Any Flash Coders here? JLFS Script to be precise?
NewYears1978
Been trying to sort this out but can't find an answer. Since HS is coded in Flash/Autoit I figured I would post here and maybe someone would know
I use this script
Code:
/** PNG2SWF_MULTIPLE JSFL v 1.0* by Matus Laco,* Modified by dark13 to embedd PNGs as uncompressed files and allow smoothing* product URL:* inspired by Mr.doob** Description:* Converts multiple png files to multiple swf files.* Input: Select folder dialog box* Output: Same folder, same filename, swf extension*/png2swf();function png2swf(){    var folderURI = fl.browseForFolderURL("Select a folder.");    if (folderURI == null) { return; }    var folderContents = FLfile.listFolder(folderURI);var doc = fl.createDocument();doc.backgroundColor = '#00FF00';var imported = 0;    for(var i=0; i< folderContents.length; i++){                        var pngURI = folderURI + "/" +folderContents[i];    if (pngURI.substr(pngURI.length-4) != ".png") continue;        doc.importFile(pngURI);        // get item            var bmp_lib = doc.library.items[imported];    bmp_lib.compressionType = "lossless";        bmp_lib.allowSmoothing = true;    var bmp_tl = fl.getDocumentDOM().getTimeline().layers[0].frames[0].elements[0];// Scale from 1080p to 1024*768 and apply 16:9 ratio correctionbmp_tl.scaleX = 0.53333 ;bmp_tl.scaleY = 0.7111 ;bmp_tl.x = 0 ;     bmp_tl.y = 0 ;// set doc size        doc.width = Math.floor(bmp_tl.width)+1;        doc.height = Math.floor(bmp_tl.height)+1;    // export            var swfURI = pngURI.substr(0,pngURI.lastIndexOf(".")+1)+"swf";        doc.exportSWF(swfURI, true );        // remove previous from timeline        doc.selectAll();        doc.deleteSelection();        // increase imported count        imported++;    }    doc.close(false);    alert(imported + " files created.");}
Works great except I would like it to also look in the subfolders of my selected folder.
Thanks in advance! I've been googling for 2 days, but no luck.
Are you an HTPC user? Do you like Kodi/XBMC?
If so, check out these Kodi Style Themes!
Aeon Nox 13 by @dark13
Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress
If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
Yes correct :) Right now it only converts the the files in the main folder
