Rocketlauncher Transition hyperspin1.3
atrain9
Hello , I recently updated my hyperspin1.3 with the rocketlauncher transition pack. After doing so according to a youtube video I am getting an error "cannot find hyperlaunch.exe" when i try and launch a game in hyperspin.   I am at such a loss because everything was working so perfectly for a long time.  Any help would be greatly appreciated.  If you can remote in or help me in any way it would be greatly appreciated ! please let me know . Thanks :)
Make sure your \HyperSpin\Settings\Settings.ini file has been updated to change this line to something like this:
Hyperlaunch_Path=C:\Arcade\RocketLauncher\RocketLauncher.exe
thanks for your response sir!  am i pointing it to run the rocketlauncherUI.exe?
Not the UI executable... the other one.
really sorry for the confusion here on my part so i shoud stay away from the rocketlauncherUI folder when naming it ?
This is the path to put in your settings file:
[wherever]\RocketLauncher\RocketLauncher.exe
you are using Hyperspin 1.3
you need to add
NO!!!!!!  RocketLauncher.exe
at the end.
if you ever upgrade to hyperspin 1.4 then you will need the full path
you need to add
at the end.
Ahhh... is that specific to 1.3? I don't remember that part. I thougth you still needed to specify the exe?
My path is D:\\Arcade\RocketLauncher\
I am still getting the "cannot find hyperlaunch.exe"  error when i try and play a game within hyperspin???
Thanks for all the responses here!  Forgive me for being new to this but can anyone point me in the right direction as to how I post logs?
02:34:44 PM |  HyperSpin Started
02:34:44 PM |  Going FullScreen
02:34:44 PM |  Checking for updates
02:34:44 PM |  Update Check Complete
02:34:44 PM |  Startup program unavailable
02:34:44 PM |  Playing intro video
02:34:47 PM |  Error intializing joysticks
02:34:47 PM |  Menu Mode is multi
02:34:47 PM |  Loading Main Menu.xml
02:34:47 PM |  Main Menu.xml successfully loaded
02:34:48 PM |  Main Menu wheel loaded successfully
02:34:51 PM |  Loading MAME.xml
02:34:52 PM |  Main Menu.xml successfully loaded
02:34:53 PM |  MAME wheel loaded successfully
02:34:56 PM |  Launching Game
02:34:57 PM |  Using HyperLaunch
02:34:57 PM |  Getting HyperLaunch path
02:34:57 PM |  HyperLaunch located at D:\Arcade\HyperLaunch.exe
02:34:57 PM |  Cannot find Hyperlaunch.exe
02:35:02 PM |  Loading Main Menu.xml
02:35:02 PM |  Main Menu.xml successfully loaded
02:35:03 PM |  Main Menu wheel loaded successfully
02:35:06 PM |  Exit program: clear.bat
02:35:06 PM |  Exit params not set
02:35:06 PM |  Working directory: D:\Arcade\
02:35:06 PM |  Window State: NORMAL
02:35:06 PM |  Launching clear.bat
02:35:06 PM |  Command Line is clear.bat
02:35:06 PM |  Quiting Hyperspin
02:35:06 PM |  Bye!
