run program at start/end of emulator
d8thstar
hi all,
i am super new to HS, please be gentle :)
i almost have my system up and running 100%, one of the big hiccups i have is the need to reassign buttons when an emu starts and, assign them back to 'standard' when the emu ends.
i found an option in hyperHQ "startup/exit" but that seems to run at the start of HS (not emu specific) and when i exit HS (not exiting the emu).
i have ultimarc product in my machine and i have the wonderful u-config all set up but i don't know where to put the call within HS.
my previous FE handled this with pre/post emu command lines.
any thoughts?  thank you all.
i am, yes.  also have uhid64 board to handle all my buttons, which is what I'm trying to reprogram.
I just read theinstructions on their site and it says it will download the controller map to the joystick over USB.
For front ends you do this via a command line.
So maybe you can just use an app like led-blinky or Hyperspin Event Dispatch to plug in the command line before you launch the game.
Let me know because I plan on getting U360s soon for mine (with rotary joysticks added). People have been using them forever so it can't be to hard to setup.
