mccorkled Posted December 27, 2015 Posted December 27, 2015 When trying to launch a Turbografx-CD game I get this error. None of my Turbografx-CD are working. Got them from PD. I am using Mednafen as the emulator. When I drag the .cue over the exe it plays fine. A PM with a link to a working bin/bue set would be great FILE "4 in 1 Super CD (USA).BIN" BINARY REM SESSION 01 TRACK 01 AUDIO INDEX 01 00:00:00 TRACK 02 MODE1/2352 INDEX 01 00:47:65 TRACK 03 AUDIO INDEX 01 01:09:29 TRACK 04 MODE1/2352 INDEX 01 01:57:19 TRACK 05 AUDIO INDEX 01 02:37:72 TRACK 06 MODE1/2352 INDEX 01 02:45:05 TRACK 07 AUDIO INDEX 01 03:12:12 TRACK 08 AUDIO INDEX 01 06:06:08 TRACK 09 AUDIO INDEX 01 06:37:50 TRACK 10 AUDIO INDEX 01 06:52:06 TRACK 11 AUDIO INDEX 01 07:23:29 TRACK 12 AUDIO INDEX 01 09:23:57 TRACK 13 AUDIO INDEX 01 11:23:17 TRACK 14 AUDIO INDEX 01 13:22:48 TRACK 15 AUDIO INDEX 01 17:53:27 TRACK 16 AUDIO INDEX 01 22:24:14 TRACK 17 AUDIO INDEX 01 26:54:18 TRACK 18 AUDIO INDEX 01 31:24:30 TRACK 19 AUDIO INDEX 01 35:54:45 TRACK 20 AUDIO INDEX 01 40:24:37 TRACK 21 AUDIO INDEX 01 44:55:44 TRACK 22 MODE1/2352 INDEX 01 49:14:23 TRACK 23 AUDIO INDEX 01 50:13:00 Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
Guest Posted December 27, 2015 Posted December 27, 2015 On 12/27/2015 at 4:21 PM, mccorkled said: When trying to launch a Turbografx-CD game I get this error. None of my Turbografx-CD are working. Got them from PD. I am using Mednafen as the emulator. When I drag the .cue over the exe it plays fine. FILE "4 in 1 Super CD (USA).BIN" BINARY REM SESSION 01 TRACK 01 AUDIO INDEX 01 00:00:00 TRACK 02 MODE1/2352 INDEX 01 00:47:65 TRACK 03 AUDIO INDEX 01 01:09:29 TRACK 04 MODE1/2352 INDEX 01 01:57:19 TRACK 05 AUDIO INDEX 01 02:37:72 TRACK 06 MODE1/2352 INDEX 01 02:45:05 TRACK 07 AUDIO INDEX 01 03:12:12 TRACK 08 AUDIO INDEX 01 06:06:08 TRACK 09 AUDIO INDEX 01 06:37:50 TRACK 10 AUDIO INDEX 01 06:52:06 TRACK 11 AUDIO INDEX 01 07:23:29 TRACK 12 AUDIO INDEX 01 09:23:57 TRACK 13 AUDIO INDEX 01 11:23:17 TRACK 14 AUDIO INDEX 01 13:22:48 TRACK 15 AUDIO INDEX 01 17:53:27 TRACK 16 AUDIO INDEX 01 22:24:14 TRACK 17 AUDIO INDEX 01 26:54:18 TRACK 18 AUDIO INDEX 01 31:24:30 TRACK 19 AUDIO INDEX 01 35:54:45 TRACK 20 AUDIO INDEX 01 40:24:37 TRACK 21 AUDIO INDEX 01 44:55:44 TRACK 22 MODE1/2352 INDEX 01 49:14:23 TRACK 23 AUDIO INDEX 01 50:13:00 I'd post this over at the RocketLauncher forums. As its an RL problem. Sent from my iPhone using Tapatalk
Spawk Posted December 27, 2015 Posted December 27, 2015 If you DL'ed from PD, I'm sure the images are fine. Have you used DT10 for any other systems? I seem to remember having some real issues trying to mount images with the newer DT's and had to revert to version 4 or 5.
mccorkled Posted December 27, 2015 Author Posted December 27, 2015 On 12/27/2015 at 5:51 PM, Spawk said: If you DL'ed from PD, I'm sure the images are fine. Have you used DT10 for any other systems? I seem to remember having some real issues trying to mount images with the newer DT's and had to revert to version 4 or 5. My Sega CD games run fine but I am not sure if RA handles the mounting or if DT10 does. I haven't set up PS1 yet since the XML changes constantly. Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
Spawk Posted December 27, 2015 Posted December 27, 2015 I don't think RA has anything to do with mounting (don't use it myself), but if the core is based on "fusion" then it does it's own mounting internally. I went back to version 4 (DTLite4454-0315 to be exact) and everything works great so far. I think ver 5 may be ok too but sometime after that they totally changed the way they mounted images. Or maybe they just removed CLI support. Can't remember.
