New to hyperspin with xml questions
Twiztedtechs
I have spent about 4 hours reading things and can not seem to find out the answer to this. I have installed hyperspin with RLUI all per Austin vids. Retroarc is installed and rom path is to hyperspin rom folder. When audit all games they show up but are red. I read some things about the list names may not match. Hyper tool and don. The rom set I installed I have been using on stand alone emu on both homebrew and android. Do these not use the same naming list as hyoerspin or am I going in the wrong direction? HS and RLUI linked and working properly from what I can tell.
If they show up red in the RLUI audit, they weren't found. Double check the rom path to make sure is correct.
Also check the names of the roms against the rom name in the database xml. They need to match exactly, and are case-sensitive.
Edit: Did you set the rom path in RLUI? You need to set that too, not just in retroarch.
Ok. This morning I rearranged and double checked my rom path in global and in nes system in RLUI. Both are accurate. Downloaded Don's tools. Set correct path in renamed from database xml and scanned. All games show up but are missing. Tried watching home arcade guys video on renaming but am not finding what is demonstrated. Dons list tutorial did not touch on renaming. Is there a tutorial more specific to that?
Ok never mind. I think the database xml is not working. Downloaded new xml and worked renamed the reloaded RLUI and all are green. Still will not boot but working on that
hi there, having same issue...i downloaded an nes pack that seems to have all the games however all games are showing red in rocketlauncher. where is the NES database stored? i can't find it rocketlaucherui/databases. i just see MAME (which is setup correctly). I assume i should make a nes folder with an xml file inside?
i fixed it (for me), i just clicked "create database" based on rom path and then all the games turned green. they load up!
unfortunately for whatever reason i cannot go into the NES from hyperspin, i click the menu and it just opens then takes me right back to main wheel. wont open and show me all the NES games. rom path in hyperhq is set correctly
i fixed it (for me),Hyper clicked "create database" based on rom path and then all the games turned green. they load up!
Did you also add the the extension the HyperHQ? And if you run Hyperspin 1.3 and Rocket launcher then ROM filtering won't work. Not really any point in wheel filtering if your XML is correct.
