Matthew Posted August 16, 2015 Posted August 16, 2015 Hi. I have downloaded & setup HyperLaunch & HyperLaunch HQ but when I try to launch a game I get an error message saying ther was an error loading HyperLaunch.dll. Does anyone know how to fix this error? Thanks
futek Posted September 26, 2015 Posted September 26, 2015 some of youre files are marked as read only make sure all files are read/write.
endus Posted November 6, 2015 Posted November 6, 2015 Hi, are you using Windows 10 ? win 8.1 was fine but now I have windows 10 with Hyperspin and Hyperlaunch = dll fault Now I use Rocketlauncher but have a problem with loading Rocketlauncher because Hyperspin search for Hyperlaunch.exe (now I have a RocketLauncher.exe.)
gigapig Posted November 6, 2015 Posted November 6, 2015 Hi, are you using Windows 10 ? win 8.1 was fine but now I have windows 10 with Hyperspin and Hyperlaunch = dll fault Now I use Rocketlauncher but have a problem with loading Rocketlauncher because Hyperspin search for Hyperlaunch.exe (now I have a RocketLauncher.exe.) Which version of Hyperspin are you using, 1.3.3 or 1.4?
gigapig Posted November 6, 2015 Posted November 6, 2015 In your HyperSpin/Settings/Settings.ini file did you change the Hyperlaunch_Path to point to your RocketLauncher.exe? You can't tell him to do that until you find out which version of HS he is using. If he using 1.3.3 then he needs to run the transition tool, 1.4 yes just change the path.
endus Posted November 10, 2015 Posted November 10, 2015 @Crispy yes, I changed Hyperspin to 1.4 and renamed the full path to: Hyperlaunch_Path=E:\RocketLauncher\RocketLauncher.exe And Now it Works
