waddlecaudle Posted October 20, 2015 Posted October 20, 2015 So I know this is specific, but it seems some other articles/posts run into a somewhat similar issue. I have Retroarch, and from the RocketLauncherUI I am able to successfully load all of the emulators I want to. However, from Hyperspin, only the most recently emulator loaded directly from Retroarch will successfully load, all others go to a black screen. Example. If I load Super Mario 64 from Retroarch using detect core it loads perfectly. I can then go into Hyperspin and load Goldeneye64 no problem. Now if I go to load Sonic the screen goes black. Back out, open Retroarch, detect core load Sonic. Loads fine. Go back to Hyperspin, load Lion King for Sega and all is well. Go to load Goldeneye64 and get a black screen. This can be repeated for other systems, so it seems it is dependent on the most recently loaded system. I have turned on settings per core and turned them off. Off it loads a window with an overflow of gibberish (likely from the bad core config). This goes for the settings in RocketLauncherUI and Retroarch. I can't figure it, but it is so close to working... Rather frustrating. Also, have the specific cores selected for each system in the system specific Retroarch configuration within RocketLauncherUI. Any help is appreciated. Windows 8.1.
thcdgaf Posted October 21, 2015 Posted October 21, 2015 make sure your using retroarch 1.22 from the site http://buildbot.libretro.com/stable/1.2.2/ not sure if link is allowed if not delete it mods and it works when you say sonic which system and which core you using i use gensis plus gx core for all sega mostly but sega saturn i use ssf
thcdgaf Posted October 21, 2015 Posted October 21, 2015 also sounds like bad roms did you look in your logg?
waddlecaudle Posted October 22, 2015 Author Posted October 22, 2015 @thcdgaf just updated to the latest stable version. Now I'm getting a blank console and retroarch doesn't load (similar situation as explained before just console instead of blank screen). The roms should be good, just used random ones as an example but all of them I have run directly through retroarch run. Thanks for all suggestions.
kylecp1979 Posted October 22, 2015 Posted October 22, 2015 Sounds like you have config problems I would set everything back to default or re-download it and start over. just download all your cores you want run all of them to make sure they work. Set retroarch up just like any other emulator in the global setting then just set your rom paths for your systems and select retroarch as your emulator. If you want different setting for each systems lunch it through rocketluncher or hyperspin and hit F1 then set your setting as you like then hit save new config. Then go to your config folder in retroarch and name the new config file the same name as your system. easy way to find the recent file is sort by date should be the top one. I hope that helps you.
thcdgaf Posted October 22, 2015 Posted October 22, 2015 Are you saying you can't run it in rlui if so you gotta have have name of config file same as xml name convention then on rlui go to modules then go to retroarch module and edit global settings point the config to config of system you are wanting to run and the do configuration per core to yes Sent from my LGL16C using Tapatalk
waddlecaudle Posted October 22, 2015 Author Posted October 22, 2015 Hey @kylecp1979 I was hoping to avoid a full reinstall. I can assume (since updating retroarch didn't work) it is something in my HyperLaunchHQ configuration for the individual wheels that is causing it or the RocketLauncherUI configuration for the emulator so I am going to try setting some of those back to default and see how it goes. @thcdgaf I can open all games fine from RocketLauncherUI, it is only from Hyperspin I am having any issues. Thanks for the help/recommendations guys
thcdgaf Posted October 22, 2015 Posted October 22, 2015 which hyperspin are you using? look at your hyperspin log file i notice sometimes you have to do transition tool even though its not required to make hyperspin work
waddlecaudle Posted October 22, 2015 Author Posted October 22, 2015 @thcdgaf I redid the transition process and that did it. Thanks so much guys for the help!
thcdgaf Posted October 22, 2015 Posted October 22, 2015 Your welcome man Sent from my LGL16C using Tapatalk
