Upgrading Os with Hyperspin setup
dmoseder
Hey guys, If i keep my Drive letter of my hyperspin hard drive the same, am i able to change the OS on the SSD that has only the Os system on it, leaivng my hyperspin drive intact.   Has anyone done this and should the only issue be some emulators?
I believe so.
I have all of mine on an HDD labeled as H:. I should be able to unplug that HDD and put it into any PC and have it work so I imagine I could also update my OS and it would still work.
You'd probably have to reinstall a few things if you use them: Demon Tools, VJoy, Xpadder various other system installs etc...
also if you have a PC Games wheel, you will have to reinstall all those dependencies.
I use antimicro for my control mapper, it's portable so I don't have to reinstall everytime.
Can you explain what that means?
it's just like them both, but it's free, and super easy to map out the guide button on the Xbox360 controller.
and it's portable, so I just map everything out in it, and never had a single problem out of it.
If you have worked with Xpadder this program will be easy to understand it's really simple.
Ive used xpadder before, and I like antimicro better
Here is a link, try it out    https://github.com/Ryochan7/antimicro