15:30:35:978 | RL |   DEBUG1  | +0     | setLogMode Called [newlogMode=1, newFile=1]
15:30:36:054 | RL |   DEBUG1  | +76    | getServiceStatus Called [serviceName=Winmgmt]
15:30:36:076 | RL |   DEBUG1  | +22    | ServiceController status is :Running
15:30:36:077 | RL |   DEBUG1  | +1     | Service Winmgmt detected as running
15:30:36:287 | RL |   DEBUG1  | +210   | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk, isModule=false]
15:30:36:360 | RL |   DEBUG1  | +73    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk, isModule=false]
15:30:36:403 | RL |   DEBUG1  | +43    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk, isModule=false]
15:30:36:409 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk, isModule=false]
15:30:36:415 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk, isModule=false]
15:30:36:427 | RL |   DEBUG1  | +12    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\Java.ahk, isModule=false]
15:30:36:433 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk, isModule=false]
15:30:36:446 | RL |   DEBUG1  | +13    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk, isModule=false]
15:30:36:452 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk, isModule=false]
15:30:36:456 | RL |   DEBUG1  | +4     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk, isModule=false]
15:30:36:464 | RL |   DEBUG1  | +8     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk, isModule=false]
15:30:36:469 | RL |   DEBUG1  | +5     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\VA.ahk, isModule=false]
15:30:36:474 | RL |   DEBUG1  | +5     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk, isModule=false]
15:30:36:481 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\7z.ahk, isModule=false]
15:30:36:487 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Bezel.ahk, isModule=false]
15:30:36:494 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Fade.ahk, isModule=false]
15:30:36:501 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Fade Init.ahk, isModule=false]
15:30:36:506 | RL |   DEBUG1  | +5     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk, isModule=false]
15:30:36:514 | RL |   DEBUG1  | +8     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Pause.ahk, isModule=false]
15:30:36:528 | RL |   DEBUG1  | +14    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Pause Init.ahk, isModule=false]
15:30:36:534 | RL |   DEBUG1  | +5     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Keymapper.ahk, isModule=false]
15:30:36:541 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk, isModule=false]
15:30:36:546 | RL |   DEBUG1  | +5     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\MultiGame.ahk, isModule=false]
15:30:36:553 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk, isModule=false]
15:30:36:566 | RL |   DEBUG1  | +13    | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk, isModule=false]
15:30:36:572 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Password.ahk, isModule=false]
15:30:36:578 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk, isModule=false]
15:30:36:585 | RL |   DEBUG1  | +7     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Shared.ahk, isModule=false]
15:30:36:593 | RL |   DEBUG1  | +8     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Statistics.ahk, isModule=false]
15:30:36:599 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk, isModule=false]
15:30:36:605 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk, isModule=false]
15:30:36:611 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\XHotkey.ahk, isModule=false]
15:30:36:617 | RL |   DEBUG1  | +6     | checkModuleCRC Called [fileName=D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk, isModule=false]
15:30:36:025 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
15:30:36:040 | RL |  WARNING  | +16    | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
15:30:36:231 | RL |     INFO  | +188   | Main - System Specs:
RocketLauncher Dir: D:\Arcade\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 10 Pro
SKU: Professional
Total Memory: 8183.11 MB
Free Memory: 3049.41 MB
Used Memory: 5133.703 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 12
GPU 1 Name: AMD Radeon HD 5800 Series
GPU 1 RAM: 1024.00 MB
GPU 1 Driver Version: 15.200.1062.1004
Sound 1 Device: Realtek High Definition Audio
Sound 1 Status: Enabled
Sound 2 Device: HD Webcam C525
Sound 2 Status: Enabled
Sound 3 Device: AMD High Definition Audio Device
Sound 3 Status: Enabled
Sound 4 Device: PlayOn Virtual Audio Device
Sound 4 Status: Enabled
OS Admin Status: Yes
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1280x720 (1280x680 work) [Landscape] (Primary)
Current AHK Desktop Width: 1280
Current AHK Desktop Height: 720
AutoHotkey Path:
AHK Version: 1.1.09.04
Unicode: No
15:30:36:243 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
15:30:36:258 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
FileDescription         RocketLauncher
FileVersion             1.0.1.3
LegalCopyright           ©2015 RocketLauncher
ProductName             djvj's one swell guy!
