HLSL Filter + Bezel not working. filter gets scaled
flyer6
Hi
I have an issue with MAME.
I've set up everything fine and working. HLSL Filter is working flawlessly and looks AMAZING. I use the new filter included in the recent official mameuifx version. I wanted to try out the amazing bezels from alexdc (http://www.hyperspin-fe.com/topic/2774-bezels-for-mame-custom-for-16x9-resolutions/page-1?hl=bezel)
Having already set up the HLSL, setting up the bezels in rocketlauncher UI scales the image and filter and makes it look absolutely horrible.
Bezel is showing up. Scales the whole image according to the bezels ini and the hlsl filter looks horrible (get's scaled with it).
I understand the image must be scaled for the bezel to look good... but is there a way to not scale the hlsl filter or maybe use a better one?
the hlsl filter in rocketlauncher ui is set to ini, not true nor default.
Hope you can help me. Thanks a lot.
tom
I had the same issue... particularly with vertical games. Regrettably, I ended up just moving to GLSL. I still prefer the look of HLSL, but not enough to deal with this.
Glsl is way better. Have the same problem with hlsl, until i discover the "gigabuild" from gigapig
Envoyé depuis midgar, entre deux raids sur les réacteurs mako
