Virtual Output kit setup
zeenon
So I am trying to wrap my hands around setting up Zebs VOK board with his shaker/gear combo and single 12V start button (just as a proof of concept before I add everything else).
As far as the physical connections I have the ribbon cable from the LEDwiz 17-32 going to the bottom flasher board, and the other ribbon going from the LEDwiz 1-16 to the inductor board. 500W Corsair power supply - 20 pin power going to flasher board, 4 pin molex going to the inductor board, and another 4 pin molex going to shaker/gear. I check continuity before mounting the LEDwiz and VOK from pins 1-32. Powered everything up and looks good...3 LEDs lit on VOK.
Software wise I put these files in my Hyperpin directory:
FPLaunch.exe (using FPLaunch 1.295 WIP 10)
HPLedControl.exe
HPLedControl.ini
Put these files in my VP Tables directory:
core.vbs (version 3.42)
ledcontrol.ini (Downloaded this from Zebs site)
ledcontrol.vbs
ledwizm05.ocx
Register the ocx file by typing this on the command line as admin:
Regsvr32 ledwizm05.ocx
(Successfully register dialog box)
So I fire up a random table (Elvira and the Party Monsters) and start playing and get no shaker/gear or start button light. VOK set for 12V, and I tested the button on a 12V supply. I'm sure there is more to this puzzle that I missed???
Z
Silly question I'm sure, but did ou hook the signal lines for the shaker and gear motor to the shaker and gear terminals on the board? I ask because you didn't list them in your connections.
The 12v start button....did you switch the front panel jumper (beside the led on the upper board) to 12v? I ship it set at 5v.
I know so much about so little that I could teach you everything there is to know about nothing....
I really thought that this was going to be a lot harder to setup......simple issue.....the default line for eatpm does not light the start button. Tried a different table and it worked. Thanks Steve!!!!
Z
Glad you got it working.