ProductVersion           1.1.9.4
CompanyName             Your favorite Front End companion! Visit us @ www.rlauncher.com
File Size: 2061824 bytes
Created: 10/4/2015 - 2:21:46 PM
Modified: 10/4/2015 - 2:26:11 PM
15:30:36:273 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BinHexRW.ahk exists
15:30:36:292 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:303 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 4961 bytes
Created: 10/4/2015 - 2:28:12 PM
Modified: 10/4/2015 - 2:28:12 PM
15:30:36:316 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\BlockInput.exe exists
15:30:36:332 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
FileDescription
FileVersion             1.1.09.04
InternalName
OriginalFilename
ProductName
ProductVersion           1.1.09.04
File Size: 657920 bytes
Created: 9/2/2014 - 11:37:08 PM
Modified: 3/2/2014 - 12:57:11 PM
15:30:36:345 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\CLR_L.ahk exists
15:30:36:361 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:375 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 5474 bytes
Created: 10/4/2015 - 2:29:37 PM
Modified: 10/4/2015 - 2:29:38 PM
15:30:36:389 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
15:30:36:405 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:407 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 5716 bytes
Modified: 11/7/2013 - 7:44:34 PM
15:30:36:408 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip.ahk exists
15:30:36:412 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:413 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 88789 bytes
15:30:36:414 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gdip_alt.ahk exists
15:30:36:417 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:419 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 5895 bytes
Created: 10/4/2015 - 2:28:10 PM
Modified: 10/4/2015 - 2:28:10 PM
15:30:36:419 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
15:30:36:420 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\gsdll32.dll exists
15:30:36:421 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 13090816 bytes
Modified: 10/4/2015 - 2:26:30 PM
15:30:36:422 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\itextsharp.dll exists
15:30:36:424 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
FileDescription         iTextSharp
FileVersion             5.4.2.0
InternalName             itextsharp.dll
LegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
OriginalFilename         itextsharp.dll
ProductName             iTextSharp
ProductVersion           5.4.2.0
CompanyName             1T3XT BVBA
File Size: 3743744 bytes
Modified: 11/7/2013 - 7:44:36 PM
15:30:36:425 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Java.ahk exists
15:30:36:428 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:430 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 7841 bytes
Created: 10/4/2015 - 2:27:12 PM
Modified: 10/4/2015 - 2:27:12 PM
15:30:36:431 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
15:30:36:432 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\JSON.ahk exists
15:30:36:434 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:444 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
File Size: 9203 bytes
Modified: 11/7/2013 - 7:44:35 PM
15:30:36:445 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Origin.ahk exists
15:30:36:447 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:449 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 4904 bytes
Created: 10/4/2015 - 2:27:53 PM
Modified: 10/4/2015 - 2:27:53 PM
15:30:36:450 | RL |   DEBUG1  | +16    | Origin.ahk Version: 1.0.2
15:30:36:451 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RegRW64.ahk exists
15:30:36:453 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:454 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 6915 bytes
Created: 10/4/2015 - 2:31:08 PM
Modified: 10/4/2015 - 2:31:08 PM
15:30:36:455 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\RIni.ahk exists
15:30:36:459 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:460 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 67561 bytes
15:30:36:461 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
15:30:36:462 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
FileDescription         SevenZipSharp
FileVersion             0.64.5717.6837
InternalName             SevenZipSharp.dll
LegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
OriginalFilename         SevenZipSharp.dll
ProductName             SevenZipSharp
ProductVersion           0.64.5717.6837
CompanyName             Markovtsev Vadim
File Size: 167424 bytes
Modified: 10/4/2015 - 2:26:42 PM
15:30:36:463 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\Steam.ahk exists
15:30:36:465 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:467 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 5347 bytes
Created: 10/4/2015 - 2:26:59 PM
Modified: 10/4/2015 - 2:26:59 PM
15:30:36:468 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
15:30:36:469 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA.ahk exists
15:30:36:471 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
15:30:36:473 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 34688 bytes
15:30:36:473 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\VA_Extension.ahk exists
15:30:36:476 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:479 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 3833 bytes
Created: 10/4/2015 - 2:28:21 PM
Modified: 10/4/2015 - 2:28:21 PM
15:30:36:480 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
15:30:36:480 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\7z.ahk exists
15:30:36:483 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:484 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 29013 bytes
