FrankyRizzo Posted October 8, 2015 Posted October 8, 2015 I thought I read this being worked in last year. However since the site upgrade I cant find it via google. Is there a way to make epsxe load a new memory card for each psx title? Otherwise after playing a few games I will need to keep swapping cards based on the games I wanna play before I launch hyperspin.
rfancella Posted October 9, 2015 Posted October 9, 2015 Hi, If your modules are all up-to-date, it already does that. Check the module notes and module settings. I believe it does it as default. If you find otherwise, post over at the RL forum and I'll be glad to take a peek at it. Thanks, Ron I thought I read this being worked in last year. However since the site upgrade I cant find it via google. Is there a way to make epsxe load a new memory card for each psx title? Otherwise after playing a few games I will need to keep swapping cards based on the games I wanna play before I launch hyperspin. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
