chrisvond Posted November 15, 2015 Posted November 15, 2015 I am building a cabinet of a Google Sketchup design that uses in 3/4 inch MDF. I live in Australia so our MDF comes in mm. 3/4 inch would be 19.05 mm so the closest would be 18mm MDF, Will this cause me issues working from the plans or I should be right? Thanks guys
iNTiGOD Posted November 15, 2015 Posted November 15, 2015 18mm has been fine for all the cabs I've built.... MAME High Score Tutorial For HyperSpin
madhatter3339 Posted November 15, 2015 Posted November 15, 2015 the only problem I can see would be the t-molding!! Just check t-molding thickness!!
Anpanman Posted November 15, 2015 Posted November 15, 2015 the only problem I can see would be the t-molding!! Just check t-molding thickness!! Seriously, if you scope up your router exactly, you won't notice the microscopic lip on each end.