Created: 10/4/2015 - 2:31:02 PM
Modified: 10/4/2015 - 2:31:02 PM
15:30:36:485 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
15:30:36:486 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Bezel.ahk exists
15:30:36:490 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:492 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 102587 bytes
Created: 9/2/2014 - 11:36:47 PM
Modified: 10/4/2015 - 2:28:37 PM
15:30:36:493 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
15:30:36:493 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade.ahk exists
15:30:36:496 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:498 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 38048 bytes
Modified: 10/4/2015 - 2:30:28 PM
15:30:36:499 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.2
15:30:36:500 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Init.ahk exists
15:30:36:502 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:503 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 999 bytes
Modified: 10/4/2015 - 2:29:37 PM
15:30:36:504 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
15:30:36:505 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Fade Animations.ahk exists
15:30:36:509 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:511 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 79882 bytes
Modified: 10/4/2015 - 2:29:21 PM
15:30:36:512 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.8
15:30:36:513 | RL |     INFO  | +15    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause.ahk exists
15:30:36:523 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:525 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 392698 bytes
Created: 10/4/2015 - 2:26:39 PM
Modified: 10/4/2015 - 2:26:40 PM
15:30:36:526 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
15:30:36:527 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Pause Init.ahk exists
15:30:36:529 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:532 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 553 bytes
Created: 10/4/2015 - 2:26:32 PM
Modified: 10/4/2015 - 2:26:32 PM
15:30:36:532 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
15:30:36:534 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper.ahk exists
15:30:36:536 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:538 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 33453 bytes
Modified: 10/4/2015 - 2:27:15 PM
15:30:36:539 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
15:30:36:540 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Keymapper Init.ahk exists
15:30:36:542 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:543 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 3461 bytes
Modified: 10/4/2015 - 2:29:23 PM
15:30:36:544 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
15:30:36:545 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame.ahk exists
15:30:36:548 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:550 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 40753 bytes
Modified: 10/4/2015 - 2:27:03 PM
15:30:36:551 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
15:30:36:552 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiGame Init.ahk exists
15:30:36:554 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:556 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 161 bytes
15:30:36:557 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
15:30:36:558 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\MultiPlayer.ahk exists
15:30:36:568 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:570 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 58770 bytes
Created: 10/4/2015 - 2:26:37 PM
Modified: 10/4/2015 - 2:26:37 PM
15:30:36:571 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
15:30:36:571 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Password.ahk exists
15:30:36:573 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:575 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 10025 bytes
Created: 10/4/2015 - 2:28:28 PM
Modified: 10/4/2015 - 2:28:28 PM
15:30:36:576 | RL |   DEBUG1  | +16    | Password.ahk Version: 1.0.2
15:30:36:577 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
15:30:36:580 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:582 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 73772 bytes
Modified: 10/4/2015 - 2:30:42 PM
15:30:36:583 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
15:30:36:584 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Shared.ahk exists
15:30:36:589 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:590 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 116503 bytes
Modified: 10/4/2015 - 2:26:58 PM
15:30:36:591 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.2
15:30:36:592 | RL |     INFO  | +16    | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics.ahk exists
15:30:36:595 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:596 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 26143 bytes
Modified: 10/4/2015 - 2:29:58 PM
15:30:36:597 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
15:30:36:598 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Statistics Init.ahk exists
15:30:36:600 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:602 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 33 bytes
Modified: 10/4/2015 - 2:26:09 PM
15:30:36:604 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
15:30:36:604 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\Virtual Drive.ahk exists
15:30:36:607 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:608 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
File Size: 18333 bytes
Created: 10/4/2015 - 2:26:52 PM
Modified: 10/4/2015 - 2:26:53 PM
15:30:36:609 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.2
