Zinc setup
gunit
Do I need to be aware of any others that are included in mame ? like aae, taito, triforce, openbar etc ?
Depending on your system specs, some zinc games may not run too well in mame (Tekken tag tournament would be the one to to test). Maybe have a look at psxmame. Runs more games than zinc. Sets up just like mame but runs with zinc's hardware acceleration, so the games look and perform better than they do in mame.
Having a nightmare, any idea ?
23:04:20:005 | MD |    ERROR  | +2293  | ScriptError - There was an error waiting for the window "ZiNc ahk_class ConsoleWindowClass". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
I have mame all setup and runnig fine,it would be nice to setup zinc to compare games. Sorry Jeremy what did you tell me to do ?
Yes but not sure if correct or not, ie:-
using emulator zinc11-win32
zinc works fine on its own but when I run it via rocklauncher I get the error message :(
using zinc 1.1
turned off fade and it loads the Zinc Front-End 2.1 - window. Then after about 30 seconds get the error message as before " ScriptError - There was an error waiting for the window "ZiNc ahk_class Conso ..................."
Just to confirm I downloaded the emulator zinc 1.1
But it come as 2 folders:-
zinc11-win32
ZINCGUI1.9.5
ok just pointed global to the exe and now works, doh! - sorry to waste your time, i'm sure I tried this earlier :(.
Thanks for your help
