Files to folders with same name
Dilated18
Im trying to organize the game guides I have for use in hyper pause. Is there a way to batch process all the guides i have into folders and the folders be named the same as the file itself. I have been doing this manually, one by one but I have a good handful of them and it will take me forever to get them all done.
I think the easiest way to accomplish that would be to write a simple powershell script. I did a quick google and found a decent example (look at the powershell example). I can't really look a lot right now but if you search around you should be able to find something. There are many ways to do it but I think powershell could be the easiest with a lot of examples you can borrow from.
http://superuser.com/questions/306890/windows-batch-script-to-create-folder-for-each-file-in-a-directory-name-it-tha
If you try this out and get stuck post back and I can try to help you out.
Yea I was looking more for an application to do this but i figured out a way. I jus used winrar to zip each file seperately and then unzipped into their own folders. Appreciate the help
