Set alternate exit key per system?
demonseed
Pinball FX2 uses my xbox triggers to play. I have the front right trigger set as an alternate exit key.  Is there a way to not have it set to that for Pinball FX2 only? I am not sure.
You have a main button assigned as your exit key? I believe you can assign your exit key on a per system basis using RocketLauncher now, but I'd really recommend you change that because that could conflict with a ton of games.
Maybe make your exit key pressing Start+Options at the same time instead or something like that?
I have it set as esc. Also using the right trigger which is l or s...... I like esc.. But for one emultr I have I want to change exit.... Where is the per emulator exit key?
