Anonymous Posted February 16, 2016 Posted February 16, 2016 Hi All, Please be gentle it’s my second post as a noob!! I wanted to run this past everyone here first before running with my build and hopefully with all of your input \ experience it will guide me in the right direction. I want and I say this very lightly a simple yet robust setup using Hyperspin and wanted to know the benefits of the three examples using: Hyperspin on its own Hyperspin with RL Hyperspin with RL & RetroArch Also what are the prerequisites before installing \ setting up any of the following. Any advice would be appreciated. Cheers.
SIMPLYAUSTIN Posted February 16, 2016 Posted February 16, 2016 HyperSpin and RocketLauncher is kinda the standard and most supported here. You need a PC with windows, x64 and 7+ will cause you the least issues. The more power you have the better the systems you can emulate... in terms of power I am talking CPU Ghz. RocketLauncher is just a Emulator to make it simple... you add lots of them to make many systems run. All depends what you want to play? Simply Austin's YouTube
32assassin Posted February 16, 2016 Posted February 16, 2016 Hyperspin on its own is not an option, Hyperspin uses RL or Hyperlaunch2 to launch your emulators. so you will need Hyperspin + RL + emulators ( Retroarch and the emulators for the systems not supported by Retroarch) most of the requisites will be made by the emulators you install, RL needs Net Frame Work 4.0 or above.
Anonymous Posted February 18, 2016 Author Posted February 18, 2016 SIMPLYAUSTIN you are a star !! I've been following your YouTube vids and I only wish (I say again) wish I would have found out about you and this community sooner. (My story is I purchased a bag of sh*t (HDD) preconfigured to reminisce) Anyway that aside im starting from fresh. I've been enjoying the ride following your vids and so far have three consoles setup and running YAY !!! Please, please listen to Austin DO NOT BUY THESE DRIVES. Follow Austin's Vids they are a great help and you will save loads.
