haimbilia Posted September 30, 2015 Posted September 30, 2015 got stuck setting up msdos system. i downloaded the exodos roms but the setup files inside are for meagre. where can i get the bat file that makes all the dirs and conf files?
iNTiGOD Posted October 1, 2015 Posted October 1, 2015 Read the rlauncher module notes for this system. There is plenty of info to get you started. MAME High Score Tutorial For HyperSpin
haimbilia Posted October 1, 2015 Author Posted October 1, 2015 I did thats why im asking for the setup bat file.
iNTiGOD Posted October 3, 2015 Posted October 3, 2015 On 10/1/2015 at 6:25 PM, haimbilia said: I did thats why im asking for the setup bat file. I'll take a look at my setup. Might take a couple days as I'm away from home atm. MAME High Score Tutorial For HyperSpin
damageinc86 Posted October 3, 2015 Posted October 3, 2015 I'd get d-fend reloaded and just add the games you want manually. Unless you seriously want every single game from the thousands available.
iNTiGOD Posted October 4, 2015 Posted October 4, 2015 Belowis the contents of the "Setup eXoDOS.bat" file Cheers @echo off rd dosbox /s /q rd scummvm /s /q del .\util\!NEVRLCK.exe del .\util\!RAWCOPY.exe del .\util\BRC32.exe del .\util\choice.exe del .\util\dosbox.zip del .\util\FBZip.bin del .\util\FBZip.exe del .\util\meagre.zip del .\util\ssr.exe del .\util\scummvm.zip .\util\unzip -o .\util\util.zip -d .\util .\util\unzip -o .\util\skins.zip .\util\unzip -o .\util\meagre.zip .\util\unzip -o .\util\scummvm.zip .\util\unzip -o .\util\dosbox.zip del .\util\meagre.zip del .\util\dosbox.zip del .\util\scummvm.zip copy .\util\unzip.exe .\games\unzip.exe cd games rd !dos /s /q if exist gamesadv.zip unzip -o gamesadv.zip if exist gamesrpg.zip unzip -o gamesrpg.zip if exist gamesstr.zip unzip -o gamesstr.zip if exist gamessim.zip unzip -o gamessim.zip if exist gamesact.zip unzip -o gamesact.zip rem if exist gameswin.zip unzip -o gameswin.zip del unzip.exe cd .. cls echo. echo Would you like to enable Aspect Correction for all game?? echo (Note - You will be able to choose this for each game individually if you run echo the install twice from the menu) echo. echo This is useful for widescreen monitors which cause stretching or distortion, echo although this also changes the output mode of dosbox from 'surface' to echo 'overlay', as surface does not support aspect correction. echo. echo In the event this causes problems, or you wish to revert, please re-run this echo setup file, and choose No. echo. .\util\choice /C:YN /N (Y)es or (N)o If errorlevel = 2 goto aspect2 If errorlevel = 1 goto aspect :aspect copy .\util\ssr.exe .\games\!dos\ssr.exe cls echo. echo Please be patient, this may take a few minutes. echo. @cd games @cd !dos for /F %%a in ('dir /A:D /B') DO ( if exist .\%%a\dosbox.conf ssr 0 aspect=false aspect=true ".\%%a\dosbox.conf" if exist .\%%a\dosbox.conf ssr 0 output=surface output=overlay ".\%%a\dosbox.conf" ) @del ssr.exe cd .. cd .. goto adult :aspect2 copy .\util\ssr.exe .\games\!dos\ssr.exe cls echo. echo Please be patient, this may take a few minutes. echo. @cd games @cd !dos for /F %%a in ('dir /A:D /B') DO ( if exist .\%%a\dosbox.conf ssr 0 aspect=true aspect=false ".\%%a\dosbox.conf" if exist .\%%a\dosbox.conf ssr 0 output=overlay output=surface ".\%%a\dosbox.conf" ) del ssr.exe cd .. cd .. goto adult :adult cls echo. echo Would you like to keep the Adult Games? echo. .