Pinball Arcade will not load tables through hyperspin
jimmyuk86
When i launch a table through rocketlauncher it works fine but when i go into hyperspin, scroll down the menu wheels and select a table it freezes the screen and does nothing. Any ideas?
Probably a setting just not right. The instructions are in the notes at the top of the module.
Are you running the latest Steam version? If you are then you need to rename the .exe correctly in the Steam folder first.
RLauncher had the module updated 2 days ago, but it still needs to be corrected. Using my module in the topic below is the one that works for now.
Here's a couple topics that might help.
http://www.hyperspin-fe.com/topic/9452-help-setting-up-pinball-arcade/
http://www.hyperspin-fe.com/topic/10648-pinball-arcade-version-1407-databasetable-list-in-here/
EDIT: Actually you only need to rename the exe to use the new DX11 version of Pinball Arcade.
I'll through together an updated tutorial for everyone with the stuff they need in a bit.
