperelectronic.exe
For the ini I just need to paste what's in the first post essentially and put it in the same location as the background?
for the double click to exit option. say I want to use 1 and 5 press. How would I add that to the ini? =1&5?
Hi , double button for exit works only for joystick buttons : joy1 , joy2 , joy3 ...
you can only make a combination of 2 joystick buttons to exit for ex :
DoubleButtonForExit1=Joy5
DoubleButtonForExit2=Joy6
For the moment there's no combination with 2 keys for exit , you can just define standard exitkey :
ExitKey=esc
r0man0
thanks. does anyone else notice that if you have joy2key activated that once you launch a game, at least for me, my left arrow is being pressed constantly. Other systems don't have this problem.maybe since this isn't launching through rocketlauncher, joy2key has a hard time swapping profiles or something? I hope someone else has this issue, otherwise I just wont use a controller on this system.
[General]
JoyNumber=1
Joy2Key=1
Azerty=1
800X600Only=0
ExitKey=esc
[XArcadeTankstick]
EnableXarcade=0
UpXarcade=Up
DownXarcade=DOWN
LeftXarcade=LEFT
RightXarcade=RIGHT
Button1Xarcade=1
Button2Xarcade=2
Button3Xarcade=3
Button4Xarcade=4
ButtonSelectXarcade=7
ButtonStartXarcade=8
  • 4 weeks later...
When I tried to launch game thru HS and press enter nothing happens. Anything I am missing?
I had this isue too. I had to go to Hyperspin\Settings\ and edit the Electronic Games.ini and set userompath=false.
I just set this up and it's great. I have a suggestion. Would it be possible to add the option to hold the exit key for a couple of seconds for it to trigger?
Also, the artwork that shows the picture of the games is missing CrazyChewy. That picture is actually CrazyChewyTabletop.
Thank you for making this. I have been holding this off for years.
Thanks dime333 will try this out tomorrow.
[General]
JoyNumber=1
Joy2Key=1
Azerty=1
800X600Only=0
ExitKey=esc
[XArcadeTankstick]
EnableXarcade=0
UpXarcade=Up
DownXarcade=DOWN
LeftXarcade=LEFT
RightXarcade=RIGHT
Button1Xarcade=1
Button2Xarcade=2
Button3Xarcade=3
Button4Xarcade=4
joy2key had a bug and updating it fixed my issue FYI
Hi Bro
Which version of windows are you using.
I tried your way on this win8.1 , but the same.
Would you mind to share your INI. Thanks
I'm using Win7 X64. You should check your "log.txt" in your HyperSpin folder. That's how I found out what was wrong on my setup. Maby there is another error for you.
Here's my ini.
[exe info]
path=E:\RocketLauncher\Emulators\Electronic Games\
rompath=
userompath=false
exe=HyperElectronicGames.exe
romextension=
parameters=
searchsubfolders=
pcgame=false
winstate=NORMAL
hyperlaunch=false
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=true
use_parent_themes=false
animate_out_default=false
reload_backgrounds=false
[wheel]
alpha=.15
small_alpha=1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=false
remove_info_text=false
use_last_game=false
last_game=DizzysCashIn
random_game=true
start_on_favorites=false
[Special Art A]
default=false
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[Special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[Special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xffffff
text_color2=0x0099cc
text_font=Style1
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
  • 3 weeks later...
I got this running with the help of Dime333's post.
"I had this isue too. I had to go to Hyperspin\Settings\ and edit the Electronic Games.ini and set userompath=false."
Working great after this fix.
Thanks for the launcher! Great work!
Hi , a new version have been uploaded on Mega server , link on the main post , here is the changelog :
version 0.9.5
02/23/2016 - Added --> Long pressed Exit Key function (3sec)
02/23/2016 - Added --> MADrigal CD Collection 59.23 Update
(Donkey Kong Circus)
02/23/2016 - Fixed --> Double game "CrazyChewyTabletop" deleted from
database.
Thanks for your bugg report.
r0man0
version 0.9.5
database.
r0man0
Thanks. I'll check it out when I get a chance. The download link seems dead, though.
Ok , link have been changed.
r0man0
