Can you have one Theme pick the art work by rom name?
I want to make one theme and use it for all games but just putting the artwork in the proper folder with the same name as the rom.
Is there a way? Am I asking for too much?
so you want a default theme?......make a theme call it default and place it in the MAME theme folder HyperSpin\Media\MAME\Themes
if you want say.....flyers to show up in the theme for each game, add them to artwork2 in the theme that is opened up in Hypertheme and on the bottom left you can select don't include in output. the drop all flyers with the correct naming per rom in the artwork2 folder HyperSpin\Media\MAME\Images\Artwork2
if that is what you mean
THk also had the same answer for you, its basiclly the same thing
You can make one theme and name it default, remove the artwork from the zip that you want to be game dependand. Then put the artwork in the correct artwork directory for the artwork layer you assigned. The game dependend artwork has to be named exactly as the xml-entry/rom/wheel.
When the artwork layer (for instance Artwork3) isn't in the theme zip, HS will call the artwork named after the game from the artwork folder (...\Images\Artwork3)
