keys not mapping correctly in hyperspin
stevetingate
I have an ipac2 running on windows 8.1, have downloaded the latest version or hyperspin, rocketlauncher and installed, i have gone into ipac and set each key to a letter, and mapped them in hyperhq, so for instance i have the K key for exit in hyperspin, and can type k in notepad, but when i launch hyperspin and select exit, it wont exit it will pause, the same as p1 start, i have that mapped as the J for p1 and T for p2, but when in hyperspin and i select one of there it refreshes and stays at the same menu, all my settings are default, i have set hyperspin as the active frontend, and setup my emulator for mame, any help would be amazing!
  On 9/18/2015 at 1:16 PM, volumetric said:
Are you sure you're running the latest version? This almost sounds like the old 'no speakers plugged in' bug.
hi yes im running latest version, and literally freezeseverything on screen! happy to give someone temviewer access
Hyperspin has a pause button? First I've heard of that unless you actually meant Hyperpause.
The latest version of RocketLauncher made changes to the exit key settings. Just in case that's what you downloaded did you read the new notes on that and follow those directions?
  Quote
RocketLauncher updated to v1.0.1.3
Major note: Part of this update, you must reassign your exit emulator keys to the Global system. Until you do that, the only key that will work is Esc (the default). From there you can customize your exit keys per-system if you like.
Personally I use the ESC key to exit everything on my cab/iPac setup.