15:30:36:610 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey.ahk exists
15:30:36:613 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:614 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 26540 bytes
Modified: 10/4/2015 - 2:29:54 PM
15:30:36:615 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
15:30:36:616 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Lib\XHotkey Init.ahk exists
15:30:36:618 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
15:30:36:619 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
File Size: 1063 bytes
Modified: 10/4/2015 - 2:28:00 PM
15:30:36:620 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
15:30:36:621 | RL |     INFO  | +0     | GetSystems - Started
15:30:36:622 | RL |     INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncherUI\Databases\Systems.xml exists
15:30:36:624 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
File Size: 21 bytes
Created: 10/4/2015 - 2:25:17 PM
Modified: 10/4/2015 - 2:25:17 PM
15:30:36:624 | RL |     INFO  | +0     | GetSystems - Found a RocketLauncher Systems.xml: "D:\Arcade\RocketLauncher\RocketLauncherUI\Databases\Systems.xml"
15:30:36:626 | RL |   DEBUG1  | +0     | GetSystems - Parsing the systems xml
15:30:36:635 | RL |     INFO  | +0     | GetSystems - Ended
15:30:36:672 | RL |     INFO  | +47    | Main - RocketLauncher launched directly
15:30:49:145 | RL |     INFO  | +12468 | GuiClose - User exited via GUI
15:30:49:146 | RL |     INFO  | +0     | ExitScript - Started
15:30:49:266 | RL |     INFO  | +125   | SystemCursor - Restoring mouse cursor
15:30:49:296 | RL |     INFO  | +32    | ExitScript - Ended
when you ask for help you need to set your rocketluancher log to troubleshoot.. the log you posted has very little information to read.
your problem (witch you already knew) is with hyperspin finding the Rocketlauncher exe.
and I'm not sure why its not finding it.
this is probably the path to Hyperlaunch 2 ---> D:\Arcade\HyperLaunch.exe
Are you sure you have Hypersin 1.3  (the rockelauncher log would of confirmed this but its not set to troubleshoot)
if this is your path in your settings ini. (other then the double backslash I don't see a problem)
but your RocketLauncher log has the correct one
have you thought about upgrading to Hyperspin version 1.4?
this would eliminate the need for you to use the transition tool and  you can set your path directly to Rocketlauncher.
ok let me check to se if i can put it to trouble shoot .  how do i update to 1.4 , im a little nervous to lose everything and mess it up even more ??
INFO  2015-10-06 06:30:30 [1] RocketLauncher.UI.Util.FileUtils RocketLauncher.UI.Util.FileUtils.findDllFolder(:0) – 7z.dll found in D:\Arcade\RocketLauncher\RocketLauncherUI\lib
DEBUG 2015-10-06 06:30:30 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni..ctor(:0) – RocketLauncherUI ini file path is D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2015-10-06 06:30:30 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2015-10-06 06:30:30 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni.readIniValues(:0) – Window coordinates are : 653.333333333333|686.666666666667|633.333333333333|0
DEBUG 2015-10-06 06:30:30 [1] RocketLauncher.UI.Util.AdsUtil RocketLauncher.UI.Util.AdsUtil.checkIfFileIsBlocked(:0) – Security zone for 'D:\Arcade\RocketLauncher\Module Extensions\RocketLauncher.dll' is MyComputer
DEBUG 2015-10-06 06:30:30 [1] RocketLauncher.UI.Database.DatabasePluginManager RocketLauncher.UI.Database.DatabasePluginManager.BuildAssembly(:0) – LinqXML is at C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll
DEBUG 2015-10-06 06:30:32 [1] RocketLauncher.UI.Database.DatabasePluginManager RocketLauncher.UI.Database.DatabasePluginManager.BuildAssembly(:0) – LinqXML is at C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll
DEBUG 2015-10-06 06:30:33 [1] RocketLauncher.UI.Database.DatabasePluginManager RocketLauncher.UI.Database.DatabasePluginManager.BuildAssembly(:0) – LinqXML is at C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll
DEBUG 2015-10-06 06:30:34 [1] RocketLauncher.UI.Database.DatabasePluginManager RocketLauncher.UI.Database.DatabasePluginManager.BuildAssembly(:0) – LinqXML is at C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.FrontendIni RocketLauncher.UI.Ini.FrontendIni..ctor(:0) – Frontends ini file path is D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\Frontends.ini
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni..ctor(:0) – RocketLauncherUI ini file path is D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\RocketLauncherUI\Settings\RocketLauncherUI.ini
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.RocketLauncherUIIni RocketLauncher.UI.Ini.RocketLauncherUIIni.readIniValues(:0) – Window coordinates are : 653.333333333333|686.666666666667|633.333333333333|0
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Main Folder is D:\Arcade\RocketLauncher
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Emulator Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Game Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing RocketLauncher Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Global RocketLauncher Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\RocketLauncher.ini
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Pause Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Bezel Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Initializing Plugins Settings...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Frontend folder is D:\Arcade
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – Reading RLUI version
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow..ctor(:0) – AssemblyVersion is 1.0.0.7, FileVersion is 1.0.0.7
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Loading systems...
