damageinc86 Posted July 13, 2015 Posted July 13, 2015 Is there a way to either use a key, or map a key to savestate slots in the new retroarch? Like, in mednafen it's really easy to use hyperpause because you just have to send a keypress to start the save process, and send a keypress to hit the number of the save state. All I see in retroarch is the menu bar where you can select a savestate with the mouse.
pofo14 Posted July 14, 2015 Posted July 14, 2015 Yes. In the retroarch.cfg there are settings to change the save/load state buttons. Open that file and search for input_save_state. You will see all the setting for loading and saving state there.
damageinc86 Posted July 14, 2015 Author Posted July 14, 2015 sweet thanks. there's no way to do that within RA uh? you have to go into that file only?
Styphelus Posted July 14, 2015 Posted July 14, 2015 There's a new Retroarch? What changed? Will I still be able to keep all my config files? What's this issue with save states? Are they not working?
damageinc86 Posted July 14, 2015 Author Posted July 14, 2015 i have no issue, i am just starting to get into retroarch because of the nice fancy new version. But I just wonder about how to do hyperpause with the save states. like other emulators.
damageinc86 Posted July 14, 2015 Author Posted July 14, 2015 I'm also curious about controls and per-core configs, and how to use it all with RL. Because I want my console controllers to be used for different cores. like nes controllers for nes games as an example.
pofo14 Posted July 14, 2015 Posted July 14, 2015 There's a new Retroarch? What changed? Will I still be able to keep all my config files? Yes, version 1.2. I upgraded and all my confit files seem to work fine.
pofo14 Posted July 14, 2015 Posted July 14, 2015 I'm also curious about controls and per-core configs, and how to use it all with RL. Because I want my console controllers to be used for different cores. like nes controllers for nes games as an example.Yes, you can do this. You can use the input binding tool or manually edit the files. I have a post here that tried to highlight the steps.http://www.rlauncher.com/forum/showthread.php?t=1421
damageinc86 Posted July 14, 2015 Author Posted July 14, 2015 nice. guess i should post over at rlauncher about how to have a core launch up through RL so i can play a system instead of just going into Retroarch.
