moleboyz101 Posted September 4, 2015 Posted September 4, 2015 Hi guys, I'm having trouble with almost all of my emulators automatically running in full screen. Is there a .bat file I can create to make this happen automatically? I used a .bat file to get Project64 to launch but I'm not sure how to make a script to make it press like "ALT + ENTER" on startup. Any ideas? I also am having trouble assigning a key other than "ESC" to close the emulator. I know that ESC toggles windows/fullscreen in some and that its a known issue, but I can't seem to figure out a way around it. Pressing ALT + F4 makes most of them crash. Is there an easier way?
gigapig Posted September 4, 2015 Posted September 4, 2015 All that can be done in RLUI. You can now set an Exit Emulator key per system or globally as long as you have the latest version. Setting full screen is normally set in the emulator but that can also normally be changed in the "Edit Global Module Settings" per system under the Modules tab.