\util\choice.exe /C:YN /N (Y)es or (N)o If errorlevel = 2 goto remadult If errorlevel = 1 goto ini :remadult cd games cd !dos rd /s /q dreamweb rd /s /q dreamwbc rd /s /q drivein rd /s /q emanuel rd /s /q farmdaut rd /s /q fascinat rd /s /q freebush rd /s /q fuck1 rd /s /q fuck2 rd /s /q geisha rd /s /q gquest rd /s /q granny rd /s /q JoGuest rd /s /q LSL1 rd /s /q LSL1VGA rd /s /q LSL2 rd /s /q LSL3 rd /s /q LSL5 rd /s /q LSL6CD rd /s /q LSL7DOS rd /s /q menough rd /s /q orionc rd /s /q planlust rd /s /q psychicd rd /s /q purptit rd /s /q qfg45 rd /s /q rexneb rd /s /q sexolym rd /s /q vixens rd /s /q seassaku rd /s /q softporn rd /s /q susan rd /s /q Teresa rd /s /q 3sis rd /s /q vida rd /s /q voy1 rd /s /q VOYEURII rd /s /q xtrek rd /s /q cobmiss rd /s /q kxentar rd /s /q madpara rd /s /q girlcost rd /s /q 15move rd /s /q 5x rd /s /q centsqr rd /s /q coversp rd /s /q dimecity rd /s /q logo rd /s /q phjigsaw rd /s /q phnumb rd /s /q pornpipe rd /s /q Playhous rd /s /q Porntris rd /s /q Sextris rd /s /q SokoSex rd /s /q SPoker+ rd /s /q SPoker2 rd /s /q SPoker3 rd /s /q SPokrPro rd /s /q SPokrPrb rd /s /q Spoker rd /s /q TeenageQ rd /s /q XRock90 rd /s /q adultfil rd /s /q beertriv rd /s /q biing!se rd /s /q drruthsc rd /s /q simusex rd /s /q softprn2 rd /s /q viz rd /s /q bombx rd /s /q Astrotit rd /s /q BarneySp rd /s /q ButtSlam rd /s /q cuntlet rd /s /q DanDolme rd /s /q duke38d rd /s /q imcumb rd /s /q MarbleCo rd /s /q MetalLac rd /s /q rodger rd /s /q UncoverI rd /s /q SuperPan rd /s /q SeXoniX rd /s /q ANightWi rd /s /q AweChas rd /s /q BadBad rd /s /q ChicksDi rd /s /q MadamFif rd /s /q YoungStu rd /s /q WUZ rd /s /q PornoAdv rd /s /q runcity rd /s /q yumemi rd /s /q Fant88 rd /s /q gunblaze rd /s /q blangel rd /s /q Mozaik93 rd /s /q PHStri88 rd /s /q SexyDroi cls cd .. cd .. :ini SET REPLACE=%CD% @echo off >MEAGRE.INI echo [Main] >>MEAGRE.INI echo Width=1280 >>MEAGRE.INI echo Height=720 >>MEAGRE.INI echo UFEPath=%REPLACE%\ >>MEAGRE.INI echo DOSBoxPath=%REPLACE%\dosbox\DOSBox.exe >>MEAGRE.INI echo ScummVMPath=%REPLACE%\scummvm\scummvm.exe >>MEAGRE.INI echo BGColor=clGray >>MEAGRE.INI echo LastSelectedGame=1 >>MEAGRE.INI echo RememberLastSelected=1 >>MEAGRE.INI echo [Fields] >>MEAGRE.INI echo Number= >>MEAGRE.INI echo Name= >>MEAGRE.INI echo Folder= >>MEAGRE.INI echo Subfolder= >>MEAGRE.INI echo Genre= >>MEAGRE.INI echo SubGenre= >>MEAGRE.INI echo SubGenre2= >>MEAGRE.INI echo Publisher= >>MEAGRE.INI echo Developer= >>MEAGRE.INI echo Year= >>MEAGRE.INI echo Executable= >>MEAGRE.INI echo DBConf/ScummID= >>MEAGRE.INI echo Emulator= >>MEAGRE.INI echo Setup= >>MEAGRE.INI echo Front01= >>MEAGRE.INI echo Back01= >>MEAGRE.INI echo Media01= >>MEAGRE.INI echo Title01= >>MEAGRE.INI echo Screen01= >>MEAGRE.INI echo Manual= >>MEAGRE.INI echo Platform= >>MEAGRE.INI echo Designer= >>MEAGRE.INI echo Designer2= >>MEAGRE.INI echo Series= >>MEAGRE.INI echo Series2= >>MEAGRE.INI echo Extra1= >>MEAGRE.INI echo ExtraLink1= >>MEAGRE.INI echo Extra2= >>MEAGRE.INI echo ExtraLink2= >>MEAGRE.INI echo Extra3= >>MEAGRE.INI echo ExtraLink3= >>MEAGRE.INI echo Extra4= >>MEAGRE.INI echo ExtraLink4= >>MEAGRE.INI echo Extra5= >>MEAGRE.INI echo ExtraLink5= >>MEAGRE.INI echo About= >>MEAGRE.INI echo [Subfolders] >>MEAGRE.INI echo !win3x= >>MEAGRE.INI echo !dos= >>MEAGRE.INI MAME High Score Tutorial For HyperSpin