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – RLUI Media folder is set to : .\Media
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Searching for icons in : D:\Arcade\RocketLauncher\RocketLauncherUI\Media\Icons\GLOBAL.png
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.loadSystems(:0) – Searching for logos in : D:\Arcade\RocketLauncher\RocketLauncherUI\Media\Icons\GLOBAL.png
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.refreshSystemsList(:0) – Database being read from Main Menu.xml according to plugin
DEBUG 2015-10-06 06:30:35 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.refreshSystemsList(:0) – Loading systems complete. 124 systems found
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel.CheckWinMgmtService(:0) – Detecting if WMI Service is running...
INFO  2015-10-06 06:30:40 [1] RocketLauncher.UI.Controls.RocketLauncherUIPanel RocketLauncher.UI.Controls.RocketLauncherUIPanel.CheckWinMgmtService(:0) – WMI Service is running
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.updateWindowTitle(:0) – Updating Main Window title...
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Forms.BaseWindow RocketLauncher.UI.Forms.BaseWindow.updateWindowTitle(:0) – Main Window title Updated to RocketLauncherUI v1.0.0.7 [ FE = Hyperspin | Plugin = HyperSpin ]
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\Global RocketLauncher.ini
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\Global Pause.ini
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\Global Bezel.ini
DEBUG 2015-10-06 06:30:40 [1] RocketLauncher.UI.Ini.IniFile RocketLauncher.UI.Ini.IniFile..ctor(:0) – Loading INI File D:\Arcade\RocketLauncher\Settings\Global Plugins.ini
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading Joystick Names...
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading AHK Profiles...
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading JoyToKey Profiles...
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading xPadder Profiles...
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Loading VJoy Profiles...
DEBUG 2015-10-06 06:30:41 [1] RocketLauncher.UI.Util.KeymapperLoader RocketLauncher.UI.Util.KeymapperLoader.listKeymapperProfiles(:0) – Profiles loading complete
DEBUG 2015-10-06 06:30:42 [1] RocketLauncher.UI.Updater.AutoUpdater RocketLauncher.UI.Updater.AutoUpdater.getMD5Hash(:0) – Calculating hash for file
DEBUG 2015-10-06 06:30:42 [1] RocketLauncher.UI.Updater.AutoUpdater RocketLauncher.UI.Updater.AutoUpdater.getCRC32(:0) – Calculating crc for file
DEBUG 2015-10-06 06:30:42 [1] RocketLauncher.UI.Updater.SimpleAES RocketLauncher.UI.Updater.SimpleAES.releaseObjects(:0) – Releasing encryptor objects
I have a working Hyperspin configuration on another drive which is all set up.  Is there a way to move or transfer over some of the files from the working copy to fix the bad copy im having all this trouble with (above....)??   may be easier if someone could guide me on how to do that???  Thanks
