PixelBlitterBoy Posted December 10, 2015 Posted December 10, 2015 Evening fellow Arcadian's, Currently got my HTPC setup running: HyperSpin v1.4 RocketLauncher v1.0.1.4 RocketLauncher UI v1.0.0.9 + Using Xpadder v2014.01.01 + MS Xbox 360 Controller All is setup with the above applications (seemingly). I have currently setup my first system [Commodore 64], using (WinVICE-2.4-x64). As mentioned this is all working fine: games audited fine, artwork linked in fine and emulator launched no problems (with and without HS). The issue I am having is when I launch a game within the [Commodore 64] system wheel in (HS). (HS) application does not minimise or pause/stop, it keeps utilising my controller in the background whilst the (WinVice) emulator in the foreground loads the chosen game. I have setup (Xpadder) with the applicable profiles for both (HS) and (WinVice) to swap over controller inputs: HyperSpin - Z:\RocketLauncher\Profiles\Xpadder\HyperSpin\p1.xpadderprofile C64 System - WinVice - Z:\RocketLauncher\Profiles\Xpadder\Commodore 64\_Default\p1.xpadderprofile Now I believe these are swapping over once I launch a game from the [Commodore 64] wheel. But I cannot confirm this, due to (HS) still having control of my Xbox 360 in the background whilst (WinVice) in the foreground loads up the chosen game file. I also cannot seem to find any settings on (RLUI / HSHQ) to solve this issue prior to my post If anyone can offer a suggestion or advice I would be very grateful, or if further information is required (screenshots etc.) I would be happy to assist....If this is a very newb oversight, my apologise...I have scoured the forum and youtube (Simply Austin etc.), and cannot find any similar issues...prior to popping a post on here. Many thanks in advance. Chris C. ❤ For the love of Pixels (̿▀̿‿ ̿▀̿ ̿) www.pixelretro.co.uk ☆ fb.pixelretro.xy ☆ insta.pixelretro.xyz ☆ twitter.pixelretro.xyz ☆ youtube.pixelretro.xyz
PixelBlitterBoy Posted December 10, 2015 Author Posted December 10, 2015 [uPDATE] Xpadder does change profiles from (HyperSpin) control profile to (WinVice) control profile. However once I launch a game from within the [Commodore 64] wheel it brings (WinVice) to the foreground, whilst still running (Hyperspin) in the background - i.e. Sound, Theme Video and control functions all playing, as if it has not change priority to the launched emulator (WinVice) window - even though it is behind the actual emulator!!!????? Also I have setup [sega Genesis] using (RetroArch) and this works fine through (HyperSpin) no problems with background conflict like the above. Any helpers? Cheers Chris. ❤ For the love of Pixels (̿▀̿‿ ̿▀̿ ̿) www.pixelretro.co.uk ☆ fb.pixelretro.xy ☆ insta.pixelretro.xyz ☆ twitter.pixelretro.xyz ☆ youtube.pixelretro.xyz
Styphelus Posted December 10, 2015 Posted December 10, 2015 I had a similar issue but I'm at work and can't look into it. When I setup a system, Rocketluncher show's me 2 profiles. One for the systemprofile I created and a 360 controller profile. What I did was copy my system profile to the 360 Controller profile and that did the trick. Basically, my 360 profile was empty and Hyperspin was switching from the Hyperspin profile to the 360 controller profile for that particular system and since it was empty, it just reverted back to the Hyperspin profile. If you go on your Rocketluncher folder under profiles and pick a system profile, you will see that under each profile there's a 360 controller profile. I just made a copy of the system profile into this folder. not sure if this will fix your problem but it worked for me.
ninja2bceen Posted December 10, 2015 Posted December 10, 2015 I'd use joytokey instead of xpadder. Plus if you get bliss box then it will be plug n play Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
PixelBlitterBoy Posted December 16, 2015 Author Posted December 16, 2015 [uPDATE] Afternoon all, I have recently re-installed my setup from scratch following the great tutorials on here and now have the following setup configured: HyperSpin v1.4 RocketLauncher v1.0.1.4 RocketLauncher UI v1.0.0.9 + Using JoyToKey v5.8.0.360 [Registered] + MS Xbox 360 Controller +Currently setup up - Commodore 64 Wheel using [WinVice] All the above is working great. Hyperspin launches fine, JoyToKey launches [HYPERSPIN] profile which functions perfectly with Xbox 360 Controller. I select the Commodore 64 wheel > Game of choice (All work through WinVice standalone and also from RocketLaunchUI). WinVice takes over, bringing itself to the foreground and loads the Rom/Game up no problems - Also JoyToKey changes profile to the new [system Profile] for the Commodore 64. My problem/issue is (as it was above when I was using the xpadder setup), it doesn't lose focus/priorty of the Hyperspin frontend. When I am pressing any button on the controller and any key on the keyboard, it moves and controls the Hyperspin wheel in the background and not the current emulator (WinVice) which is currently running in the foreground. This is really doing my head in with regards to why it is doing this....am I missing a tick box or parameter to stop/pause functionality with Hyperspin? Any help or advice would be greatly appreciated...or if you need any further info, logs, screenshot - just let me know! Many thanks in advance. C. ❤ For the love of Pixels (̿▀̿‿ ̿▀̿ ̿) www.pixelretro.co.uk ☆ fb.pixelretro.xy ☆ insta.pixelretro.xyz ☆ twitter.pixelretro.xyz ☆ youtube.pixelretro.xyz
