trekdropp Posted January 31, 2016 Posted January 31, 2016 I really would like to add bezels, now i have a lot off them. the problem is that they doesn’t work.. They need to be in a folder with a .ini file? The problem is that i only have the bezel file .png. Can someone please help me how i can put all the bezels in separate folders and put the ini file with the same name as the bezel...
griffin518 Posted January 31, 2016 Posted January 31, 2016 I'm assuming you're talking about RocketLauncher bezels? Each bezel needs to be in a separate folder, name matching the ROM name exactly, and it must have an .ini file with the same name as the .png file. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
trekdropp Posted January 31, 2016 Author Posted January 31, 2016 I'm assuming you're talking about RocketLauncher bezels? Each bezel needs to be in a separate folder, name matching the ROM name exactly, and it must have an .ini file with the same name as the .png file. Yep thats what i am saying, only i am looking for a easy way to get my .png in a folder with the same name and with a .ini file with the same name. Because i have a lot of bezels only the bezels in no folder.
Metalzoic Posted January 31, 2016 Posted January 31, 2016 Yep thats what i am saying, only i am looking for a easy way to get my .png in a folder with the same name and with a .ini file with the same name. Because i have a lot of bezels only the bezels in no folder. Why aren't they already in properly named folders with ini's? Where did you download them at? I don't know of any easy way. You'd need to manually make and name eaqh folder (making sure the name matches the rom) and add your .png's to it. Then make ini's with the correct coordinates and also copy/paste those into the folders. Different bvezels may need different ini's. Honestly you'd be better off just going and re-downloading sets that are already setup right.
trekdropp Posted January 31, 2016 Author Posted January 31, 2016 I was searching for art for my cab and found a bunch of them. Where can i download them? Because putting 900 bezels in a folder
Metalzoic Posted January 31, 2016 Posted January 31, 2016 I was searching for art for my cab and found a bunch of them. Where can i download them? Because putting 900 bezels in a folder 900? If you found a bunch of them then they all should have been in folders with ini's already... Unless these are MAME bezels (run directly in MAME) instead of RocketLauncher bezels (work with RocketLauncher). You can check the bezel section here and the bezel section on the RocketLauncher forums.
trekdropp Posted January 31, 2016 Author Posted January 31, 2016 Yeah there mame bezels, is there a way i can use them for rl? Or do i just need to search bezels on some other forum that will work with rl.
Metalzoic Posted January 31, 2016 Posted January 31, 2016 If they are MAME bezels with .lay files you could convert them to work with RL, but then you're back to foldering, naming, and iniing them all. Why search some other forum? I just told you that you can check the bezel section here and at the RocketLauncher forums. The pack I have posted here has RL bezels for 700+ games. If you don't like my matched set you can also get all of Krakermans, Alex's, Ashurax's etc... bezels here and there.
trekdropp Posted February 1, 2016 Author Posted February 1, 2016 I have found them in the rl forum there perfect! Thank. Only problem that i cannot figure out.. when i launch a game with a bezel my windows taskbar is still visible.
