my mame - pin cab
fandtm666
after reading a post about addictive games etc it bought
back memories of the good old games so i decided to
build a mame cab.
while thinking about it i decided to make it a pinball
setup as well and started playing with vision pinball
and hyperspin for the mame .
So started with a 32' lcd for the main screen and a 19' for the back-glass
screen for the pinball that is designed to drop down when not playing pinball
Then on the inside i have a dualcore 3ghz cpu with 4gig ram and twin
1tb drives and a gtx610 video card .
hooked up to that is the basic usb encoder with 8 buttons per player plus joystick for mame
plus the 3 main buttons for the pinball and extra buttons for mame admin.
this is the final result just needs a final polish
Interesting, one of a kind build, kudos for that!
How big is the distance between both flipper buttons? Looks like they are really far apart, but I could be wrong.
hi the flippers are 750mm ( 29.5 " ) apart quite comfortable actually.
Yep its a different design because i wanted to incorporate both mame and pinball
into sit down style table that still looked nice.
750 mm is just about right. It looks a lot further apart on the photo's. Maybe because that is because almost all pincabs are without edges.
If it was my cab i would probably give it small feet so the bottom is raised like 20 mm, and put a ledstrip under it. Together with Ledwiz and VP that's awesome.
it does have 50mm feet on it already and i was thinking led strip lighting underneath
that i have left over from when i installed some on my boat.
