HS is not shutting down LEDBlinky
DHG
I have been having this issue for years and never really knew why.
This is one of a few issues but one thing at a time.
A good bit of the time I exit HS LEDBlinky is not closing and my 'Frontend Active' light display keeps going until I manually shut down LEDBlinky with Windows Task Manager.
From research I done over the last few days I'm under the impression that HS is the issue not shutting down LEDBlinky
Here is a copy of the HS log from a quick test....I just pasted since its not that big.
What is the deal with the 'Unavailable' items.. and can this be related to my problem
08:38:23 PM |  Startup program unavailable
08:38:58 PM |  Error intializing joysticks (not sure what this is all about... the joysticks work fine)
08:40:50 PM |  Exit program unavailable
08:38:23 PM |  HyperSpin Started
08:38:23 PM |  Going FullScreen
08:38:23 PM |  LEDBlinky is set to active
08:38:23 PM |  Found LEDBlinky.exe
08:38:23 PM |  Running LEDBlinky
08:38:23 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 1
08:38:23 PM |  Checking for updates
08:38:23 PM |  Update Check Complete
08:38:23 PM |  Playing intro video
08:38:58 PM |  Menu Mode is multi
08:38:58 PM |  Loading Main Menu.xml
08:38:58 PM |  Main Menu.xml successfully loaded
08:38:59 PM |  Main Menu wheel loaded successfully
08:38:59 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "MAME" "Main Menu"
08:39:04 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Commodore 64" "Main Menu"
08:39:07 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 8
08:39:07 PM |  Loading Commodore 64.xml
08:39:07 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 7 "Commodore 64"
08:39:08 PM |  Main Menu.xml successfully loaded
08:39:09 PM |  Commodore 64 wheel loaded successfully
08:39:09 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "10th Frame"
08:39:14 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Archon"
08:39:17 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Archon (cheat)"
08:39:20 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Archon II"
08:39:22 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "BC II - Grog's Revenge"
08:39:27 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "BC's Quest For Tires"
08:39:29 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Beach-Head (docs cheat)"
08:39:29 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Beachhead II - The Dictator Strikes Back"
08:39:30 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Beyond Castle Wolfenstein"
08:39:38 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Boulder Dash"
08:39:41 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 4
08:39:41 PM |  Loading Main Menu.xml
08:39:41 PM |  Main Menu.xml successfully loaded
08:39:42 PM |  Main Menu wheel loaded successfully
08:39:42 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "Commodore 64" "Main Menu"
08:39:43 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "MAME" "Main Menu"
08:39:44 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 8
08:39:44 PM |  Loading MAME.xml
08:39:44 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 7 "MAME"
08:39:44 PM |  Main Menu.xml successfully loaded
08:39:45 PM |  MAME wheel loaded successfully
08:39:46 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "bking2"
08:39:47 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "bking3"
08:39:51 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "blaster"
08:39:52 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "blstroid"
08:39:54 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "bosco"
08:39:57 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "btime"
08:39:59 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "centiped"
08:40:00 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "centipdd"
08:40:02 PM |  Launching Game
08:40:02 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 3 "centipdd" "MAME"
08:40:02 PM |  Using HyperLaunch
08:40:02 PM |  Getting Launcher path
08:40:02 PM |  Launcher located at E:\Hyperspin\RocketLauncher\RocketLauncher.exe
08:40:02 PM |  Running Launcher
08:40:02 PM |  Launcher Command Line is: E:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "centipdd"
08:40:35 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 4
08:40:38 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "centiped"
08:40:38 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "centipdd"
08:40:41 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "choplift"
08:40:41 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "chopper"
08:40:43 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 4
08:40:43 PM |  Loading Main Menu.xml
08:40:43 PM |  Main Menu.xml successfully loaded
08:40:44 PM |  Main Menu wheel loaded successfully
08:40:44 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 9 "MAME" "Main Menu"
08:40:50 PM |  Quiting Hyperspin
08:40:50 PM |  Command Line is: "E:\Hyperspin\LED BLinky\LEDBlinky\LEDBlinky.exe" 2
08:40:50 PM |  Bye!
The Startup & Exit unavailable sounds like you have an EXE set to start with HS in the HyperHQ settings, but either the exe is bad or the path is.
Just my guess, but it's the first thing I'd check.
Maybe the joystick error is caused by sending a blinky command to the sticks they can't except. Like telling them to light if they aren't LED.
All just guesses. I've never seen or used LED Blinky, but will be rebuilding my CP for RGB soon.
I have nothing in my settings for a startup or exit program... I don't even have any clue what those would be used for?
Nothing should be setup like that with LEDBlinky for the joysticks... I'll check on that and send arzoo an email if necessary.
Maybe those 'unavailable' prompts are standard if you have nothing in setting for it?
Must be then. Other than that I have no idea.
